Aiming Morimoto XB led headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by Ladderman30, Feb 26, 2020.
  1. Feb 26, 2020 at 2:55 PM
    Ladderman30
    Ladderman30 [OP] New Member
    2010 brown sr5 double cab
    Has anyone had to aim their Morimoto XB led lights? I put my lights on today and one side is lower than it should be. I have been told there are adjustment screws in the back. I guess you have to take the light back off to get to them. Is there any other way.
  2. Feb 26, 2020 at 3:08 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    You should be able to access from the top with a long skinny Phillips screw driver without removing. I have read on here multiple people not realizing this until after the fact of ripping the headlight out and adjusting 10+ times.
    let me see if I can find better details, but I suggest popping the hood and looking down into the back of the headlight, there should be a space there for the screw driver to fit in and hit the adjusting screw.
    cheers,
    831Tun likes this.
  3. Feb 26, 2020 at 3:24 PM
    TheBeast The Beach
    are you talking about driver side ? because it is usually lower than passenger as not to blind driver in front of you. unless it's really low.
  4. Feb 26, 2020 at 6:31 PM
    Ladderman30
    The passenger side is 2 ft. lower than the driver side.
  5. Feb 26, 2020 at 6:34 PM
    Ladderman30
    Which way to turn screw to lower, clockwise or counter-clockwise?
  6. Feb 26, 2020 at 7:12 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  7. Feb 27, 2020 at 7:25 AM
    Ladderman30
    No I have a 2010
  8. Feb 27, 2020 at 10:00 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Adjustment is almost the same. Its been a while since I have my '12 so can't quite remember, but I believe you can still reach them with a wrench from above.
    https://www.youtube.com/watch?v=kcxQssGld1o
  9. Feb 28, 2020 at 6:08 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    when I installed my XB head lights I noticed my drivers side was low by about a foot or so. just get the long Philips screw driver and just start turning. it takes a couple minutes but you'll notice movement right away. I can't remember which direction, but it won't harm it. I adjusted them on the truck and definitely do it at night.
    SC_TRD and TheBeast like this.
  10. Feb 29, 2020 at 8:22 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    I went and took a quick picture of alpharex housing adjustment. looks something like this.
    theres two adjusters one for horizontal adjustment and another for vertical. just start spinning it and you will start to see it move after a few turns
  11. Feb 29, 2020 at 8:32 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    also make sure the housing went all the way into the clip that the lower inside corner of the housing clips into.
  12. Mar 10, 2020 at 5:48 AM
    Sparkyman13
    Sparkyman13 Sparkyman13
    Washington State
    Magnetic grey tundra limited 2016
    Bilstein 5100's, CB 1" Rear, Diode Dynamics SS3 Fog Lights, Goodyear Duratrac 305/55R20
    8mm wrench to the little white nut that’s totally accessible without removing. Counterclockwise to raise.
    mtucker, mb66 and (deleted member) like this.
  13. Jul 18, 2020 at 3:13 PM
    07tundraSILVER
    07tundraSILVER New Member
    does anyone have a picture of the headlights leveled at a wall
    Vockroth likes this.
  14. Jul 22, 2020 at 5:16 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    https://youtu.be/BwlY4RD3le0
    i also bought the $95 hilux wire harness off ebay and added manual level control. remember the instructions say do not turn more than three full revolutions or you can leave the assembly in a state where they may not adjust anymore. i turned both sides until they were level so one side wasn't turned too much. good luck.
  15. Jul 23, 2020 at 9:19 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    8mm and completely accessible without pulling them. Passenger side is a little tighter.
    mtucker likes this.
  16. Oct 20, 2020 at 6:53 PM
    mdh1470
    mdh1470 New Member
    Tennessee
    2017 Midnight Black Mettalic Tundra Platinum CrewMax 4x4 5.7L V8
    LED interior/ground lights, 3" Leveling Kit, 20" Fuel Rims, 33/12.5/20 Nitto Ridge Grapplers, Hard Tri fold Tonneau Cover, Rhino Linings Spray-in Bed Liner, 8" SS BAMuffler
    I recently bought Morimoto XB LED Headlights & Fog Lights for my 17 Tundra Platinum CrewMax (I have a 3” lift w/33s on 20” rims).
    1. How do I adjust Headlights horizontally? It seems like the field of view is narrow. Hardly can see road when making a 90 degree turn onto a 2-lane road.
    2. Fog lights are almost non-visible. Seem to be very low. How do I aim these?
    3. I’m also getting issues with headlights where the DRL on one side goes off when I use turn signal. It also goes off when i turn off vehicle while other DRL stays on until I hit lock, then both go off like they should.
    4. The other DRL is dimmer, but works fine.
    Any ideas on what’s causing issues? How to fix?
