Adding Led lights under step bars but not turning off when closing doors
Discussion in 'Lighting' started by Toshito, Feb 25, 2020.
  1. Feb 25, 2020 at 6:10 PM
    Toshito
    Toshito [OP] New Member
    2017 Red Tundra Limited
    Hello everyone,
    NEED HELP. Maybe someone already went through this and can Help me. I installed additional Led strip under the step bars so when I open the doors I have more light. I tapped to the existing led pods but when I connected the ground the light stays on. It does not turn off when I close the doors. Is there a special way of wiring the leds so it turns off as all the other lights on the truck? Please help if any anyone has done this mode. Pictures, instructions or anything that can help. Thanks in advance boy and girls.
  2. Feb 26, 2020 at 8:52 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Maybe your wires are crossed?
    I have a switch and originally the switch light was always on, even when I turn off the car instead of when I actually turn on and off the switch. Turned out to be because I wired it wrong, swapped the wiring and now light only comes on when I press the switch.
    Or you wired it up to a constant power...maybe try wiring it up to the footwell light?
  3. Feb 26, 2020 at 10:00 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    I added strips under my truck to have them come on when the doors open or when I unlock it. I tapped into the cargo light wires under the driver side rear door trim. I don’t any pictures right now, but I can take some later today.
  4. Feb 26, 2020 at 12:51 PM
    Toshito
    I will try to do this today. Let's see how it goes. Thanks DRP82
    DRP82 likes this.
  5. Feb 26, 2020 at 5:36 PM
    biebs96
    PA
    If you tap into the driver side footwell light wires (you must connect both power and ground to this set of wires, because it seems to be on its own relay/circuit)
    The lights will fade on when the truck is shut off, before you open the door. And will fade on/off with locking unlocking the doors.
    https://youtu.be/Q5VmAUuNGnE
    Any questions let me know.
    RockWarrior2k10 and Mountun Goat like this.
  6. Feb 26, 2020 at 5:53 PM
    Toshito
    Thanks guys for the help. It was a success. Job is complete and working BEAUTIFUL.
    Next addition will be adding the Lund Bull Bar with the Led light bar but also adding another led light bar on the lower part of the bumper. Thanks again Guys.
    Sas and Bob_Wiley like this.
  7. Feb 26, 2020 at 6:50 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    @Toshito @biebs96 where did you get your LED strips from? Do you have a link?
  8. Feb 26, 2020 at 6:57 PM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    This is what I purchased and installed as courtesy lights.
    CLAUTOP LED Truck Bed Lights, 2PCS 60" White LED Truck Bed Light Strip Lamp Kit, Waterproof Lighting Bar Kit with on-Off Switch Fuse 2-Way Splitter Cable for RV SUV Vans Jeep Cargo Boats and More https://www.amazon.com/dp/B07CZSVMXS/ref=cm_sw_r_cp_api_i_T9YvEbZRVY3SN
  9. Feb 26, 2020 at 7:52 PM
    Toshito
    I got the same one as DRP82.
    MICTUNING 2Pcs 60 Inch White LED Cargo Truck Bed Light Strip Lamp Waterproof Lighting Kit with On-Off Switch Fuse 2-Way Splitter Cable for Jeep Pickup RV SUV and More https://www.amazon.com/dp/B01JUE9OLM/ref=cm_sw_r_em_apa_i_HYZvEbXKRCS17
    DRP82 and Bob_Wiley[QUOTED] like this.
  10. Feb 26, 2020 at 7:53 PM
    Toshito
    This is how it looks after installed.
  11. Feb 27, 2020 at 3:24 AM
    biebs96
    PA
  12. Feb 27, 2020 at 3:28 AM
    Toshito
  13. Feb 27, 2020 at 6:15 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I had some Baja Designs rock lights installed that are currently hooked up to my Switch Pros. I'd love to wire them into the interior or cargo lights so they illuminate when I unlock the truck but can also be controlled by my Switch Pros. Just haven't figured out how to do that yet.
