Advice for new to me Tundra.
Discussion in '1st Gen Tundras (2000-2006)' started by TheJthunder45, Sep 4, 2024.
  1. Sep 4, 2024 at 4:18 PM
    TheJthunder45
    TheJthunder45 [OP] New Member
    2002 Black Tundra SR5
    This is a long one. About a month ago I bought an 02 Tundra SR5. I dig the truck alot and I took it to get new fluids in to start fresh. I eventually went to a Toyota Dealer and got the lower ball joints replaced (as I did not see them being replaced mentioned in its history) to assure I was getting OEM. This was a Saturday. About 4 days later (Wednesday) I got new tires. 2 days after that, (Fri) I noticed that my truck would pull to the right everytime I stepped on the brakes. Next day, I took it to a shop I normally go to. They tell me it looks like it could be the tire rod and I approve the repair. About an hour or two later, they tell me upon further inspection the issue is actually the right lower ball joint and that it looks to be a defective part. I tell them I got it done at a Toyota Dealership and they advise me to take it back to see if they can check it out and get it replaced. It's now been 4 days since then, Toyota has called me back saying that the joint seems to be intact and shows no issues but that my brake fluid is extremely dirty and after a flush still is dirty and has affected my brake master cylinder. I feel a bit sceptacle about that and just overall feel concern as I know how catastrophic of a fail the Lower ball Joints can be if defective or neglected. Just feels like I'm getting alot of different opinions left and right and would appreciate if anyone knows anything regarding all this. Could the braked fluid and Master cylinder be the problem with the pulling or should I still have concern over the Ball Joints despite being assured the are okay. Thank you.
  2. Sep 4, 2024 at 4:37 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    It pulls to the right everytime you stop on the brakes, but doesn't pull that way when regularly driving correct?
    I'm thinking you have a warped brake rotor that needs replacing. Had the same issue in the past on a tacoma and that fixed it for me.
  3. Sep 4, 2024 at 5:10 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Please read the whole gen 1 bible sticky. Obviously you already have good handle on the lbjs since you went oem
    best advice, since you’re already on your second opinion, is to google around and see if there’s an independent Toyota speciality shop in your area that ONLY work on Toyotas. They’re pretty common in larger metro areas. Get a third opinion from there.
    my guess with a pull under braking scenario is something in your brake system is amiss, seized caliper or otherwise. You should probably get a brake fluid flush regardless.
    jerryallday likes this.
  4. Sep 4, 2024 at 7:22 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Sep 4, 2024 at 7:31 PM
    Welcome from NY.
  6. Sep 5, 2024 at 1:50 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I'll take frozen brake caliper for $400 Alex...
    NickB_01TRD and shifty` like this.
