Advice on Suspension Selection
Discussion in 'Suspension' started by cain0725, Mar 27, 2021.
  1. May 8, 2021 at 6:22 AM
    #61
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    They’ll likely just reuse the top hat from your originals.
    I would ask and just buy new top hats if they aren’t assembled so you have fresh bushings and keeps your originals intact if you want to keep them.
  2. May 8, 2021 at 7:10 AM
    #62
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    The truck has 112,000 Miles on it, so unlikely I want to hang onto the old parts?
    I can see the reason for the fresh bushings.
    Would the top caps be Toyota replacement parts?
    SPP
  3. May 8, 2021 at 8:15 AM
    #63
    cain0725
    cain0725 [OP] New Member
    unknown, but i just had mine put on and it came with new too hats, was a little extra. I am at the 2.5 setting. 1.9 would have cleared tires. But i did not want to chance it. running 295/60R20 Wildpeaks. Love the ride and feel of tire. Its the quietest AT3 tire i ever ran.
  4. May 8, 2021 at 8:16 AM
    #64
    cain0725
    Shocks i think would ride better at 1.9 on bumps. On road it drives great where it is at.
  5. May 8, 2021 at 8:21 AM
    #65
    Black
    You can go OEM I think they are like $75 each.
    I went with KYB for like $30 each and they are good quality.
  6. May 8, 2021 at 3:26 PM
    #66
    slowpokepete
    Peter
    Hillsdale, NY
    I am gonna stop by there Monday.
    What are the chances they can even get these parts I wonder...
    SPP
  7. May 8, 2021 at 3:35 PM
    #67
    Black
    If they can’t get a simple top hat be it OEM or aftermarket you certainly don’t want them working on your truck.
  8. May 8, 2021 at 6:01 PM
    #68
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    The KYB top hats are what most places use that sell the 6112s pre-assembled. They are perfectly fine for this application and should be readily available. Depending on where they're ordering them from they should be able to add them in the order.
    Your problem may be availability. The 6112s are out of stock everywhere and no real ETA. If you can wait several weeks or even months then you're good. If you want to get something on sooner you may want to look at other options in that general category.
  9. May 8, 2021 at 6:37 PM
    #69
    cain0725
    shock surplus is where i got mine, enter your email and be ready to buy. Had mine ordered within a week, took another to get to my door.
  10. May 9, 2021 at 4:43 AM
    #70
    slowpokepete
    Peter
    Hillsdale, NY
    Actually I was referring to the 6112's...
    SPP
  11. May 9, 2021 at 4:45 AM
    #71
    slowpokepete
    Peter
    Hillsdale, NY
    Yeah, I'm just not sure how the shop will feel if I show up with my own parts...
    If they can't get them from wherever they source parts, maybe I will suggest shock surplus, but again, not sure how they will feel about that.
    I imagine they expect to make money on supplying the parts.
    SPP
  12. May 9, 2021 at 5:47 AM
    #72
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I wouldn't really worry about that. They make their money off labor.
    With that said I just installed the Eibach stage 2's Friday. Took about 4 hrs total (3 on drivers side and 1 on passenger). It's really easy install once you succumb to loosening the camber bolts (you'll need an alignment whether you loosen them or not).
  13. May 9, 2021 at 6:11 AM
    #73
    slowpokepete
    Peter
    Hillsdale, NY
    I wish I felt confident doing this kind of work myself, believe me.
    I felt pretty good about installing the GoRhino running boards myself.
    That said, anybody local who wants to tackle the project with me, hit me up lol.
    I'll definitely ask my shop about providing the parts myself if they can't seem to get them.
    SPP
  14. May 9, 2021 at 6:19 AM
    #74
    Black
    Just as easy not loosening the camber bolts.
    Fronts were cake.
    I had a seized nut on a rear shock. That took forever not much room to work up too there.
    Need to get a nut splitter after that fiasco that probably would have solved the issue in short order. Getting a cutting wheel up there without damaging the wheel well liner was fun.
  15. May 9, 2021 at 9:29 AM
    #75
    Djone27
    Djone27 New Member
    I've read that several times. Just wasn't true in my case. Bent a pry bar trying to get the LCA far enough down to fit the longer shocks. Since the geometry is changing with the lift, it didnt make since to continue to fight it.
  16. May 9, 2021 at 11:03 AM
    #76
    Black
    Ahh, yes the pry bar method.
    Should have gone with the couple of double cheese burgers for lunch then stand in the lower control arm.
    Makes plenty of room for the longer shocks.
  17. May 9, 2021 at 8:35 PM
    #77
    OnespeedTRD
    Don
    San Diego
    Most shops are OK with you bringing your own parts, especially if they can't get them themselves.
    If they can't get the Bilsteins in a reasonable amount of time, see what they can get.
    Like @Djone27, I'm running the Eibach Coilover 2.0 Stage 2 kit and very happy with them. Equal to the Bilsteins in build quality and ride, plus fully adjustable coilovers. Should be easily sourced straight from Eibach, and about the same or maybe even a little less than the Bilsteins.
    slowpokepete[QUOTED] likes this.
  18. May 18, 2021 at 3:35 PM
    #78
    slowpokepete
    Peter
    Hillsdale, NY
    So my local shop received the 6112's, confirmed that I will be getting new top caps...
    Now I need to decide on whether to go with middle or top setting.
    SPP
  19. May 18, 2021 at 3:46 PM
    #79
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  20. May 18, 2021 at 10:32 PM
    #80
    cain0725
    i went top, is stiff at certain bumps, gonna lower to 1.9 setting or switch to fox 2.5 and tuned through acutune.
  21. May 19, 2021 at 3:46 AM
    #81
    slowpokepete
    Peter
    Hillsdale, NY
    I am thinking either 1.3" or 1.9"
    Probably leaning towards 1.3"
    SPP
  22. May 19, 2021 at 9:21 AM
    #82
    cain0725
    lower = smoother
  23. May 19, 2021 at 11:31 AM
    #83
    slowpokepete
    Peter
    Hillsdale, NY
    That's what I wanted to hear.
    SPP
  24. May 25, 2021 at 3:06 PM
    #84
    slowpokepete
    Peter
    Hillsdale, NY
    Just got my Tundra back...6112's installed at 1.3", seems almost level to me.
    SPP
  25. May 25, 2021 at 4:10 PM
    #85
    OnespeedTRD
    Don
    San Diego
    Pics?
    Barrett50 likes this.
  26. May 26, 2021 at 4:50 AM
    #86
    slowpokepete
    Peter
    Hillsdale, NY
