Adding Led lights under step bars but not turning off when closing doors
Discussion in 'Lighting' started by Toshito, Feb 25, 2020.
  1. Mar 7, 2020 at 7:47 AM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    That would be great. I see a few options. But wanted to see how others did it. Thanks guys!
    Toshito[QUOTED][OP] likes this.
  2. Mar 7, 2020 at 2:59 PM
    Toshito
    Toshito [OP] New Member
    2017 Red Tundra Limited
    Here it goes how I did mine. As you can see on the pictures it also shows where I installed my ground and what wire I used to get power. Hope this helps. 20200307_174852.jpg 20200307_174911.jpg 20200307_174937.jpg
    Rengawt, Bob_Wiley, focal and 3 others like this.
  3. Mar 7, 2020 at 5:15 PM
    SiberianTundra
    Greg
    War Machine
    interesting you chose to place a fuse. You think 5 or 10 should be enough ? I most likely will run it same location.
  4. Mar 7, 2020 at 5:44 PM
    Toshito
    I used the same fuse the led kit brought. At least 10 I would use.
  5. Mar 7, 2020 at 6:49 PM
    SiberianTundra
    Greg
    War Machine
    Got it. Thank you again! Very helpful. I think for the other side of the truck I will run inside the cabin and out the other side of the drain. I figured it would be harder running wires under the truck with exhaust and drive shaft in the way.
  6. Mar 7, 2020 at 8:41 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You'll find that grommet on both sides of the front floorboard.
    Just run your wire under the carpet, thru the console and back under the carpet.
    You can get the console top off with trim tools, no screws to remove..
  7. Mar 7, 2020 at 8:57 PM
    SiberianTundra
    Greg
    War Machine
    Thank you! Oh yea I had console off a few times before
  8. Mar 7, 2020 at 9:33 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Me too..:D
    523DED9D-32A5-4DC2-AA57-E852E359D7BB_zps_73ea1a999024d6b7854503f9287ca46fa138168a.jpg
    638DCE44-F47A-440E-998C-AD18A99A9987_zps_c43b83fecc75e4dfdaca051bb4d7d60549739959.jpg
    088AE31E-2D15-484B-8E40-0CC492301A20_zps_b4ab4dd4f8ae9aaef29508592f66bf0ac75155f5.jpg
    47332915-4D32-4748-BED7-CDC3C5B5250B_zps_95c75428d1370e9538f6492231694d5f2f872218.jpg
  9. Mar 8, 2020 at 9:26 AM
    SiberianTundra
    Greg
    War Machine
    I will check mine. But as I recall it is 10 amp. Could be wrong I will double check.
  10. Mar 8, 2020 at 6:24 PM
    SiberianTundra
    Greg
    War Machine
    I actually installed lights. But did not add the fuse in line. Actually forgot until after I was done with install. I will add it later.
    Thank you for all the help guys. Worked out great!
    Pictures coming soon
    NewImprovedRon likes this.
  11. Mar 8, 2020 at 8:43 PM
    SiberianTundra
    Greg
    War Machine
  12. Mar 9, 2020 at 4:57 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    I’m like the Amber
  13. Mar 9, 2020 at 8:37 AM
    SiberianTundra
    Greg
    War Machine
  14. Mar 9, 2020 at 6:42 PM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
  15. Mar 28, 2020 at 7:18 AM
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Thanks guys for all the tips and pictures as i finally finished my step lights. Had some old led lights i had once intended to hook up in the rear and are now my step lights.
    A couple things that might help someone else out. I have a 16 and there were no pink wires so i started looking for a grayish one. I only had one and it was not it. It was more brownish/black and the wire was thin. Also I didn't realize i had to take out my seats to pull the carpet back so I could access the floor plugs to run my wire through. Not a huge deal but more time consuming than i originally thought.
    All in all they turned out great but I'm not real impressed with my choice of lights. At least all my wiring is there if i want to change them out later.
    SiberianTundra likes this.
  16. Mar 28, 2020 at 8:45 AM
    SiberianTundra
    Greg
    War Machine
    I did not pull my seats. I just pulled carpet back a bit and ran the wires to the plugs. I did not even cut the plugs. Wires I used were so small that plugs fit snug tight around it with no problem. I guess depends on the plugs you chose to run from.
  17. Mar 28, 2020 at 8:18 PM
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Man that carpet is stiff. Plus I ran the wire from the opposite side under the carpet and it just made it easier, i guess, to move the carpet back. I wasn't sure where the plugs were, but they right next to where you need them. The plugs come out real easy and i just punched a small hole through it with an ice pick and shoved the wire through. Seals back up tight. Anyways sounds like there’s more than one way to skin a cat. Lol.
  18. Mar 28, 2020 at 8:23 PM
    SiberianTundra
    Greg
    War Machine
    All good. You did it right for sure. I was lazy and snaked the wires under the carpet.
  19. Mar 28, 2020 at 8:43 PM
    #49
    TTund16
    TTund16 New Member
  20. May 28, 2020 at 12:50 AM
    #50
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I need to do this!
  21. Nov 24, 2021 at 6:05 PM
    #51
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Hi I’m thinking of getting these VLED strip bars for my side step area too but I was wondering if you used any of the adapters the strip bars come with? Did you just wire it to the cargo light wire? I’ll be looking into how to properly do this for my 07 Tundra but I would like to know if I need adapters or electrical wires
  22. Nov 30, 2021 at 4:10 PM
    #52
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Curious... I am planning to do something like this based off the VLEDs setup and then strips on the outside. Should I put some inline fuses into the external strips so if they get wet and blow a fuse it would be before all my interior lighting?
  23. Dec 1, 2021 at 4:58 AM
    #53
    DerfM
    South Dakota
    2021 TRD Pro MBM
    Thanks, that was kinda my plan but just wanted someone to help verify that it makes sense.
