Advice on removing these bolts
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Jun 15, 2020.
  1. Jun 18, 2020 at 8:45 PM
    #91
    MS22
    MS22 New Member
    02 Tundra 4x4
    Hope these pics help.
    1st pic you can see the bottom of the rear driveshaft U joint that connects to the CB is about in the 5 o'clock position.
    2nd pic is the rear drive shaft to axle. The bottom of the U joint is in about the 5 o'clock position.
  2. Jun 19, 2020 at 4:58 AM
    #92
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Thank you will do.
  3. Jun 19, 2020 at 5:01 AM
    #93
    Pucks18
    Thanks i will check. I never took off any of the ujoints for this job, so i dont see why they would he in a different position than what they were before. Will check though
  4. Jun 19, 2020 at 5:59 AM
    #94
    Pucks18
    Plan for today- come home from work, take out the new csb bearing, put back in my old one, drive and see if my new problem goes away. If it does, i will either bite the bullet and by the toyota one for 280 because i cant confirm if any of the other spicer ones are ACTUALLY for my truck. OR i will buy a cheap dorman one and pray it lasts a year at least.
    MS22 likes this.
  5. Jun 19, 2020 at 7:56 AM
    #95
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  6. Jun 19, 2020 at 8:01 AM
    #96
    Pucks18
    Ooo that washer aint that important ;)
  7. Jun 19, 2020 at 3:24 PM
    #97
    Pucks18
    My joints are not lined up like that. But i doubt thats the problem as they have most likely been like that since ive got the truck before this new problem.. and i put the old bearing back on and same problem..
  8. Jun 19, 2020 at 3:25 PM
    #98
    Professional Hand Model
    Hand Protectors
  9. Jun 19, 2020 at 3:28 PM
    #99
    Pucks18
    ACTUALLY now that i remember right. When doing the job the first time my slope yoke pulled out a little and twisted.. can i line up the u joints just by looking at it with my eyes?
  10. Jun 19, 2020 at 3:39 PM
    #100
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yes.
  11. Jun 19, 2020 at 4:17 PM
    #101
    Pucks18
    @empty_lord how do i line them back up? I dropped the shaft and pulled the shaft back from yoke but i cant twist the shaft and line them up. Do i need to dissasemble the joint?
  12. Jun 19, 2020 at 4:17 PM
    #102
    Pucks18
    How do you line them back up?
  13. Jun 19, 2020 at 4:29 PM
    #103
    Pucks18
    Nvrm, just pulled the shaft from the slip yoke. Didnt know u could do that!
    MS22 likes this.
  14. Jun 19, 2020 at 4:38 PM
    #104
    Hand Protectors
    I’d love to see a pic of this. Can you post one?
    MS22 likes this.
  15. Jun 19, 2020 at 4:39 PM
    #105
    Hand Protectors
    This pic would show us the inner workings of where all the Slip Joint grease pumps disappear. We need a pic!
  16. Jun 19, 2020 at 4:40 PM
    #106
    empty_lord
    05 rollover special
    its just a bunch of splines.
  17. Jun 19, 2020 at 4:41 PM
    #107
    Hand Protectors
    :worthless:
  18. Jun 19, 2020 at 4:42 PM
    #108
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I marked my flanges and marked the flange to spline, just so the mojo was exactly the same when it put it back.
  19. Jun 19, 2020 at 4:43 PM
    #109
    Hand Protectors
    Mojo is important. Often overlooked and rarely understood.
  20. Jun 19, 2020 at 4:54 PM
    #110
    FrenchToasty
    Mo
    Bone stock
    I don’t have a full grasp on the entire workings, but I’ve got a good idea, and I respect the Mo and the Jo; Separately And together
  21. Jun 19, 2020 at 5:59 PM
    #111
    Hand Protectors
    Its like Yin and Yang but at a Black Belt Level.
  22. Jun 19, 2020 at 6:40 PM
    #112
    Hand Protectors
    I bought this one off Big Gurrl for about $120? a while back.
  23. Jun 19, 2020 at 7:44 PM
    #113
    Pucks18
    Sorry no pic. It did not fix my issue. Drove my truck on the highway for a few miles at 70-80mph just to make sure the truck is still driveable and "safe". Still kinda frustrated.. she will see the mechanic the 29th. I wish we could post videos and audio on here so u guys could hear what I'm talking about at least
  24. Jun 19, 2020 at 8:03 PM
    #114
    MS22
    MS22 New Member
    02 Tundra 4x4
    Can you move the rear driveshaft by hand? Maybe a bad U joint somewhere.
  25. Jun 19, 2020 at 8:16 PM
    #115
    AZTundra
    Paul
    Phoenix, AZ
    You can do video/audio. You'll need to create on youtube then attach the link here.
    MS22 likes this.
  26. Jun 19, 2020 at 8:35 PM
    #116
    Pucks18
    Nope. All nice n tight. It sounds like a bad bearing or something. I hope its me diff so i have an excuse to just get it rebuilt already as i already have a noisey pinion bearing.
    AZTundra likes this.
  27. Jun 19, 2020 at 8:36 PM
    #117
    Pucks18
    Its basically a bunch of splines. I longer and skimnier version of the splines coming out of the carrier bearing basically
  28. Jun 19, 2020 at 8:38 PM
    #118
    Pucks18
    Its just interesting cause its most noticeable at 45-48 mph. And when i give it more throttle to apply more torque (basically at the point in my powerband where the rpms stay the same but u can feel more torque being applied, its right after my o/d kicks in) thats when the sound gets real deep and rhythmic
  29. Jun 20, 2020 at 5:53 AM
    #119
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hmmm, that may not be your bearings. That sound is constant and just increases linear to vehicle speed.
  30. Jun 20, 2020 at 6:08 AM
    #120
    Hand Protectors
    What about the other shaft. Is it hollow? All the way up to the other end?
