Acceleration Hesitation from a Complete Stop
Discussion in '3rd Gen Tundras (2022+)' started by raulz888, May 4, 2023.
  1. Feb 2, 2025 at 11:31 AM
    #121
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    That's cool.
    Not knowing when the next time it will happen, and whether or not it will put me in a potentially dangerous situation, would not sit well with me.
    It's bad enough knowing there's a chance my engine could grenade at any time.
    cartage1 likes this.
  2. Apr 8, 2025 at 1:48 PM
    #122
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    This is a huge problem for my 2022. Absolute worst. 40,000 Miles on my truck and it does it a few times a week. Ill be at a stop sign or a light and take my foot off the brake and give it gas and it wont go. For a second you're like "wtf?" as your brain processes why you're not moving. The guy behind you is about to hammer you because you're not going anywhere (because you took your foot off the brake and your engine is making noise) and your gap in traffic is now significantly smaller therefore your left with the only option of smashing the gas and burning out, giving yourself and your passengers whiplash, as to not get rear ended or T-Boned. Its NUTS toyota refuses to address this.
    RayRay27 likes this.
  3. Apr 8, 2025 at 2:05 PM
    #123
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Still waiting on your new motor I hope?
  4. Apr 8, 2025 at 2:06 PM
    #124
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    Yep...Other than the acceleration from a stop my truck has been performing as it should. No word on my engine replace date as of yet. Just a "We will be in touch"
  5. Apr 8, 2025 at 2:09 PM
    #125
    PNW Tundra Mike
    Southern Cal
    Fortunatley, everyone I’ve read says their new motor fixes the issue and acceleration is smooth like never before.
    22whatwedo and GeoNeo[QUOTED] like this.
  6. Apr 8, 2025 at 2:26 PM
    #126
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    That's excellent news. Thanks for the heads up on that. There is a LOT to read on this forum and sometimes the answers get a bit hidden.
  7. Apr 10, 2025 at 9:52 AM
    #127
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    2025 Platinum with 2200 miles and the hesitation is now becoming a nuisance and a danger.
    Never happened within the first 400 miles or so but now it's happening frequently.
    Makes me wonder what has changed since the truck was new that NOW it is an issue.
    I've tried turning the traction control ALL the way off. It still happens.
    It happened a couple days ago (yes, I was turning LEFT) and when I finally got going, tires were spinning as I attempted to not get crushed by oncoming traffic.
    I was so aggravated and embarrassed, as I drove away I mashed the pedal to the floor over and over and there is barely any reaction from the engine unless you leave it held down for a moment. Eventually it registers.
    I loathe this wired throttle and all the "smart" nannies on these new trucks. As if the truck knows how to drive better than I do.
    I promise that if you don't hold back horsepower I will be able to take off from a stop without breaking traction and without car-show Mustanging into a crowd of pedestrians. Ask my '09 5.7L with traction control turned all the way off. I've seen me do it.
    Hail Mary, I put 93 octane in it today. I know that's not the issue as the motor isn't gagging due to bad fuel or lack of air. There is no engine response from the pedal at all. The engine is just not getting the signal to go. Something between the pedal and the engine has gone stupid.
    From what I'm reading in here the TSB fix is temporary and some dealers claiming they can't "recreate' the issue so they don't even do it ...so I wont waste my time at the dealer.
    No one has a definitive answer other than "wait until you get a replacement motor"? Do you think your new motor will be different than my 2025? I doubt it.
    Seems the Pedal Commander (or other brand) is where I'll be looking.
    Such a nice truck. Shame that I need to spend $$$ on aftermarket products and potentially risk my warranty just to make it function as it should.
  8. Apr 10, 2025 at 10:00 AM
    #128
    sudobash
    sudobash New Member
    You will still experience the issue with a Pedal Monster or Pedal Commander.
    T-TT-0777-25
    cartage1 and Kap1 like this.
  9. Apr 10, 2025 at 10:32 AM
    #129
    Noobo Baggins
    Glenn
    Booo...
    Now what? Learn to drive it like this?
    Guess I'll need to get in the habit of two footing it, use the brake pedal like a clutch, giving it gas and let up on the brake when I'm ready to skedaddle.
  10. Apr 10, 2025 at 11:23 AM
    #130
    JayDee
    JayDee New Member
    For those experiencing hesitation from a stop try this: Instead of gunning the throttle from a stop, lightly press the accelerator and then once the truck starts moving press the accelerator more aggressively.
    My 2024 SR5 had a 1/2 second or so hesitation when it was new (and I was new to it). I don't know if this technique cured the issue or if it was the transmission software update but my truck now has no hesitation from stop. It may be that I've just learned to accelerate this way (light then heaver throttle press) that caused the issue to disappear.
    I don't typically hot-dog my truck but the last time I needed to accelerate in a hurry from stop (needed the adjacent lane quickly for a turn and there was a car next to me) I pressed the throttle about 1/3 from stop and did not expect the amount of wheel spin I got (traction control enabled) and had to back off the throttle. It's amazing how little throttle it takes to get the truck moving in a hurry.
    Tundrastruck91 likes this.
  11. Apr 10, 2025 at 11:55 AM
    #131
    Kap1
    Kap1 New Member
    San Francisco, CA
    Sorry to hear this.
