Advice on Suspension Selection
Discussion in 'Suspension' started by cain0725, Mar 27, 2021.
  1. Mar 28, 2021 at 3:36 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Haha, damn cats!
    I hear you on the spending thing, but I just sold two AMGs and a GTI, and my Stumpjumper is as dialed as can be, so the truck is the beneficiary of those freed up expenses.
    The Fox 2.0s would be fine, if you can find them. About the only thing you can get right now in the lower price range is the Bilsteins, until they run out, or the Eibachs, until they run out.
  2. Mar 28, 2021 at 3:39 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I don’t know what you’ll find in stock but there’s tons of info on the 6112 and 5160 combo. They are coil over not spacer lift and they’re usually used with about 2 inches of lift
  3. Mar 28, 2021 at 3:40 PM
    eick
    eick New Member
    Also don’t rule out ome and dobinsons and Ironman foam cells.
    But stick to the shorter coils because apparently the 3 inch lift coils give more people like 5 inches
  4. Mar 28, 2021 at 3:41 PM
    OnespeedTRD
    Don
    San Diego
    The Bilstein 6112s and 5100s are semi adjustable. They have grooves with a circlip that holds the lower perch in place at 4 different settings. You can reuse the stock spring or get a new one with the kit prebuilt with a new top hat. Most Tundras experience a driver's side lean, especially when swapping to aftermarket suspension, so most folks throw a 1/4" spacer on the driver's side to even it out. The Eibach 2.0s are a true coilover, and can be adjusted to account for the lean.
    A 2" lift/level and going up to a 275/70/18 tire will net you about 3" total increase in the front and 1" in the rear.
  5. Mar 28, 2021 at 3:54 PM
    Semper Fi
    eick[QUOTED] and Saltyhero13 like this.
  6. Mar 28, 2021 at 4:21 PM
    cain0725
    cain0725 [OP] New Member
    anyone on here have a link to somewhere to get the 6100 ? Will that package be all i need?
  7. Mar 28, 2021 at 4:22 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Falcon all day long!
    Had Fox 2.0s and Bilstein in the past. The Falcons provide a far better ride.
    bkdelux, Skew12 and akmerle like this.
  8. Mar 28, 2021 at 8:33 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Here are the eibach 2.0’s $850
    https://www.stage3motorsports.com/e86-82-067-01-20-07-20-tundra-eibach-20-front-coilovers-0-25-lift.html
    Bilstein 6112 seems pretty back ordered, I got mine a few weeks ago and in that time have gone back out of stock.
    Old Man Emu 612 coils and nitro charger struts assembled coil overs $681 Toytec/Eibach assembled coil overs 2” or 3” lift $512 Lots of other options and rear options to go along but those are easier to find in stock than the front options. A few of the above options have been out of stock a while so might be limited stock
    Black Wolf likes this.
  9. Mar 28, 2021 at 8:52 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Congrats on the truck, Id be happy to help go over options with you. Feel free to call in and will give you a hand. David 801.635.4872
    https://shopcoachbuilder.com
  10. Mar 28, 2021 at 9:31 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I have kings front and rear regular 2.5's no adjusters, I'm very happy with them and I had them rebuilt after 4 years because 1 rear shock was leaking due to my abuse and not having shock boots to protect the shafts, lesson learned there. They ride smooth and plush on the pavement, off-road at high speeds it is so comfortable and makes me want to go faster.
    jeremyd likes this.
  11. Mar 29, 2021 at 4:20 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Horses. We also used to bang rocks together to start a fire but we have lighters now.
  12. Mar 29, 2021 at 5:18 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
  13. Mar 29, 2021 at 5:24 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    I think the main difference is the $850 ones are fully adjustable with a threaded sleeve for more incremental and easier changes in ride height. The $512 setup has about 4 height levels or notches to choose from. I would guess very similar ride quality and feel so it comes down to budget and how easily you might want to change the lift height.
    edit: the $512 ones you choose 2” or 3” of lift height and could add CB shims for .5” increments of lift to address drivers side lean etc.
    slowpokepete likes this.
  14. Mar 29, 2021 at 6:12 AM
    Black
    The 2.0s also use a larger shock body.
