Adjusting KING front coil overs for Tundra lean
Discussion in 'Suspension' started by TheBeast, Feb 2, 2018.
  1. Feb 2, 2018 at 7:56 PM
    Vizsla
    Vizsla 2 = 2.5
    Yours will be very difficult without compressing the coil. You have 600lb springs requiring more preload. All Tundras have some lean even new. Full tank of gas average in my experience is 3/8”. Sticking to that I would guess 4 turns with 600lb springs, 3 with 700lb springs.
  2. Feb 2, 2018 at 8:03 PM
    TheBeast [OP] The Beach
    thanks. yes that's what we did. 4 full turns and yes 600 lbs springs.
  3. Feb 2, 2018 at 8:12 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Damn man that sucks! I just remembered you saying something about you not liking to modify tow rigs, so I was curious if the bug bit ya or something.
  4. Feb 2, 2018 at 8:34 PM
    Filthy13
    Filthy13 New Member
    NorCal
    2017 White 1794 TRD OR
    A few goodies
    My mechanic bent the crap out of my spanner wrench making adjustments. He was able to manage. I have a little over two additional threads showing on the drivers side to eliminate the lean.
    TheBeast[QUOTED][OP] likes this.
  5. Feb 2, 2018 at 8:44 PM
    I don’t like modding tow rigs or lifts and such. 20’s actually tow better. Less sidewall roll. The 20’s are not any taller, but noticeably heavier.
    Filthy13 and zcarpenter92 like this.
  6. Feb 2, 2018 at 9:01 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  7. Feb 2, 2018 at 9:04 PM
    and where would someone find such a tool ? ;)
    Filthy13 and ColoradoTJ like this.
  8. Feb 2, 2018 at 9:07 PM
    Baja Mike
    South Bay, Ca.
  9. Feb 3, 2018 at 6:45 AM
    n2deep
    n2deep Pavement Princess
    That is the tool I have and also a correct size punch. Tough to bend those. I adjusted mine with more preload and didn't have a problem. I am LT so my turns will be different and don't know what they are set at. Just weird cause I didnt have any problems adjusting when I was MT either. I think I used a CB shim on the driver's side
    040Tundra likes this.
  10. Feb 3, 2018 at 7:50 AM
    Vizsla
    Vizsla 2 = 2.5
    I have a few of these. They are little to no help adjusting on the truck, just not enough clearance.
  11. Feb 3, 2018 at 9:43 AM
    thanks guys. I'll see where I'm at after suspension settle and alignment.
    then maybe I'll look into a single CB shim driver side.
    I had to correct the 3/4", that was too much. But I can live with 1/4" lean ..lol
    Filthy13 likes this.
  12. Feb 3, 2018 at 2:03 PM
    n2deep
    Yeah I use that spanner and a punch together due to limited space.
  13. Feb 3, 2018 at 2:16 PM
    Filthy13
    Filthy13 New Member
    NorCal
    A few goodies
  14. Feb 5, 2018 at 2:49 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    Man i was dead set on getting Kings next month until i saw this. Kinda defeats the purpose of having coilovers almost if you can't adjust them on the truck. i never had a issue with the icons on my Tacoma once jacked off the ground. Might have to think about Fox or Icon now.
  15. Feb 5, 2018 at 3:59 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Yea I was not impressed, I put Fox's on my Tacoma and they were easy to adjust on the truck. I struggled hard with the Kings and had to borrow a spring compressor to adjust them. Luckily I tried to adjust them before even getting them on the truck so i got them to where people recommended before even putting them on the truck.
    TheBeast[OP] likes this.
  16. Feb 5, 2018 at 4:00 PM
    Vizsla
    Vizsla 2 = 2.5
    Don’t be, they are all the same basic thing. And all can be adjusted on the vehicle. The manufacturer is going to tell you the best way for the worst case scenario adjustment. If you want Kings read the thread and get them from the vendors mentioned in this thread that pre-set them(they give you other choices as well). That will give you the best results, you like Kings, you will get them set/spring rate/valved exactly for you, and have a shop standing behind it if there is a problem. The price, nothing but a little patience. Hope this helps.
    Filthy13 and TheBeast[OP] like this.
  17. Feb 5, 2018 at 4:02 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    Agreed once on the truck they are great, I don't really plan on doing much if any changes down the road.
  18. Feb 5, 2018 at 4:03 PM
    Vizsla
    Vizsla 2 = 2.5
    Fox has switched, they use the same basic design as King now. Same struggle.
  19. Feb 5, 2018 at 6:43 PM
    #49
    thanks for the link. Yes we had the truck on the lift.
  20. Feb 6, 2018 at 6:30 AM
    #50
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    Which vendors preset them besides Down South Motor Sports (Wheelers Offroad , SDHQ ??) ? Do they charge extra to do it ? I went to Down South Motor Sports last night and looked at the Kings and their prices are the same as Wheelers, but there is a option for lifted trucks, and if you click that it's $200 more. Is that for extended travel or something , and not just say adjusting to 2.5" to 2.75" of lift (to avoid uca's and clear 285/75/17) ?
    I would rather get King or Icon, than fox cause i have read about Finnish issues on the fox, and them being stiffer (to some at least).
  21. Feb 6, 2018 at 7:23 AM
    #51
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    hmm. interesting thread. i just put on my kings how i got them from sdhq. i do think i need to adjust them a bit as on bigger hits, the front tires will rub the wheel wells. that being said, i don't seem to have this lean you're talking about.
    040Tundra and TheBeast[OP] like this.
  22. Feb 6, 2018 at 9:03 AM
    #52
    filthy motorsports as well.
  23. Feb 6, 2018 at 9:07 AM
    #53
    "bro lean"..only found in California :D..you left too early
    smslavin[QUOTED] likes this.
  24. Feb 6, 2018 at 9:09 AM
    #54
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    whew. that's a load off. thanks for clarifying.
  25. Feb 6, 2018 at 9:09 AM
    #55
    the lifted ones are for the big brackets lifts: 5" + I htink
  26. Feb 6, 2018 at 9:10 AM
    #56
    seriously though, your truck is already highly modified so it's possible it's compensating some of the weight with everything you added or SDHQ sent them already corrected. count the # of threads showing on each side.
  27. Feb 6, 2018 at 9:14 AM
    #57
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    sarcasm aside, totally get it. front springs are 700s, deavers are 600. drawers, topper and skids probably balanced it out a bit. i'll give the threads a count. guessing i need to crank them down another 3-4 threads and gain another inch.
    dcsleeper408 likes this.
  28. Feb 6, 2018 at 9:19 AM
    #58
    per KING instructions, 5 threads is 1 inch.
    you also have 700 lbs springs so it might be easier for you to crank them per @Vizsla
    smslavin likes this.
  29. Feb 6, 2018 at 9:21 AM
    #59
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    whew, finally, something to do on the truck with a wrench. i was going through withdrawals. as long as i'm under there, i might as well install the wireless winch controller too...
  30. Feb 6, 2018 at 9:30 AM
    #60
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    K, i figured it had to be something like that, or something outside the normal.
    will give them a call, i am not going to order for a month or so. i am an accountant, and have no time to mess with installing them until after tax season.
    i did want to have them by 4/15 cause that was going to be my after tax season project.
