Aftermarket Dash Cam
Discussion in '3rd Gen Tundras (2022+)' started by paradizecityz, Oct 1, 2022.
  1. Oct 1, 2022 at 1:20 PM
    paradizecityz
    paradizecityz [OP] New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Share your aftermarket dash cam setups please. Doing my search now but I might end up getting Garmin Mini 2. How did you plug it up?
    I don't want to spend $500 on Toyota's
  2. Oct 1, 2022 at 1:48 PM
    devron11
    devron11 New Member
    Ron
    Denver
  3. Oct 1, 2022 at 3:28 PM
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    I'm also looking for an aftermarket dash cam. Do they make one that uses one of the USB ports? Since my truck doesn't have a standard DC outlet. They do have hard wire kits but................
  4. Oct 1, 2022 at 3:31 PM
    paradizecityz
    Richmond, TX
    what trim level that you don’t have a cigarette outlet?
  5. Oct 1, 2022 at 4:00 PM
    GunnyTundy
    GunnyTundy New Member
    North Dallas, Texas
    2022 Lunar Rock Tundra
  6. Oct 1, 2022 at 4:15 PM
    paradizecityz
    Richmond, TX
  7. Oct 1, 2022 at 10:57 PM
    dreamcatcherxo
    dreamcatcherxo New Member
  8. Oct 2, 2022 at 3:05 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
  9. Oct 2, 2022 at 6:26 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    I'm running a Garmin Mini 2. I got the adapter that Dongar makes that allows you to run the USB power cable up into the opening for the mirror and connect where the toyota cam plugs in. Looks clean, I'm happy with it.
    https://dongar.tech/products/optionconnectortoyota
    romanlegion, Alden, ReCKzX and 8 others like this.
  10. Oct 2, 2022 at 7:15 AM
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    Thats a clean install. Found the DC outlet. Had my truck for 9 months still learning it.
  11. Oct 2, 2022 at 7:56 AM
    paradizecityz
    Richmond, TX
    This was what I was thinking of doing. I didn’t order that adapter because in the description, it stated that auto dimming mirror is required and mine didn’t come with that so wasn’t sure if it would work?
    TheGreenGoblin likes this.
  12. Oct 2, 2022 at 8:03 AM
    Kagisexton
    Kagisexton New Member
    Christopher
    2022 Tundra Platinum
    same camera here but not comfortable hard wiring myself.
  13. Oct 2, 2022 at 8:19 AM
    Boats N TRDs
    Travis
    Chrome delete
    Not sure what that is all about. Trucks without auto dimming can still have the toyota cam so obviously the power harness is there regardless of what type of mirror you have. I wonder if it has to do with routing of the wire. The toyota cams run the wire directly above the cam where the headliner meets the glass, not through the mirror opening. You could always pull the roof console down and check out what's going on up there. It's very simple. The console comes down as a single unit, don't take it apart. The front side (closest to windshield) pulls straight down. Then slide forward to release the rear side. You don't even need to disconnect anything, just let it hang out of the way while you're in there. There is also a trim piece around the mirror base that comes off easily and will allow you to see better up in there. If you go with the adapter, make sure you use zip ties or double sided tape to keep the connectors from rattling around up there.
  14. Oct 2, 2022 at 8:23 AM
    pursuit2550
    pursuit2550 New Member
    For t hose of you that have a dash cam, do you guys leave it in the truck permanently or remove it when you get somewhere. I always have this feeling that someone will break in just to steal it.
    Kap1 likes this.
  15. Oct 2, 2022 at 8:28 AM
    paradizecityz
    Richmond, TX
    Thanks! I'll just order now and deal with it when it comes in lol
    Does this give you access to 24 hour power?
  16. Oct 2, 2022 at 8:34 AM
    GunnyTundy
    North Dallas, Texas
    The quality looks good from what I can see on the camera screen. I'll have to pull footage to see how good it looks compared to windshield nounting. I'll let you know. I'll try to check it this afternoon.
  17. Oct 2, 2022 at 8:35 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    That's looks good, I may give that a try. Currently, I concealed a long cable and ran it to the USB outlets in the backseat so it's out of the way.
    I leave mine in because it has parking lot monitoring in case of hit and run. I hope I don't jinx myself with this statement, but, I've used a dashcam for 10+ years and always left it in.
  18. Oct 2, 2022 at 8:37 AM
    GunnyTundy
    North Dallas, Texas
    I'm sure it records upside down but you can use any editing software to flip it to the correct orientation if needed. The outlet only supplies power when you turn on the engine or accessory power on.
  19. Oct 2, 2022 at 8:38 AM
    GunnyTundy
    North Dallas, Texas
    I'll try and check this afternoon and get back to you on this thread.
  20. Oct 2, 2022 at 8:39 AM
    Boats N TRDs
    Travis
    Chrome delete
    Out of the box it will power on/off with the truck. The harness in the truck has 5 wires coming in. The adapter is tapping into only 2 of them. Because the toyota cam has parking mode, I'm thinking that one set of wires to the harness must be constant power. I'm considering modifying my adapter to work off the constant power, but need to research more on the garmin side to make sure it's not just going to record 24/7. I just don't want to mess with the camera every time I go for a drive.
  21. Oct 2, 2022 at 9:03 AM
    FrozenFella
    FrozenFella New Member
    Kev
    Canada's Yukon
    2022 Tundra Crewmax Ltd & 2013 Tacoma TRD Sport Premium
    I had my Garmin 56 installed in my Tacoma with the hardwired Garmin parking mode cable so it had constant power and worked as a security/vandalism/crash cam when parked. https://www.garmin.com/en-CA/p/587564/pn/010-12530-03 (Garmin Canada link)
    With my Tundra I run it from the dash "cigarette lighter" socket and a USB converter plug, but that's just powered when the truck is running.
    I just ordered and received the Garmin OBD2 constant power cable which is relatively new to Garmin, but haven't installed it yet to see how it works.
    https://www.garmin.com/en-CA/p/735279 (Garmin Canada link)
  22. Oct 2, 2022 at 12:27 PM
    GunnyTundy
    North Dallas, Texas
    Front dash view and interior view from my setup.
  23. Oct 2, 2022 at 3:25 PM
    pursuit2550
    ElectricMan, TheBeast and Troyboy84 like this.
  24. Oct 2, 2022 at 4:43 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    There are 2 other threads in this forum that cover a lot of what you all are looking for. Do the search and you'll find a connector in the headliner available...
  25. Dec 8, 2023 at 4:36 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I didn’t want to start and entirely new dash cam thread but I wanted to know if there is anyone using the alpine DVR -C320R specifically and also if you have it paired with a alpine halo unit?
    thanks in advance
  26. Dec 8, 2023 at 6:07 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Dongar cable, Viofo 4K dual cam, and TheDashCamStore bracket (get the long version).
    Couldn’t be any happier with this setup… And my god it is super clear.
    WesternDawg and G3ardnut like this.
  27. Dec 8, 2023 at 6:53 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Looks great but for crew max owners
    Rigging the rear camera may not be an option since the back window goes down.
    But i imagine someone has over come that obstacle
  28. Dec 8, 2023 at 7:08 AM
    Maharisc
    Maharisc w/Patty
    Karl
    gj953 and TexasTacoma713 like this.
  29. Dec 8, 2023 at 8:06 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    No effect on the window. I have that mount and my window works fine.
  30. Dec 8, 2023 at 8:27 AM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I think this is the perfect set up and the way I want to go on my truck. Do you have a link/part number for the rear view cam bracket from TheDashCamStore. Thx.
    EDIT: I found the link, just missed it in one of the responses.
    gj953 likes this.
