Added H-Pipe and Resonators to TRD Exhaust
Discussion in 'Performance and Tuning' started by 17TundraDCEd, Jul 22, 2019.
  1. Aug 4, 2019 at 4:20 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Worked for me. Sounds good and i might have to stop at my local muffler shop and talk to them.
  2. Aug 4, 2019 at 7:34 AM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    RitcheyRch likes this.
  3. Aug 4, 2019 at 8:22 AM
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
  4. Aug 4, 2019 at 9:44 AM
    17TundraDCEd
    17TundraDCEd [OP] New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Cool. Glad it's working for you.
  5. Aug 4, 2019 at 9:47 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Happy to help.
    It’s always hit or miss with these videos. When I first heard them, I was surprised, because the exterior sound is louder than what I hear in the cab since adding the H pipe.
  6. Aug 6, 2019 at 8:06 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Did you receive the helmholtz resonators yet?
  7. Aug 6, 2019 at 8:23 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Hey Keith.
    I e-mailed you yesterday and you said they are shipping out Friday. I take that as this Friday, so I should have them next week since they are coming to the East Coast.
  8. Aug 22, 2019 at 10:34 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Update:
    The resonators were delivered yesterday, and my local exhaust shop installed them this morning before I went to work.
    Props to Keith - they fit perfectly. I had my doubts because that's a lot of pipe and angles to squeeze into a small area, but they went in without issue, and cleared everything just fine.
    Also props to my local exhaust guy. Tom Stack at Low Cost Exhaust in Fairless Hills PA (Bucks County). He did the H pipe a few weeks back and the resonators today (lined everything up and torched the hole so I didn't have to drop the tailpipes).
    I'm going to put the truck on ramps this weekend when I'm off and have some good daylight and take pictures or video from underneath so you can see the setup.
    For now, just some feedback. No need for video. With the H pipe and the dual resonators, the TRD sounds pretty much like OEM stock on the inside - maybe a little deeper in tone, but not by much. Nothing that video would ever pick up. The only exception is when you're heavy on the throttle, it has a little bit more than stock, but it's still very quiet on the inside. Again, nothing that video would ever capture. For comparison, I had Keith's standard 12 inch system with resonator on a previous Tundra, and the TRD with H pipe and dual resonators is quieter than the 12 inch system.
    This is not something I would recommend if you don't already have a TRD exhaust. It doesn't make sense to spend $1,100 and then spend more to make it quiet. In my case, my truck was a dealer demo/leftover with 700 miles that was discounted 20%. So I couldn't pass that deal up. But it came with the TRD exhaust. I tried it for about 6,000 miles. Loved the WOT throttle sound, but couldn't deal with the resonance at light throttle and cruising between 40 and 65 mph. I didn't want to go back to stock, because the TRD is a nice looking system, so I figured I would use the information and resources available on this forum to quiet it down. And it worked for me.
    I am a little curious how the TRD would sound/perform with just the dual resonators and no crossover. But, I have no plans to cut the H pipe out so I'll just have to be curious.....
    Hope this thread was useful. Images/video are forthcoming.
  9. Aug 22, 2019 at 10:41 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’m looking forward to seeing pictures and possibly hearing it a video of the change. This seems like the exact exhaust I want. I think when I’m ready to bite the bullet, I’ll get with Keith and see about him possibly making one of his TRD replacements just like this for me.
  10. Aug 22, 2019 at 11:31 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I posted some videos on the previous page with just the H pipe. I don't think the exterior sound is much different with the resonators added, it's just a lot quieter on the inside.
    If you want duals, I think the TRD replacement by Keith is the way to go. It's all packaged together ahead of the tailpipes - x pipe, resonators, mufflers.
    My setup is a little different, because I have the factory TRD system. The resonators are in the tailpipes between the rear differential and spare tire. And I added an H pipe crossover ahead of the mufflers versus the X that Keith uses.
  11. Aug 24, 2019 at 7:20 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    173732A4-0ABF-44AC-8E98-0171D4DF2E5C.jpg 5DFE91C2-9A12-44C6-B4BA-117A3BBACC3F.jpg 084E4A16-D457-4CB4-8202-94AC25120B3C.jpg 29795D26-A0F7-439C-B862-161C469DB88F.jpg 0FB6A9C1-3DE6-486F-8688-8E20DA63B021.jpg Posted pictures of the resonators and H pipe. For reference, the top resonator is bolted to the passenger side tailpipe and the bottom resonator to the driver’s side. The driver’s side does pitch down. They are stainless, but Keith offered to replace if I encounter any rusting issues a few years out due to water collection on the driver’s side. Honestly, I’m not too worried about it.
    Pbear1454 likes this.
  12. Sep 27, 2019 at 6:45 AM
    tps5150
    tps5150 New Member
    Hi Ed - can you share what exhaust shop you had the H Pipe done with. As I would like pursue and always cool to have seen the work done already by a good shop. Appreciate it.
  13. Sep 27, 2019 at 6:55 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Absolutely.
    Tom Stack
    Low Cost Exhaust
    45 Spencer Avenue, Fairless Hills PA 19030
    215-547-7470
  14. Jun 18, 2020 at 4:10 PM
    Tundra18ttags
    Tundra18ttags New Member
    2018 cement tundra offrd
    All, this mod H pipe helped me gain back bottom end and eliminate that choppy drone. Best mod made yet. TRD was all about sound and there was no gain performance what so ever. Our engines are less efficient going true duals.
