Aftermarket Head Units
Discussion in 'Audio & Video' started by aag5, Oct 19, 2017.
  1. Oct 27, 2017 at 4:51 PM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    I travel all around the country with my job, and I have nothing but bad things to say about Google Maps. About 10% of the time it is major wrong! Almost makes me want to get an I-Phone.
    aag5[OP] likes this.
  2. Oct 28, 2017 at 12:52 AM
    Ahhhz
    Ahhhz New Member
    Oz
    17 Limited 4x
    My CarPlay on the ilX runs google maps all day. It’s quite intuitive and suggests where I might be going. It has an updated 3d map function and effortlessly shuts off voice nav with a single tap. I can just press the steering control for voice commands and say “direction to dildo factory” and it pops right up. I do miss Waze tho
  3. Oct 28, 2017 at 12:11 PM
    Judd1980
    Judd1980 New Member
    Judd
    2014 Tundra Platinum
    As anyone gone aftermarket only to go back to their entune setup? I don't care much for the JBL setup, but I see other owners paying a decent amount for them. ...and I wonder why?
  4. Oct 28, 2017 at 9:21 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'm aware you can play Google maps nav audio instructions through your CarPlay system. Unless you are jail-broken, however, I don't think you can actually display Google Maps on your CarPlay screen. If I am mistaken, the world would like to know how you did that.
  5. Oct 30, 2017 at 10:35 AM
    Ahhhz
    Ahhhz New Member
    Oz
    17 Limited 4x
    No jail break... professionally installed not sure what they did. Probably has to do with swapping screen out with alpine ilx
    aperezsh likes this.
  6. Oct 31, 2017 at 5:19 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    That looks like Apple Maps, not Google Maps. They are not the same thing.
  7. Nov 1, 2017 at 10:42 AM
    Ahhhz
    Ahhhz New Member
    Oz
    17 Limited 4x
    Well phuck me rotten and call me Barry. You may be right. I’m a woodworker so all comps looks like google to me
    Pudge, SuaveRC and bobeast[QUOTED] like this.
  8. Nov 26, 2017 at 4:47 PM
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Do you have instructions since I just placed the order for Kenwood unit?
  9. Nov 26, 2017 at 6:53 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Instructions for what specifically? Generally, you can just specify your truck on Crutchfield, select the unit you bought and follow their recommendations. If you want to take advantage of all the unit has to offer, you'll need the iDataLink module which has a connector for your OBDII. Thats how the unit is able to display vehicle parameters.
  10. Nov 26, 2017 at 7:09 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I placed the order maestro rr, harness, Kenwood 9904s but I have never removed head unit off tundra. Not sure if someone have instructions how to do all work or some write up.
    Is it completely plug and play or still need some wire splicing?
  11. Nov 27, 2017 at 8:46 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    There may be such threads. Dunno. There are just too many vehicle/radio/option combinations for any one DIY thread to be much more than a general guideline. Most of us just start ripping things apart. Again, crutchfield is a great resource for technical knowledge, even if you buy your stuff elsewhere. Once you get past your first radio swap, you'll find how easy it is. If you get the right harness as specified by crutchfield very little splicing (if any) is required. Just dig in. Then if you get stuck, post up your specific questions.
    LKSR5-14 likes this.
  12. Nov 27, 2017 at 9:34 AM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks for your input. I'll get back if I come across with any problems.
    I do have one question, does SR5 tundra has already installed GPS antenna even if my hu didn't come with navigation since it's basic hu.
  13. Nov 27, 2017 at 9:53 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Its doubtful your SR5 has a GPS antenna. Even if it does your new setup will come with one. Just use the one that comes with your new HU, regardless. I placed mine under the center speaker grill in my Limited.
    LKSR5-14[QUOTED] likes this.
  14. Nov 27, 2017 at 9:58 AM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Good tip since I didn't know if antenna should be visible (I don't like it) but glad to hear that can be placed in hidden space and still do their job with signal.
    I see some people plug existing antenna from vehicle but you stated differently and I may go that route as well.
    Thank you
  15. Jul 8, 2018 at 7:10 AM
    tgo
    tgo New Member
    Central VA
    2018 Limited CM Silver Sky
    Google Maps will be usable and able to be viewed through Apple CarPlay in the next few months. Once iOS 12 is released, all CarPlay products will be compatible with Google Maps and Waze. Good News!
  16. Jul 20, 2018 at 10:41 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Good news indeed! I was at WWDC this year when they announced that Waze would be coming to CarPlay. My life is complete.
    xando likes this.
  17. Aug 14, 2019 at 7:32 PM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
  18. Aug 14, 2019 at 8:29 PM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    whatz a good unit for a 2014 Tundra? My factory unit keeps freezing up and restarts once a day. I have updated but still dose the same, so i want to changed to after market better
    Voyagermike likes this.
  19. Aug 14, 2019 at 8:42 PM
    #49
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Swapping to a kenwood headunit sounds like a great idea. The Bose speakers....not so much. The headunit + idatalink maestro RR can be installed and you can use your OEM amp and speakers and it'll sound much better. Or you can do the kenwood+maestro+amp+speakers/sub and it'll sound incredible. There are a ton of speakers out there that are infinitely better and more affordable than Bose. Check out tech12volts... tech12volt@gmail.com
    James has full systems ready to go for your tundra. They can do a mild upgrade right up to premium competition level stuff.
  20. Aug 15, 2019 at 6:57 PM
    #50
    Skeezo
    Skeezo New Member
    WHITE 2019 TRD OFF ROAD
    Do the steering wheel buttons still work with this system and how about the dashboard display? Is it still operational?