  17. Oct 21, 2020 at 6:29 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    You do it with a long philips screw driver. It engages the gear ring shown in the pics above. The philip acts as a gear to turn the ring.
    Do it at night and you will see which way moves the light up or down.
  18. Oct 21, 2020 at 7:16 AM
    @Headlight Revolution. The DRL becomes the turn signal when activated. Can you post a video of your issues? What fuse spot are you plugged into? Of one DRL is dimmer, it might be a warranty issue but we need to see your connections.
  19. Oct 21, 2020 at 10:24 AM
    mdh1470
    mdh1470 New Member
    Tennessee
    DRL brightness difference.jpg DRL Fuse Location.jpg DRL On_Off Issue.jpgLights FOV.jpg
    Top Left: Driver's side DRL is brighter than Passenger's side DRL
    Top Right: DRL fuse location
    Bottom left: Driver's side DRL not working when vehicle is turned off, but ignition is in the "On" position (Both DRLs work when vehicle is running)
    Bottom Right: Lights seem to be a narrow field of view (How do I adjust horizontally?)
    How do I fix these issues? Or, is there a warranty problem? I have some difficulty seeing a 2-lane road when making a 90 degree turn onto one because of the narrow light path.
    Fog lights are on in bottom right pic. They seem to be really low. Are these adjustable vertically? Toyota actually installed the Fog lights for me. They just seem to be shining lower than the factory halogen fogs were.
  20. Oct 21, 2020 at 12:25 PM
    I will look at mine to see where its plugged in. Can you swap your lights to opposite side? I want to see if the dimness followed the passenger side light or if it stays on the passenger side after you know the fuse tap power lead up to it. That would narrow it down to the pass side light or the power to it I. The fuse tap.
  21. Oct 22, 2020 at 9:48 AM
    Sparkyman13
    Washington State
    Does the the other side DRL go away and amber turn signal work when activated? Did you have DRL's on your factory lights? I had to replace the factory relay on my 16' to make the DRL's work with turn signals. I only had the amber bulb DRL from factory. Might not be the issue but just raising the question. Good luck fixing the issue, I love these lights myself.
    mdh1470 likes this.
  22. Oct 22, 2020 at 9:50 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Can you shoot us an email on this one? I'm thinking this is most likely a DRL harness issue which we'd be happy to replace! we're happy to help out with troubleshooting over email, that'll be the fastest way for us to get back to you! :) We'll get to the bottom of this one. As far as the fog lights go, they are adjustable! You'll need to peel back the fenderliner on each side and turn the wheel in different directions to have better access to them. From there, you can pivot the fog light in it's bracket up or down and adjust as needed! :)
    Sales@HeadlightRevolution.com
  23. Apr 28, 2021 at 2:55 AM
    redrum448
    redrum448 New Member
    Digging up old thread...
    Did you ever get an answer about your horizontal issue?
  24. Apr 28, 2021 at 4:42 AM
    mdh1470
    mdh1470 New Member
    Tennessee
    Turned out that it was a messed up light set. Warranty replacements work great. I also had to adjust lights so the dial next to steering wheel would properly raise/lower beam projection. I was getting high beamed multiple times a day with the dial turned to the lowest angled beam setting. Once I adjusted lights, the dial adjustment worked great. I have it set on 3 and blind no one even at a 3” lift.
  25. Apr 28, 2021 at 5:54 AM
    redrum448
    May I bother you for a picture of the new light spread?
    And do you know if there even is a horizontal adjustment?
    (thanks for the help!)
  26. Apr 30, 2021 at 3:57 AM
    redrum448
    I dont believe the offsets from L and R headlights should be this close. What does any "expert" think?
    Headlight Revolution likes this.
  27. Apr 30, 2021 at 5:13 AM
    mdh1470
    mdh1470 New Member
    Tennessee
    Mine are similar. But prob not as bad as yours. Im not sure there is horizontal adjustment. I’ll post a pic of mine tonight when it gets dark. I like mine. Took some getting used to though.
  28. Apr 30, 2021 at 5:19 AM
    Atlanta, GA
    There is a horizontal adjustment, it can be reached from uptop with a philips screwdriver! :)
  29. Apr 30, 2021 at 5:21 AM
    Atlanta, GA
    Looks good! If anything, you could separate them a little bit for more width, but that's entirely up to your preference! :) There is no real proper layout for width, it's whatever you're most comfortable with! Closer together will strengthen your hotspot, giving you more distance vision down the road. Widening it out will allow for more side-to-side vision!
    It's the vertical adjustment that you want to have dialed in properly, and yours looks great!
    Ohannon7 likes this.
  30. May 7, 2021 at 1:24 PM
    Sparkyman13
    Washington State
    Thats exactly how mine are adjusted