    Y0TA PR0 and 17TundraDCEd[OP] like this.
  15. May 29, 2021 at 1:23 PM
    AustinPaulJeepTundra
    AustinPaulJeepTundra New Member
    Man, I'm scratching my head on the desire to make a beautifully engineered look and sound of the TRD Pro dual exhaust - quieter!
    Apologies, I don't mean to insult. And I also completely understand that these things are subjective.
    Me? I love the sound of a good V8, which our 5.7s are. I agree with whoever said the TRD exhaust is all about the sound. However, I disagree that it results in a degradation of performance, be it tq or be it hp. Toyota doesn't just slap together parts like this exhaust system, slap a TRD Pro label on it, and call it a day. They are, well...engineered!
  16. May 29, 2021 at 1:59 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    You make good points - no offense taken.
    My truck came with the TRD exhaust - it was a leftover that I got a great deal on. I wasn’t really trying to make it quieter, I wanted to get rid of the chopper-like resonating sound at steady highway speeds. I know it doesn’t bother everyone, but it annoyed me.
    As far as performance, the mid to top range with the TRD was great, but I could feel it struggled to lug in 6th gear at lower speeds. Not a major issue, but it was there.
  17. May 29, 2021 at 2:54 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Same reason I added a crossover pipe (h-pipe) to my TRD system.
  18. May 29, 2021 at 6:45 PM
    mb66l79
    mb66l79 New Member
    Truth of the matter is that H-pipes do increase performance. Mostly low to mid end. Do some research on it if you don't believe it, exhaust scavenging is very real. I have trd exhaust and installed an H-pipe for the performance, and it's a noticeable increase.
  19. May 29, 2021 at 8:09 PM
    #49
    Thanks for your reply.
    My 1794 came with the stock single exhaust, so I had a chance to put a few hundred miles on it before the dealer installed the TRD exhaust (agreed-on as part of the sale). I honestly noticed no change, good or bad, after the install. - - I know you know this, but for others - your truck should never be lugging at low speeds in 6th gear, let alone be in 6th gear at low speeds. The trans should downshift, or if you're shifting it manually, well, I think you know the rest. But seriously, it's always possible (though not likely in a Toyota ) that the trans
    Yep, done a ton of research on H-pipes. Had them installed on both my '12 & '18 Mustang GTs. Why? For the sound. I never felt any improvement. Dyno results showed very little improvement in autos and manuals.
    For my truck, I hit the tow/haul button and enjoy the kick, along with making it louder. It's towing ability is fine as it is (don't haul more than about 600 lbs). That little button is the biggest improvement in power. It reminds me of the tuners I used on the Mustangs.
  20. May 30, 2021 at 6:00 AM
    #50
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    :thumbsup: I used “lugging” as a figure of speech, but thanks for the clarification for everyone else, which will help make my point....
    Scenarios where the stock single exhaust and H piped TRD could hold 6th gear would require a downshift with the TRD duals. Not a big deal just anecdotal evidence that the true duals may loose some low end torque.
  21. May 30, 2021 at 9:29 PM
    #51
    AZTundra
    Paul
    Phoenix, AZ
    I have the trd exhaust as well with the noticeable helicopter sound around 50-65 mph. Would you recommend an h pipe or the resonators to cure it?
  22. May 31, 2021 at 4:48 AM
    #52
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    The H pipe will get rid of the helicopter sound, but it also changes the tone of the exhaust. It’s smoother and deeper sounding vs the throaty burbly sound of the TRD. You’ll lose the chopper sound in that 50 to 65 mph range, but to my ears there was a little drone left - just not that resonating chop. The H pipe is cheaper than resonators, but will require sectioning in pieces of pipe if you decide to reverse.
    The resonators make the interior very quiet. It still sounds like the TRD but just very muted inside - the sound stays outside. The chopper sound is still there if you listen for it, but significantly reduced. The chopper sound didn’t bother me with the resonators. The resonators are more expensive than H pipe, but more easily reversible - just unbolt and clamp block off plate.
    I still have the drivers side resonator which I can send you if you decide on that route. But you would need to get the passenger side resonator from Keith.
    AZTundra[QUOTED] likes this.
  23. May 31, 2021 at 5:20 AM
    #53
    AircareTundra
    AircareTundra New Member
    JT
    If we keep the TRD duals or go with the replacement set up with resonators from Dirtydeedsindustries@gmail.com
    and we opt for the headers offered on their site..... do we still have the catalytic converters as part of the exhaust set up? I called a local shop about doing the work if get the TRD replacement set up from Keith......they suggested they could not get rid of the cats.......silly epa I guess.
    Thanks for any feedback
  24. May 31, 2021 at 8:14 AM
    #54
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the offer. I just had shoulder surgery 2 weeks ago so I won't be doing this modification for a while. Did you only end up using the passenger side resonator leaving the drivers side unused?
  25. May 31, 2021 at 8:50 AM
    #55
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    With a little tweaking to the saddle, the TRD resonators can be used with the standard system - the angle of the resonator part is just different. When I sold the TRD exhaust, I held onto the resonators and another member got the passenger side resonator for a project he was working on.
    Just PM your address to me if you want it and I’ll send it. You’ll be 1/2 way there if/when you’re ready.
  26. May 31, 2021 at 9:10 AM
    #56
    AZTundra
    Paul
    Phoenix, AZ
    PM sent.