    I've been very aggravated by this as well. After 3 years of living with it, I got used to driving it like this. No fix unfortunately. I hear that it may improve for me with the new replacement engine, but I would think 2025s should have latest and greatest engine already... So don't know, sorry
  12. Apr 11, 2025 at 5:18 PM
    #132
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Dealer said mine was normal and it was the Turbo's spooling up..., but when I mentioned my wife has the exact same motor and transmission in her 23 Sequoia (I know..., two G-damn grenades waiting to explode (probably done with Toyota)) and her throttle response is 100% different... After a slight puzzled look, they went back to Turbo spool.... Safe to say this power train stinks...
  13. Apr 12, 2025 at 4:59 AM
    #133
    Noobo Baggins
    Glenn
    If it were "turbos spooling up" it would happen every time ... and wouldn't the truck still move while "turbos are spooling up"?
    I can translate for you since I speak fluent "Dealership" ...
    "turbos spooling up" = "we are aware there may be an intermittent lag issue but we can't figure it out all by ourselves so we are at the mercy of Toyota Corporate to send us updated programing to correct it".
    Breathing Borla, GeoNeo and sudobash like this.
  14. Apr 12, 2025 at 2:17 PM
    #134
    Matt2015Tundra
    2023 1794 CrewMax
    Compounding this frustrating problem is the fact that not all Gen 3 Tundras suffer from acceleration hesitation.
    My truck, and many others here, have never experienced the hesitation.
    Mix in the fact that the hesitation is not replicable on demand, and it becomes a warranty/service nightmare. I hope they figure it out. It sounds like the trucks that suffer from this are down right dangerous.
    GeoNeo likes this.
  15. Jun 20, 2025 at 6:35 AM
    #135
    TincanJoey
    TincanJoey New Member
    2024 Tundra TRD Pro
    Yes. This issue is driving me crazy! I have a 2024 and Toyota won't even admit that it is a problem in my model year. My service rep just gets a frustrated look on his face because he has been hit with so many complaints about it but Toyota has tied his hands by ignoring the issue exists. Same thing with the uneven tire wear. They have put out service bulletins on previous years but are ignoring that it is still happening in later models.
  16. Jun 20, 2025 at 8:34 AM
    #136
    Reciprocal
    Reciprocal New Member
    2025 Tundra 4x4 Limited Crew Cab 5.5
    I noticed it twice, assumed I was doing something wrong since several things about it have confused me, like the parking brake. I admit to not reading the owners manual yet.
  17. Jun 20, 2025 at 8:41 AM
    #137
    Noobo Baggins
    Glenn
    I have been using "Sport" mode and haven't noticed the issue again.
    Just gotta remember to spin that dial after I start the truck.
    Speaking of Sport mode ... When entering Sport mode, why does the display show the motor blue and also the suspension (not-blue)...
    Do some trim models have adjustable suspension that changes in Sport mode?
  18. Jun 20, 2025 at 9:36 AM
    #138
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Yes. There's a "Sport S" , Comfort, and Custom in other trims. Not sure which though.
    https://www.tundras.com/threads/can...-changes-in-comfort-mode.109542/#post-2826911
    Noobo Baggins[QUOTED] likes this.
  19. Jun 20, 2025 at 9:47 AM
    #139
    Breathing Borla
    Northern Illinois
    ya its not the turbos lol.. These turbos are tiny and spool really easy and fast, hence the 479 at 2,400....
  20. Jun 20, 2025 at 10:04 AM
    #140
    Reciprocal
    Could the front radar be mistaking something (pedestrian, animal etc.) is in front of the truck when accelerating for the uphill left turn? As an aside, when I park in my garage, the brakes automatically slam when the front gets too close too the wall. If I switch off the backup sensor, it seems to disable the braking behavior in front as well, allowing me to get up close. Wondering if that would have anything to do with the hesitation?
  21. Jun 20, 2025 at 10:05 AM
    #141
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Quite interesting that this is still happening with 23's.
  22. Jun 20, 2025 at 10:21 AM
    #142
    Reciprocal
    An unrelated anecdote, I've had two Gen2 Ridgelines. The earlier one, (a 2017) I was in the left turn lane behind another car that would not go through the intersection. I pulled left to go around her when she decided to then go herself. There was plenty of time for both of us to make the turn before the arrival of an oncoming car but the Ridgeline sensed a forward collision and completely stopped me for dead, left me helpless in front of the approaching traffic, would not go for a second or two no matter how far I depressed throttle, until it finally took off.
  23. Jun 21, 2025 at 5:11 AM
    #143
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    My acceleration hesitation is gone since my motor was replaced with the recall. It drives much smoother, very noticeable change in driving the biggest being the throttle response compared to before. One other thing is I have zero turbo noise now, before you could hear the turbo spool every time I hit the gas and now it’s silent.
  24. Jun 21, 2025 at 5:16 AM
    #144
    Backroadgee
    west
    Missouri
    Is the clunk TSB also the fix for the lag?
  25. Jun 21, 2025 at 8:41 AM
    #145
    sudobash
    sudobash New Member
    The one from 2023 is the same calibration to fix both issues.
  26. Jun 21, 2025 at 8:41 AM
    #146
    sudobash
    sudobash New Member
    Your TCM learning logic was reset because the battery was pulled. It will return.
  27. Jun 21, 2025 at 5:12 PM
    #147
    se3388
    se3388 New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    My 25 Platinum IForce Max has almost 5k on and it has done it twice. My 5k Service is scheduled already so I'll see what they have to say about it.
    Steve............
    sudobash likes this.