    (the installer did a crappy job with the wiring...they will be fixing that)
    Rengawt and biebs96 like this.
  14. Feb 27, 2020 at 6:18 PM
    biebs96
    PA
    You can easily tap off of the interior footwell light and they will work as the video I previously posted. As far as also getting them to work on a switch at the same time that would require some constant 12v power and relay and switches.
  15. Feb 27, 2020 at 6:35 PM
    chrisbusnut
    Pasadena, CA
    Thanks. I don’t have stock footwell lights. I have some VLEDS ordered and will install those once I receive them. I need to find someone local who is good with wiring and knows switch pros. I’d prefer to pay someone who knows what they are doing to do it, and make it look professional.
  16. Feb 27, 2020 at 9:31 PM
    GSD
    GSD New Member
    Seattle, WA
    2019 Platinum Crewmax
    Is there a write-up/video out there for the running board light mod including running wires to cab and where to tap into? Did a search, didn't really see anything.
    Bob_Wiley likes this.
  17. Mar 3, 2020 at 2:06 PM
    Rengawt
    Rengawt New Member
    Tanner
    2010 Tundra Crewmax 4x4 Platinum
    Wanting to do this same kind of thing with some rock lights where they turn on when unlocking and such but can also operate them separately if anyone knows how to wire it that way. I know some from OPT7 have a feature to wire into the door open wiring at the same time so it must be possible with some additional wiring.
  18. Mar 3, 2020 at 6:32 PM
    Toshito
    It's very easy to wire it. You can tap the wire on the rear driver trim. See this thread and is very helpful. That is how I did mine.
    https://www.tundras.com/threads/wires-for-interior-lights.5987/
  19. Mar 4, 2020 at 4:01 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    ok so if I tap into the pink for positive in the driver side rear passenger. What wire do I use for negative. Black ?
  20. Mar 4, 2020 at 4:16 PM
    Professional Hand Model
    Hand Protectors
    Connected the flexible LED strip into the OEM courtesy lights wires with quick Tee connects. $10 for the strips and another $10 for a box of connectors. Took about 3 hours for both doors.
    Comes on with door opening. Turns off with door closing. Puts the light right where you want it.
  21. Mar 4, 2020 at 4:54 PM
    SiberianTundra
    Greg
    War Machine
    thats nice
  22. Mar 5, 2020 at 7:11 AM
    SiberianTundra
    Greg
    War Machine
    do you have a picture by any chance of your ground?
  23. Mar 5, 2020 at 8:25 AM
    SiberianTundra
    Greg
    War Machine
    That is awesome! Thank you very much! Good visual for me to use. I have so many LED strips and gadgets I got from Vleds that I have not yet used. This is my next wiring project.
    NewImprovedRon likes this.
  24. Mar 5, 2020 at 8:27 AM
    SiberianTundra
    Greg
    War Machine
    Ok now to look for a thin pink wire in driver passenger rear
  25. Mar 5, 2020 at 9:06 AM
    SiberianTundra
    Greg
    War Machine
    I have a basic poke light tester. I guess I just ground and look for hot wire by poking through the positap
  26. Mar 6, 2020 at 6:11 PM
    SiberianTundra
    Greg
    War Machine
    Ok found the wire now were to run it from cabin to below is next
    it was the large pink. Not pink skinny
    Pillslinger likes this.
  27. Mar 6, 2020 at 6:16 PM
    Toshito
    Make sure it turns off when you close the door. Press the pin switch and wait a few seconds and see if the tester bulb turns off. If it does you got it.
  28. Mar 6, 2020 at 7:18 PM
    SiberianTundra
    Greg
    War Machine
    Yes it does :)
    Toshito[QUOTED][OP] likes this.
  29. Mar 6, 2020 at 7:21 PM
    SiberianTundra
    Greg
    War Machine
    where did you guys run the wire to from cabin to outside ?
  30. Mar 7, 2020 at 7:37 AM
    Toshito
    Do not drill anywhere but the grommet that is close by to the trim.
    I can take a picture and send tomorrow how I did mine.
