6112/5100 set up, prices, install questions. Need some advice
Discussion in 'Suspension' started by TXTundra89, Apr 21, 2020.
  1. May 9, 2020 at 11:28 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    My tires were on, truck on the ground for bumpstops. I went with the CB bumpstop extensions.For carrier group. tires on, on the ground, and jackstand under drive shaft.
  2. May 9, 2020 at 5:56 PM
    TXTundra89
    TXTundra89 [OP] New Member
    Conroe, TX
    2016 Silver Tundra SR5 crewmax
    6112's on top setting with Boss shims, 1.5 inch shackles, 5160's in rear. 305/70r18 KO2's, Method Grid 0 offset.
    Yeah, didnt make any sense to me either. I'll probably hit up Boss to let em know their instructions are a bit off cause I'm sure someone who doesnt know better would try to do all of that lol. Thanks Tundy
    Tundyfundy likes this.
  3. May 20, 2020 at 11:01 AM
    TXTundra89
    Conroe, TX
    I got the job done and tested. Loving the ride and look. Wheels and tires to come..
    +2 shackles and 5160's in rear
    Front with 6112's on top setting (2 shims driver side, 1 on passenger)
  4. May 20, 2020 at 11:15 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Where did you get them from? And cost please? This is the set up I am currently wanting for my truck.
    Please and Thank You
    Edsel
  5. May 20, 2020 at 12:56 PM
    TXTundra89
    Conroe, TX
  6. May 20, 2020 at 2:33 PM
    Kenny1794
    Kenny1794 New Member
    Bought them from Keith @ dirty deeds if u are looking for ur truck to be leveled he's going to recommend this and it pretty much leveled my truck my rear is about 1/4" higher....
  7. May 20, 2020 at 2:35 PM
    TXTundra89
    Conroe, TX
    @Damie Street if you have any questions about install or anything I can help with don't hesitate to ask. Good luck and I hope you like the set up.
    Damie Street likes this.
  8. May 20, 2020 at 2:54 PM
    Damie Street
    Edsel
    South Carolina
    I'm sure I will have plenty of questions for you. :rofl:
  9. May 26, 2020 at 12:13 PM
    TXTundra89
    Conroe, TX
    I am waiting on 18in method grid wheels with 0 offset and 305/70 KO2's. I've done alot of homework on fitting these tire sizes. I am sure some cutting will need to be done, mainly the body mount. Does anybody know how or if a zero offset with this tire size will fit or how intense it'll be to fit them? I have about 3.2ish inch lift in the front.
    Everything I read says the more positive the offset the better as far as fitting. However, I want the great look of the tires out away from the truck a tad so I am a bit worried about it all fitting. Twist my arm and I'll throw on a C4 fab front bumper in a heart beat lol.
    InfernoToyo likes this.
  10. May 26, 2020 at 2:23 PM
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    Nice. Add pics after install. Looking at this lift as well
  11. May 27, 2020 at 2:33 PM
    TXTundra89
    Conroe, TX
    How much space is between your bumpstops and lower control arms? I have about 1.5 inches of allowed travel after putting on the bumpstop extensions. I am wondering if I am taking away or limiting travel of my 6112's on top setting. I don't know how to tell how much uptravel is enough or too little. Anyone have thoughts or advice?
    georgiey22 likes this.
  12. May 28, 2020 at 5:45 PM
    33jeep
    33jeep New Member
    That is about what I have between mine. The spacer is to keep the longer blistering from being bottomed out.
  13. May 28, 2020 at 9:55 PM
    TXTundra89
    Conroe, TX
    Okay, good to know someone has about the same. I asked Bilstein and they said it's fine if it came with my kit. Which seemed a tad too confident IMO but im sticking with it and if I can tell its too little travel I will change it. I tried bottoming out earlier and could'nt/didn't. So I guess those 6112's are rocking it in every way and I couldn't be happier. Should be getting new tires and wheels tomorrow and can start to see how much of a chop, trimming, and molding I'll need to do.
