5100's just installed.... Top setting is rough
Discussion in 'Suspension' started by burr-head, Jun 14, 2019.
  1. Jun 17, 2019 at 11:25 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Although you got it home safely, when the spring perch is upside down, I don't think they're is anything to keep the clip from popping off. If it were to pop off, I think there would be a bit of damage. Not sure how far the tire goes up in the wheel well with no spring support.
    kparrow likes this.
  2. Jun 17, 2019 at 11:35 AM
    burr-head
    burr-head [OP] New Member
    2019 Tundra 4x4 Crewmax Platinum, Magnetic Gray
    This is the pic the dealer just sent me showing correct. Thoughts before I pick it up
    rv740, Rica25 and Voyagermike like this.
  3. Jun 17, 2019 at 11:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks a lot better. Make sure to get their alignment sheet of last time and this time to ensure they did it...
  4. Jun 17, 2019 at 11:40 AM
    burr-head
    You got it. It still looks a little high in the front end to me. I know I can put a block or Coachbuilder in the rear but I just wanted to get y’all a opinion on the shocks. Thanks
  5. Jun 17, 2019 at 11:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you want a slight slight rake then have them set it to the middle before they align it
  6. Jun 17, 2019 at 11:51 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Looks good. You can always drop the front end one spot, but not sure you want to uninstall and reinstall again.
  7. Jun 17, 2019 at 12:09 PM
    burr-head
    Yeah once I look at it and see how much clearance I have with these 285’s then I’ll decide. The dealer said all they had to trim was the skid plate and everything cleared pretty good. I will post a couple pics of what they sent me
    Voyagermike likes this.
  8. Jun 17, 2019 at 12:11 PM
    burr-head
  9. Jun 17, 2019 at 12:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I dig it
  10. Jun 17, 2019 at 12:47 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Hows the ride now? I want to get those tires (stock size) with those shocks (on middle setting).
  11. Jun 17, 2019 at 12:57 PM
    burr-head
    I’m waiting on it to get back from the dealer and I will post the ride quality when I get a chance to drive it but they put mine on the last setting I believe. I have looked at the pics pretty good and I think they could’ve done middle and not had to trim but not sure. This whole thing has been a cluster and thanks to the guys on here, I was able to keep my sanity.
    Thanks Hbjeff.
  12. Jun 29, 2019 at 5:56 PM
    ZekeFreak
    ZekeFreak New Member
    I have them on the bottom setting and still think its a stiffer ride than stock
    Rica25 likes this.
  13. Jun 29, 2019 at 6:11 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I had 5100s on my last truck and thought they were a little jarring. I went with 6112s on my new truck for that reason alone. Def a night and day difference.
  14. Jun 29, 2019 at 6:12 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I love my 5100's on top setting with Toytec shackles. The ride was great with the stock LT tires but it became stiffer when I put on Nittos. I knew that the ride would change due to me changing to good, real, tough tires.
    It will be tough to get over the psychological warfare that's going on in your mind since they already screwed up. Deep breath my friend; deep breath.
  15. Jun 29, 2019 at 6:44 PM
    burr-head
    This is the first truck I've had with 5100's and on the top setting, it's not bad at all. I just changed wheels and tires and went with the 18x9 bronze Methods with the 295/70/18 Nitto Ridge Grapplers and I thought it was going to ride rough, not at all. The dealer put 35 PSI in the tires and it rides very smooth. All my other trucks in the past had Rough Country Lifts and boy do they live up to that name "rough". Never again...
    vhstejskal likes this.
  16. Jun 29, 2019 at 8:22 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Post come pics with the wheels.
  17. Jun 30, 2019 at 3:52 AM
    burr-head
    I am definitely on the fence about adding a shackle in the back for a little rake. I am also thinking about 1-2 shims in the front just to get a touch more but everything rides great with no rubbing anywhere so I probably should leave well enough alone.
    rv740, vhstejskal, teedubbya and 2 others like this.
  18. Jun 30, 2019 at 9:54 AM
    nvrgvup444
    KCMO
    I think it looks perfect. Beautiful truck, nice stance. Seems like you have a winner.
  19. Jun 30, 2019 at 10:05 AM
    #49
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Nice wheels lol
    If you go with shims + shackles from coach builder it gets you around 3” all around, no rake...well maybe just a smidge 5A508A03-9161-4129-B233-EDE6460CFD71.jpg
  20. Jun 30, 2019 at 10:31 AM
    #50
    Mr Badwrench
    Mr Badwrench New Member
    Oh my god. I have given up on these "mechanics". They didn't think to STOP and reassess the situation when they had to compress the spring completely to get the assembly bolted back together. Parts changers, and they can't even get that right.
  21. Jun 30, 2019 at 10:44 AM
    #51
    burr-head
    Thanks for the nice compliments. Mr Badwrench, agreed 100%!!!
    teedubbya, what do you have on yours? That looks good.
    teedubbya likes this.
  22. Jun 30, 2019 at 1:04 PM
    #52
    teedubbya
    Austin TX
    5100’s on top setting, 2 shims driver side one shim passenger, +3 shackles in back. All @Coachbuilder1
