Advice on redoing walls in kitchen
Discussion in 'Home Improvement' started by Kung, Apr 2, 2021.
  1. Apr 3, 2021 at 1:16 PM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    Yeah, I read somewhere where we can soak the wallpaper with whatever we're going to use, and then tape some plastic sheeting to the wall and let it sit for a few hours to essentially force it to soak in. I'll likely plan for sheetrocking, but try that first, and if it works, woohoo! If not, at least I'm prepared.
  2. Apr 3, 2021 at 1:20 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Yea with that kilz IF it's going to come off you will know as it will bubble when the kilz dries. If it doesn't should be solid and sealed enough with the kilz to do what you need to do.
    Kung[OP] likes this.
  3. Apr 4, 2021 at 5:10 AM
    Slayer
    Slayer Member
    Slayer
    stick with this plan.
    It's wise when doing a major renovation like a kitchen or bath to 'gut it' & start fresh
    You can remove all of the drywall in a room in 30 minutes.
    10TundraSR5 likes this.
  4. Apr 5, 2021 at 7:17 AM
    bwh
    bwh New Member
    Unless you remove the drywall to find nearly an inch of plaster and metal lathe underneath... then it becomes an entire day trying to remove that shit. Yes, 1/2 drywall ON TOP of 3/4 of plaster. Which in the bathroom was all behind terrible Pink tile and an INCH of thinset/mortar.
    It haunts me still.
  5. Apr 6, 2021 at 1:42 PM
    Kung
    KG, VA
    Mother of God. O_O
    Thankfully, yeah, we just have sheetrock on top of studs, although what they attached to the sheetrock is often attached with Liquid Nails and the like. LOL
  6. Apr 6, 2021 at 3:59 PM
    Wahayes
    Will
    2017 tundra limited
    Is it an older house? I'm wondering if maybe it had paneling liquid nails to the rock and then at some point someone tore it down and half assed some wallpaper
  7. Apr 6, 2021 at 4:01 PM
    bwh
    bwh New Member
    Liquid nails is rather status quo in many tract homes. The consensus among those cheap grade builders (or subcontractors) is that it helps alleviate nail pops down the line. I've seen a lot of homes that are poorly glued like that, tact in with a few nails, and then fully fastened later with screws. Three types of fasteners is insane to me.
    The glue is often curing before the screws come in, so it adds to a pretty wavy looking wall.
  8. Apr 6, 2021 at 4:33 PM
    Kung
    KG, VA
    ....but it shouldn't be status quo for wallpaper. (Yes, wallpaper. Yes, I'm serious.)
    It was built in 1981...my guess is that whoever built it used it because they had it on hand, and that was that. LOL
