After Market Fog Lights
Discussion in 'Lighting' started by CHASDON, Aug 5, 2018.
  1. Aug 5, 2018 at 8:57 PM
    CHASDON
    CHASDON [OP] New Member
    2018 Tundra
    I'm looking for aftermarket fog lights for my 2018 Tundra, as mine didn't come with this option. Any suggestions? The Toyota dealer informed me that they cannot install factory fog lights on it.
  2. Aug 5, 2018 at 9:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I just put morimoto LED fog lights on my 2015 and I like them so far. I made a thread in the lighting forum you can check out. You'll need a wiring harness and switch if you dont have any fog lights now. It can be done just will take a little work. You'll find some good info here in the lighting section.
    CHASDON[OP], NewImprovedRon and Sas like this.
  3. Aug 5, 2018 at 9:07 PM
    CHASDON
    2018 Tundra
    Thanks for the info.
  4. Aug 5, 2018 at 9:14 PM
    Pudge
    CT
    https://www.tundras.com/threads/whats-needed-to-install-fog-lights.28284/
    https://www.tundras.com/threads/201...o-fogs-and-fog-light-anytime-relay-mod.29530/
    There's a chance you have the wiring in place so check that you need a switch, relay, lights and a power source. I searched here for a write up but didnt find anything but I know it's been done. You can try googling adding fog lights
    I have my OEM 2015 lights and bezels I'd sell cheap if you're interested. But you'll still need more parts.
  5. Aug 5, 2018 at 9:16 PM
    Pudge
    CT
  6. Aug 5, 2018 at 9:22 PM
    CHASDON
    2018 Tundra
    Great! And thanks again.
  7. Aug 5, 2018 at 9:22 PM
    Pudge
    CT
  8. Aug 5, 2018 at 9:23 PM
    Pudge
    CT
    No problem. Hope you get this figured out
    CHASDON[QUOTED][OP] likes this.
  9. Aug 6, 2018 at 4:52 AM
    Cfincke
    San Antonio
    CHASDON[OP] likes this.
  10. Aug 6, 2018 at 4:54 AM
  11. Aug 6, 2018 at 4:56 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  12. Aug 6, 2018 at 7:57 AM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    Currently switched out mine to Squardon Pros, & they are bright. Highly recommended @Baja Designs. You can also try their Sports.
  13. Aug 6, 2018 at 7:59 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    We'd love to set you up with one of our Fog Pocket Kits!
    These won't be 100% plug and play since your vehicle isn't equipped with OEM fogs. I'd recommend picking up this harness instead:
    https://www.bajadesigns.com/products/squadron-s2-wire-harness-2-lights-max-150-watts.asp
    Let me know if you have questions or email info@bajadesigns.com
    Baja Designs
    www.bajadesigns.com
    CHASDON[QUOTED][OP] and Pudge like this.
