6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 10, 2022 at 9:33 AM
    #2011
    Trstno1
    Trstno1 New Member
    Brent
    2021 cavalry blue SR5 w/TRD Offroad
    None
    How did you mount those raptor lights?
  2. May 17, 2022 at 2:37 PM
    #2012
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    After a long wait I finally got my 6112/5160 kit installed yesterday. Have the fronts set at 1.9” with one 1/4” coachbuilder shim on the drivers side. The shop apparently broke their ball joint press trying to remove the old bushings, so the coachbuilder +2 shackles will have to wait a couple weeks until I can give up the truck again. Overall pretty happy with the ride so far, and it’s relatively level as it currently sits, but looking forward to a little extra rake. The tires are 275/60r20 Goodyear wrangler duratracs on stock 20s, but will be upsizing to a 275/65r20 when the tires wear down or I come into a little extra cash.
  3. May 20, 2022 at 8:37 AM
    #2013
    Rivulose
    Rivulose New Member
    Looking to see if anyone's got a similar setup to what I'm wanting to do or has some experience with lifts and suspension.
    Ordered a pair of 6112 planning on setting to 1.9 or second off the top setting. A single coach builder shim on the driver side so eleviate some lean going on. Stock Bilstein 4600 shocks in the rear with coach builder +3 shackles.
    Looking to have some forward rake and not breaking the bank to have a near 2 inch lift.
    Thanks for the input and help
  4. May 20, 2022 at 9:11 AM
    #2014
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    6112s top setting up front ... 5160s in back with Toytec shackles @ 1" setting. 285/75/17 KO2s. Had to bend in the corners of the skid to prevent rubbing at full lock.
  5. May 21, 2022 at 1:16 PM
    #2015
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    Looks great! Do u have a front or rear shot of the truck? Need to get a feel for the outset on those wheels.
  6. May 24, 2022 at 9:38 PM
    #2016
    ShinyConcretE
    ShinyConcretE New Member
    Justin
    Northern California
    2020LimitedCM
    Watson, Tundra Dude 45 and pvmike like this.
  7. May 24, 2022 at 9:41 PM
    #2017
    ShinyConcretE
    Justin
    Northern California
    2020LimitedCM
    COTundra23, Sleeper16plat and pvmike like this.
  8. May 27, 2022 at 10:26 AM
    #2018
    Ronsofury
    Ronsofury New Member
    Dont wana hijack this thread but I need some advise. so I installed 6112 at 1.9" with a shim on driver side, drove for about 30 miles,felt normal,wasnt pulling etc, then took it to a Toyota dealer for alignment. the tech worked on it for 3 hours, and now my steering wheel is off center. they said thats best they can do, cant get anymore green than that.... idk , should I bring it back?
  9. May 27, 2022 at 12:49 PM
    #2019
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    They lie, alignment is only as good as the tech that performs it. Requires knowledge and experience. Find a local tire/suspension shop that has good reviews. 1.9 lift in front should not be hard to align and if the steering wheel is off now, they did it improperly. Alignment and wheel balance is usually best performed somewhere other than the dealer.
  10. May 27, 2022 at 9:22 PM
    #2020
    Ronsofury
    I took it back, dude spent another 90 minutes, now the truck pulls right...I dont think he even tried to adjust caster... sigh there are no good alignment shops nearby, highest rated one is a 3 star pepboys...
    anyway Im gona install 1.5 toytec shackles in cpl weeks, the TSS sensor works perfectly fine tho. got a set of ray10s coming, still cant decide on tire size after reading every 275/295 thread lol.
  11. May 28, 2022 at 4:15 AM
    #2021
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    The tech had no idea what he is doing. You can get better numbers with angle meter and measure tape if you do it by your self.
    equin and Ronsofury[QUOTED] like this.
  12. Jun 7, 2022 at 11:58 AM
    #2022
    king.cong.1119
    king.cong.1119 New Member
    6112s on 2nd notch (1.9in) setting
    5160s plus coachbuilder+2 shackles
    One thin shim driver side
    stock UCA/LCA
    All alignment spec in green
    BFG KO2 315/70r17 load range E
    Icon Rebound 17x8.5 +25mm offset
    Does not rub on body mount
    Do rub a bit on front wheel well liner, head gun push forward solved it.
    uFKm6IVY.jpg mwlIRi9k.jpg rlWFtxNI.jpg _1WlpIU8.jpg B7_l2Jhc.jpg Capture31.jpg
  13. Jun 8, 2022 at 10:29 AM
    #2023
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Looks sweet!
  14. Jun 9, 2022 at 5:22 AM
    #2024
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    King Cong truck looks great! I think 315/70/17 is the perfect size on these trucks with about 2” of lift. Unfortunately I just couldn’t stand the power loss on the mountain passes but the ride with that size is incredible! 1.9” is actually 3rd notch or 2nd from the top correct? I have mine set 2nd notch passenger and 3rd driver and I swear I get 2-2.5” of lift still.
  15. Jun 9, 2022 at 6:50 AM
    #2025
    king.cong.1119
    Now you are confusing me, I believe it was the 2nd notch from the bottom, not sure how many total notches there is? haha yea 35s is great for our tundra. I found out the amazing difference the "tow haul mode" makes, it transforms my truck in to a little race car when towing, I have yet tried it without towing yet, but that will be a great weapon for some of the occasion sluggishness in the mountain passes. Try it, it keeps your gear low and hold it longer.