  14. Jun 3, 2020 at 7:55 PM
    TXTundra89
    Conroe, TX
    no plates front side view.jpg Finally got the wheels and tires today. Method Grid 0 offset wrapped in BFG KO2s 305/70 r18. I didn't bother putting in the wheel hub covers, shes gotta go in for some cutting, trimming, molding to get rid of rubbing. 102833646_3325963537447686_97723171842555904_n.jpg
  15. Jun 3, 2020 at 8:29 PM
    InfernoToyo
    Barty
    Inland Empire
    Have you done the alignment? Do you need aftermarket upper control arms?
  16. Jun 3, 2020 at 8:34 PM
    InfernoToyo
    Barty
    Inland Empire
    Did you need the diff drop? Did you need the front sway bar relocation kit?
  17. Jun 3, 2020 at 8:48 PM
    TXTundra89
    Conroe, TX
    I did have it aligned after the lift, no aftermarket UCA's needed (but they're on the list). I did not need the front sway relocation and I haven't installed the diff drop yet but plan to soon after the BMC.
    Rica25 and InfernoToyo like this.
  18. Jun 9, 2020 at 2:46 PM
    TXTundra89
    Conroe, TX
  19. Jun 9, 2020 at 5:25 PM
    #49
    NEPAChuy
    NEPAChuy New Member
    2023 Tundra Platinum Hybrid Supersonic Red, 2020 Tundra Platinum Voodoo Blue
    Hi all,
    I just installed 6112s (1.9” setting both sides) in the front and 5160s in the rear this week. I’m measuring the truck as essentially level within 1/4” front to rear.
    Since I often haul or tow a trailer, I’d like to retain at least some of the factory rake. Can you tell me what is the factory rake (i.e. how much higher the rear is than the front from factory)? I forgot to take measurements before install. And if I want to move towards retaining the factory rake, what do I need to add in the rear with the 5160s?
    Thanks!
    Rica25 likes this.
  20. Jun 9, 2020 at 9:33 PM
    #50
    TXTundra89
    Conroe, TX
    I believe factory comes about 2 in higher in rear. As for what to put with the 5160's, I'd say add about a 1 in shackle or add a leaf if you're worried about needing extra strength in the rear when towing. I have my 6112's on top setting with 2 shims driver and one on passenger side and 1.5 shackles. The rear is barely higher so with the lower setting up front like you're running I'd bet it'd look good and be CLOSE to factory. Others will chime in. If you bought the parts from a site I'd ask them or check out the 6112 set up/combo thread on this site. You'll be amazed when you realize you're on page 34 lol.
  21. Jun 9, 2020 at 9:51 PM
    #51
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    about 2 1/2 inches. I am at 2 1/4” of front lift and still have about 3/8” of front rake
    NEPAChuy[QUOTED] and Rica25 like this.
  22. Jun 10, 2020 at 12:10 AM
    #52
    NEPAChuy
    NEPAChuy New Member
    Thanks. I’ve read about as much of the 6112 threads as I can find, but this simple question wasn’t answered anywhere that I could find. The answer is probably buried somewhere and I missed it. I will look into shackles for the rear.
  23. Jun 10, 2020 at 4:38 AM
    #53
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    How high can you go in the front before you need a diff drop kit?
  24. Jun 10, 2020 at 10:39 AM
    #54
    TXTundra89
    Conroe, TX
    From my research at around 3 in and up you wanna drop the front diff. You'll find people saying that changing the angle of the front diff that it'll cause the fluid not to properly coat the gears yadayadayada. IMO if you have the proper amount of fluid (as you should) then it wont matter and the gears will throw fluid around as designed. I spoke to Darren at Boss about this and he assured me that it will not harm or change anything by dropping the diff and that he sells a ton of diff drop kits every month for years with no problems from the kit.
    I have yet to install my diff drop, have ran 4x4 a few times but nothing crazy or taxing on the front end. No issues. This saved me cause I just had Toyota throw in a new front diff actuator covered under my warranty, costs me 50 bucks lol. Had I thrown it in they may have said it broke warranty. Now I will throw the drop kit in soon haha.
