Aftermarket Dash Cam
Discussion in '3rd Gen Tundras (2022+)' started by paradizecityz, Oct 1, 2022.
  1. Dec 8, 2023 at 8:30 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    If you go on the site and search tundra it’ll come right up.
    G3ardnut[QUOTED] likes this.
  2. Dec 9, 2023 at 4:54 AM
    wfhandrv
    wfhandrv New Member
  3. Dec 9, 2023 at 4:15 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Thanks all
    I’m on that bracket.
  4. Dec 25, 2023 at 4:49 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thank you very much.. Bracket came in ( albeit late but i guess i should be thankful that it arrived)
    anyways i went with the alpine dash came and at first i absolutely regretted buying it.. then after going through the settings i realized that the camera Lense was not set properly and had to be angled up which was easy. More settings manipulation and i got it dialed in. just took me playing around with it in the alpine halo unit
  5. Jan 8, 2024 at 5:24 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    I'm leaning towards this cam setup. Does this hookup allow for parking recording?
  6. Jan 8, 2024 at 5:37 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    No. I’m sure there is a way tho, but I don’t wanna hack up more wires
  7. Jan 8, 2024 at 7:30 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    A member here sells a harness that plugs into the oem dashcam plug....provides constant and switched power so you can use parking mode...no wire hacking
    gj953 likes this.
  8. Jan 8, 2024 at 7:58 AM
    gj953
    gj953 New Member
    East Coast
    I might check out on the blackboxmycar I think it is powercell for parking mode... I've got to see how much heat/size it is to see where it might go - underdash or overhead. We'll see.
    eddiefromcali likes this.
  9. Feb 27, 2024 at 1:08 PM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    Wanted to bump this thread and ask how people are powering the rear facing camera? I'm wondering if the adapter in the headliner would be able to take 2 cameras, or maybe the better choice would be the sockets in the back seat. I bought the Garmin and the Dongar cable. Wouldn't be too hard to split the power off the Dongar cable to supply 2 cameras but it might not work. I would hate to ruin something in the headliner or blow a fuse then have to hunt for the blown fuse.
  10. Feb 27, 2024 at 1:24 PM
    zonehenge
    zonehenge New Member
    Pete
    Western Mass
    2022 Solar Octane TRD Pro
    285 75 18's Wild Peak, PPF for front, Go Rhino RB20 slims, Truxedo Sentry CT, TVD decals
    I'm very happy with my Fitcam X, didn't get the rear camera option. Super easy install and you can't tell I have a camera when looking inside the truck.
  11. Feb 27, 2024 at 4:40 PM
    TexasTacoma713
    2023 SR5
    My rear cam is powered by the front which is powered by the dongar cable.. Viofo 4K.. Highly recommend
    Tundrastruck91 and G3ardnut like this.
  12. Feb 28, 2024 at 4:47 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    How did you split the power to each camera? I'm thinking a dual camera system may have a cable that comes with it that allows it. I'll check the Viofo cam setup on their site. Thanks.
  13. Feb 28, 2024 at 6:00 AM
    TexasTacoma713
    2023 SR5
    Dongar cable powers the front cam unit. A cable that is tucked into the headliner then powers the rear unit… Not sure how else to explain it
    I would think a lot of cam systems are run this way, in order to sync the video. But I only have the Viofo 4K so can’t speak on other manufacturers
  14. Feb 28, 2024 at 8:48 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    Thank you for the info. I think my confusion comes from only having a single cam system. I've got to look at the 2 cam systems to see how they work and tie together.
  15. Feb 28, 2024 at 1:38 PM
    TexasTacoma713
    2023 SR5
    The front camera powers the rear camera if that makes more sense
  16. Feb 28, 2024 at 2:57 PM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    Ah! That makes sense! Thanks!!!
    I was thinking something like 2 connectors coming off the connector in the headliner.... Thanks!
  17. Mar 4, 2024 at 10:53 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    Is the bracket for the back cam hard to get into the headliner?
  18. Mar 4, 2024 at 1:39 PM
    TexasTacoma713
    2023 SR5
    Just wedges in, no hassle at all. Wire for my rear cam is easy too. Just push it in using a blunt tip trim tool or popsicle stick
    joescho[QUOTED] likes this.
  19. Jul 24, 2024 at 11:34 AM
    #49
    jguedry
    jguedry New Member
    john
    2024 tundra 1794 LE mesquite, 2016 blizzard pearl land cruiser
    How did you route the rear?
  20. Jul 25, 2024 at 5:25 AM
    #50
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Which model is that? The A139?
  21. Jul 25, 2024 at 5:42 AM
    #51
    TexasTacoma713
    2023 SR5
    The rear camera is powered by the long cord. You can buy different length cords directly from Viofo.. Just tuck it inside the headliner with a trim tool
    Yessir.. You can find them cheap on eBay or Amazon.. My only gripe about it is its WiFi connection only. So you have to disconnect from Apple CarPlay to view it. But the clarity is great, once you go 4K, you won’t go back
    #51
    dccrens[QUOTED] likes this.
