A.R.E CX HD installed and Silverwing Roof Top Tent
Discussion in 'Tonneau Covers, Caps and Shells' started by NoRcptn, Jun 27, 2019.
  1. Jan 14, 2022 at 4:43 PM
    #91
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    I am particularly looking for a higher capacity shell such as the CX HD or Snugtop sportsman (reinforced corner and 1 inch thick upper shell), however I am doubting the quality of snugtop since my dealer does offer it but not yet had any experience in installing it.
    Anyway, I am just anticipating the need for it but I guess I can get away with just the normal shell. How are you limited with the inner frame? I can’t think of things that might be a problem since the only thing I am planning to install in side is a modular bed/drawers, if I would be putting something big or heavy to put over I’ll just use a trailer. What did you encounter that had the frame as a nuisance or obstacle?
  2. Jan 15, 2022 at 5:21 AM
    #92
    NoRcptn
    NoRcptn [OP] Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Well, I am running the decked system so with that and the internal frame it limits me quite a bit. If you look back at page 1 you'll see where the internal frame can reduce side room and headroom in certain spots. If you're drawers are lower than the decked system is, then it's not a big deal.
    What do you plan on putting up top?
    The uprights and load bars aren't re-moveable(well I guess you can technically, but they're not made to). If you want to install a Pioneer/Prinsu rack it'll take a lot of work over a regular shell. If you plan on getting a basket or cargo case it should be no problem to mount stuff up there.
    It doesn't sound like you'll be sleeping on top of it. It sounds more like you'll sleeping under it.
    Whats the setup plan or outfitting idea?
  3. Jan 16, 2022 at 12:21 PM
    #93
    ultraman29
    Katy Tx
    I am thinking of sleeping over it at least 1-2x a year. I’m just bothered by the difficulty of cleaning the window when needed (my driveway has trees that give off yellow pollens), the inability to remove the load/cross bars when needed and I guess the internal frame that might be an obstacle. Thank you the picture though.
  4. Jan 16, 2022 at 12:48 PM
    #94
    NoRcptn
    NorCal
    2017 Platinum
    Yeah I get it . Good luck in your search!
    ultraman29 likes this.
  5. Feb 23, 2022 at 2:28 PM
    #95
    Chowdah
    Chowdah New Member
    Oceanside, CA
    2020 MBM Tundra TRD Pro
    A.R.E. Truck Cap HD Method Grid Wheels Mickey Thompson Baja ATZP3s
    Hey dudes, back after a pretty long hiatus.
    Active duty life sucks a lot sometimes man.
    Anyways, I managed to mount a Rhino Rack platform to my ARE HD crossbars via a special clamp Rhino Rack makes that's actually pretty hard to find. Still experimenting in my free time to see if I can eliminate how high the platform sits as it sits on top of the HD bars.
    Photos and a full write up to follow once I get home this Sunday. Hopefully it'll help someone else out as there's literally no one else other than us who owns this truck cap it seems. (And no one including Rhino Rack nor ARE offers any kind of support whatsoever.)
    WVI and Wallygator like this.
  6. Feb 23, 2022 at 3:02 PM
    #96
    NoRcptn
    NorCal
    2017 Platinum
    Awesome. Can’t wait to see it.
  7. Feb 23, 2022 at 6:33 PM
    #97
    ultraman29
    Katy Tx
    Just ordered mine and waiting for it. I’m looking forward to the modification of accessories.
    NoRcptn[OP] likes this.
  8. Feb 26, 2022 at 4:43 PM
    #98
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    How did this turn out? What CVT tent is that,I’m looking at them currently. Have the extended fly?
  9. Mar 10, 2022 at 6:33 PM
    #99
    EdShed
    EdShed New Member
    I have a 19 Crewmax with an ARE CX HD. Anyone know what size T-slot nuts fit the internal skeleton? I'm having no luck finding that information
  10. Mar 10, 2022 at 8:43 PM
    #100
    NoRcptn
    NorCal
    2017 Platinum
    No but I've been meaning to find out, for like, a year now. If I have time I'll swing by ACE by my house. They seem to have a large assortment of sizes there.
  11. Mar 10, 2022 at 9:02 PM
    #101
    NoRcptn
    NorCal
    2017 Platinum
    OK just found this on Tacoma world ....
    "I never found any t-nuts that fit the frame through my usual hardware suppliers. I ended up getting an A.R.E. t-nut kit from my local dealer. It had 8 black t-nuts that are shaped to fit the slots somewhat snugly, 8 washers, 8 screws, and 8 zinc-plated flat nuts (thick sheet metal) that have two threaded holes and fit the slots somewhat loosely. The black t-nuts and the smaller hole on the zinc t-nuts are 6mm. The larger hole on the zinc t-nuts are 8mm. If I remember correctly, the kit was about US$17.
    I see you're in Orange County, CA. You could try calling this guy. He's where I got mine from."
    A-11348 is the part number for the kit. $30.00 is how much they said.
    Snap-In Campers
    1501 West Acacia Ave. Ste. #114
    Hemet, CA 92543
    Phone (951) 766-9425
    TundraRV likes this.