    Rodtheviking likes this.
  15. Mar 29, 2021 at 1:13 PM
    cain0725
    how will the bilstein 6100 compare to the fox 2.0 ?
  16. Mar 29, 2021 at 1:25 PM
    mtb-sam
    mtb-sam New Member
    I have been very pleased with my 6112 on the 1.3" setting.
  17. Mar 29, 2021 at 1:46 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    The bilstein 6112 is a larger body strut and on these heavy trucks I believe it provides better damping and control over the fox 2.0. I personally prefer the simple replacement style strut like the bilstein over the “rebuild” style of the fox.
  18. Mar 29, 2021 at 7:59 PM
    cain0725
    Thanks, i think thats what i will go with on the front. what about the back
  19. Mar 29, 2021 at 8:51 PM
    #49
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    I’ve only had old man emu nitrocharger and bilstein 5160 shocks on the Tundra and both are good. A lot might depend on how much lift you are planning on in the rear. Most rear shocks for the tundra are 2.0 shock body including the 5160 so personally I think you could go with eibach or bilstein, OME, dobinsons etc and be pretty happy. Rear lift or staying stock?
  20. Mar 29, 2021 at 8:59 PM
    #50
    cain0725
    not sure what i need to do, i ran 295 nitto grapplers on my last truck. i dont want my tires sticking out a bunch or any trimming.
  21. Mar 30, 2021 at 10:30 AM
    #51
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    For the most part any tire larger than stock you will need to trim the skid plate “wings”. I had 4” of lift and only 1” taller tires and it rubbed the skid
  22. Mar 30, 2021 at 10:47 AM
    #52
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  23. Mar 30, 2021 at 11:50 AM
    #53
    slowpokepete
    Peter
    Hillsdale, NY
    I think I am between these and 6112's...definitely ditching the 5100 idea for the front.
    SPP
  24. Mar 30, 2021 at 1:19 PM
    #54
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    IMG_20210204_162637.jpg Fan of the Toytec aluma series lift. Glad I did, rides better than factory and alignment was dead on!! Good luck
  25. Mar 31, 2021 at 5:38 PM
    #55
    cain0725
    called a local place today and they recommended a bds 3/2 lift. spacer and blocks in rear. They would do something for dif drop. Said ride would stay the same with factory shocks. It seems to me it would ride worse. Any opinions are appreciated
  26. Mar 31, 2021 at 6:33 PM
    #56
    OnespeedTRD
    Don
    San Diego
    Spacers and blocks definitely won't ride the same as stock. It will ride harsher, you'll lose travel which could potentially bend or break the shocks, and at 3" front you'll more than likely need UCAs to get the alignment back in spec.
    That's a budget friendly appearance mod, but not necessarily a suspension upgrade.
  27. Mar 31, 2021 at 6:44 PM
    #57
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Yea don’t do it!! You will just fatigue the stock suspension quicker and not be happy with the ride and handling. If your paying for all the labor either way just get it done right the first time. Any of the suspension upgrades people here have recommended will be far better than spacer/block lift. Then your struts and shocks will be good to go for a while as well.
  28. Mar 31, 2021 at 11:13 PM
    #58
    cain0725
    what i thoguht, now i just need to figure out what to get! thanks
  29. Apr 1, 2021 at 6:40 AM
    #59
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
  30. May 8, 2021 at 6:06 AM
    #60
    slowpokepete
    Peter
    Hillsdale, NY
    Bumping this up with a question.
    So I got an estimate of about $1,300 for 6112's installed by my local shop, I think excluding alignment, which I think i will need.
    That estimate seems ok to me, so I told them to order them.
    I have no idea whether they will order them pre-assembled, or plan to assemble them at the shop.
    But I wonder about the "top cap" I think it is that Bilstein does not include with the 6112's?
    Do you think my shop is aware of this?
    Not quite sure if I am even calling it the right thing...I am going to stop by there next week, since I want to ask them about whether they an even get the shocks or how long a wait I am looking at, and want to ask about that "missing" part without sounding like an asshole.
    As always your expertise is greatly appreciated.
    SPP