  16. Jun 9, 2022 at 7:05 AM
    #2026
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    I’m confused too, I was hoping you could help! I believe there are 4 notches: .7, 1.3, 1.9 and 2.5 and I assume bottom notch is lowest(.7)top notch is tallest(2.5).
    Tow/haul works pretty good but not as well as a throttle controller like pedal commander or the Banks one I have. It really makes the truck so much more enjoyable to drive on a daily basis and in all situations.
    king.cong.1119 and tonynw318 like this.
  17. Jun 19, 2022 at 8:21 PM
    #2027
    jaflynn738
    jaflynn738 New Member
    Just had the Bilstein 6112 installed. Rear is still stock, but I do have 1in shackle to install. Now for Wheels and Tires. Willing to take any suggestions especially with offset as I have no idea. I would like to stay with 18 wheels. I hear to stay between +18 to +25. Again, any help with that would be appreciated as I don't want to cut or trim.
    Sleeper16plat likes this.
  18. Jun 20, 2022 at 10:29 AM
    #2028
    Ronsofury
    I bought SCS ray10s but now I'm not sure I want to use it, If I paint my stock wheels black they'll look pretty good too. My setup is 6112 @ 1.9" with 1 DS shim, 1.5" shackle, installing JBA UCA next week. I wanted 295s but several offroad shops advised agaisnt it, 25mm offset isnt ideal at my lift height becoz new UCA (for easier better alignment) puts upper ball joint backward to its original position and 34" tires will hit the body mounts. without UCA alignment can be very tricky, Iv been to 3 shops now and they cant/too lazy to do it right. If I dont want to do BMC I'd have to choose between good alignment and good looks. So I'm gona go with 275/70r18 falkens this time and see if I want to lift the truck higher. imo at 3-4" lift, 285/75/r18 tires looks really good.
  19. Jun 20, 2022 at 4:30 PM
    #2029
    DK1865
    DK1865 New Member
    Kansas City
    2021 WCP Tundra Limited
    Shop just installed Bilstein 6112/5160 with CB +3. The clip at the highest setting. Also added JBA UCA with the lift. No alignment issues. Had to remove the mudflaps due to the the 0 offset RRW RR6-H wheels on 295/70/17.
  20. Jun 28, 2022 at 2:45 PM
    #2030
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Those wheels are so sweet! Just wish they made them in a +25 or +35 offset.
  21. Jun 28, 2022 at 3:05 PM
    #2031
    DK1865
    DK1865 New Member
    Kansas City
    Yeah 0 offset is pretty aggressive for me. I installed some fender flares to hopefully protect my truck from debris.
    tonynw318 and FISHN43[QUOTED] like this.
  22. Jun 28, 2022 at 3:21 PM
    #2032
    FISHN43
    FISHN43 New Member
    Ohio
    Looks good! Do they still stick out past the flares or they pretty flush now?
  23. Jun 28, 2022 at 3:49 PM
    #2033
    DK1865
    DK1865 New Member
    Kansas City
    Thanks! They are about flush now. I purchased the extend-a fender flare from bushwacker.
    With flares
    Without flares
  24. Jun 28, 2022 at 4:05 PM
    #2034
    FISHN43
    FISHN43 New Member
    Ohio
    Thats about perfect. Nice!
    DK1865[QUOTED] likes this.
  25. Jun 28, 2022 at 4:58 PM
    #2035
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    @DK 1865 flares look good! I am running 0 offset wheels and accumulating scars- not a major issue but I did have flares on my 08 Tacoma and liked them. Could you have kept the flaps on? Actually thinking about coopers for next tires; I am on Mickey ATZs currently.
  26. Jun 28, 2022 at 5:25 PM
    #2036
    DK1865
    DK1865 New Member
    Kansas City
    Thanks! I don't think the mudflap would fit with the flares. I tried to remount the mudflap with the flares but it doesn't line up correctly to secure the flap. My initial experience with Cooper AT3 XLT are great! Really quiet tires and does well so far with rain. I had K02s on my 15' Tacoma and I thought those tires were a lot louder.
  27. Jun 29, 2022 at 4:34 AM
    #2037
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Appreciate it @DK 1865. I was at the Truck Shop in San Diego getting an alignment and the guru's there said they would go with Coopers or Yokos. I am leaning towards Coopers.
    SAGE63 and DK1865 like this.
  28. Jun 29, 2022 at 11:59 AM
    #2038
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Un-solicited review:
    I've got about 10k on my cooper at3 XLTs. Overall still pretty quiet, not as much as new obviously. Only issue that has really gotten old is the flat spotting. Noticeable overnight. Even worse if it's parked for a few days. Goes away after 10 min of driving or so, but 10 minutes is also about my average commute time. Overall I don't think it would make me choose a different tire tho.
  29. Jun 29, 2022 at 3:24 PM
    #2039
    DK1865
    DK1865 New Member
    Kansas City
    Definitely will have to keep an eye out for the flat spotting. Thanks for the heads up!
    Pillslinger[QUOTED] likes this.
  30. Jun 29, 2022 at 6:21 PM
    #2040
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    Recently got my 6112/5160s installed. 6112s set at 1.3. Tires are hankook dynapro mt2 at 285/65r18, wheels are method 305s with +25 offset. I think the stance looks great for not having a big lift and bigger tires.
