5000 Miles maintenace and 5W-30
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Apr 10, 2024.
  1. Apr 23, 2024 at 8:02 AM
    #91
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Do you have the 4.6 or the 5.7? It should take 8.5 quarts for the 5.7 (unsure for the 4.6). I would double check you're not low, because only 7 ain't enough (assuming it's the 5.7).
    nobodyintexas likes this.
  2. Apr 23, 2024 at 11:48 AM
    #92
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    No more Kirkland Signature for you?
    Leo's first and hagrid like this.
  3. Apr 23, 2024 at 12:19 PM
    #93
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    lulz!
    Pig Rig and Leo's first like this.
  4. Apr 23, 2024 at 12:39 PM
    #94
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i will still use it.
    just wanted to try something else.
    Leo's first and Tbrandt[QUOTED] like this.
  5. Apr 23, 2024 at 12:43 PM
    #95
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    At 5k intervals, oil is oil dont overthink it.
  6. Apr 23, 2024 at 8:30 PM
    #96
    Rugerla1
    Rugerla1 New Member
    Tennessee
    2018 Tundra TRD Sport
    I sure started getting nervous reading through this thread when the “Amazon filters can be counterfeit” comments started. I watched the video and my filters don’t compress like the counterfeit one. But like another member posted, I only have the word “Toyota” and nothing else on one section of the filter. I bought this five pack below from Amazon which had good reviews. But now I’m wondering if it isn’t worth getting at least one filter from the dealer just to compare before using any out of the five pack.
    https://www.amazon.com/dp/B007OW6LSC
  7. Apr 23, 2024 at 9:24 PM
    #97
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you want I can take some pictures tomorrow of my authentic Toyota oil filter so you can compare.
    Leo's first and Rugerla1[QUOTED] like this.
  8. Apr 23, 2024 at 9:27 PM
    #98
    Rugerla1
    Rugerla1 New Member
    Tennessee
    That would be awesome! Thank you for offering to do that
    Ruggybuggy[QUOTED] likes this.
  9. Apr 23, 2024 at 10:00 PM
    #99
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Apologies, I should have said “some lube techs”. Didn’t mean to lump any real service techs into my little rant! :)
  10. Apr 24, 2024 at 5:39 AM
    #100
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    No I got the 5.7 and it was more than enough, it was above the two dotted marks on the dipstick. I initially added almost 8 (7.9 According to Toyota) but then had to drain a bunch with my new cool Fumoto drain valve. Checked it again after the truck was standing for a while it was still above the two marks..
    Leo's first likes this.
  11. Apr 24, 2024 at 6:00 AM
    #101
    centex
    centex New Member
    I did about 7 3/4-8qts on mine when I changed it the other day.
  12. Apr 24, 2024 at 6:00 AM
    #102
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    7qts seems like it's too little. The 5.7 takes 8.5qts as @Red&03Taco said. I believe the 7.9qts that Toyota suggests is if you don't drain the oil filter canister but since it looks like you did, it should be 8.5qts.
    Terndrerrr likes this.
  13. Apr 24, 2024 at 6:03 AM
    #103
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I concur.
    every time I do a full oil change it's ~8.5 qts.
    2020
    did different years have different oil pans....I think not.
    interesting - nonetheless.
    Red&03Taco likes this.
  14. Apr 24, 2024 at 6:10 AM
    #104
    TacomaTRD4x402
    Southern California
    How about the oil filter canister? Is 2007+ same plastic canister as later models? I ended up with a stuck canister last weekend so I didn't change out the filter. I want to have an emergency backup one on standby in case it breaks. I settled for a dorman metal one but I'd rather have OEM. I might be able to snag one from a '13 part out.
  15. Apr 24, 2024 at 6:22 AM
    #105
    It is in the manual for “severe duty” such as heavy stop and go traffic or towing. Tell em that’s you.
  16. Apr 24, 2024 at 6:23 AM
    #106
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I think the discrepancy comes from the angle the truck sits when draining old oil and how long it is allowed to trickle.
    With the extra clearance of my skinny 35s and almost completely flat driveway, I don’t jack the truck up at all (which would angle the oil pan, potentially keeping a small amount of old oil from draining). I think I get that extra half quart or so out compared to some of y’all.
    I’m not saying that you’re not doing a good oil change if you only replace 7 qt when the manual says 7.9; just noting a possible explanation given that we’re surely not seeing a super wide tolerance in oil pan sizes.
    After letting oil pan and filter fully drain, I start with adding 7.5qt, and always have to add a bit more after a short drive to get between the marks on the dipstick.
  17. Apr 24, 2024 at 6:57 AM
    #107
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    He could be changing his oil on an incline or something not allowing all the oil to come out
    TacomaTRD4x402 likes this.
  18. Apr 24, 2024 at 7:15 AM
    #108
    TacomaTRD4x402
    Southern California
    Ths recent oil change I did(which was my first on this truck) I used rhino ramps which inclines it allowing me to get under my truck since I have no lift. I put the full 8.5qts in and checked the level next morning with a cold engine. Would you uguys think the best way to drain everry last drop out would be to jack it up from the drivers side only? Or am I overrthinking this? :monocle:
  19. Apr 24, 2024 at 7:19 AM
    #109
    nobodyintexas
    nobodyintexas What?
    South of Houston
    you are over thinking.
    y'all remember the dude that - after draining the oil - pours in a half quart of new oil to get all the remnant oil out?
    pure genius
    I do that every time now.
  20. Apr 24, 2024 at 7:24 AM
    #110
    TacomaTRD4x402
    Southern California
    Also would be best to drain when the oil is warm or hot, right? Drains better?
  21. Apr 24, 2024 at 7:41 AM
    #111
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yes, you should ideally drain it when the oil it at least warm. And I wouldn't bother about lifting the driver side higher. Yes maybe you'll get a few extra drops out, but you're getting the vast majority out, so it's fine.
  22. Apr 24, 2024 at 7:59 AM
    #112
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I think you're absolutely right on this one. I have 35s as well and therefore can do my oil change without jacking the truck up too. Consistently get 8.5 quarts out, and refill with the same.
    Terndrerrr[QUOTED] likes this.
  23. Apr 24, 2024 at 8:16 AM
    #113
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I've been running 0w40/5w40 in warmer months since 2012. Started doing it when I installed the SC. Usually change to a 5w30 by November/ December and 0w40 by March/ April. Probably could run 0w40 year round but it's a schedule i keep. OCI every 5k. Never had an oil analysis so not sure. Engine still runs...
    blenton[QUOTED] likes this.
  24. Apr 24, 2024 at 8:31 AM
    #114
    blenton
    blenton New Member
    no. Olive oil is clearly too thick. Unless they cut it with lacquer thinner.
    ryanwgregg[QUOTED] likes this.
  25. Apr 24, 2024 at 8:34 AM
    #115
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Probably should, since the 0 means better flow on cold starts in winter.
  26. Apr 24, 2024 at 8:53 AM
    #116
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I switched to 0w30.
    Designed for fancy European vehicles.
    Just wanted to share that I'm better than everyone and care more about my truck.
  27. Apr 24, 2024 at 9:00 AM
    #117
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    The oil level should be checked with the truck chassis in a level position. After the new oil is added (proper quantity per the manual), start engine to build oil pressure and fill the filter. Wait several minutes, then check with dipstick (if desired, I seldom do since there should be no difference from oil change to oil change).
    I drain, fill and start with the truck on the ramps to check for leaks (there never is any). Then I back off the ramps after I install the skid plate. I'm done at this point (except for cleanup).
  28. Apr 24, 2024 at 9:00 AM
    #118
    Norfolk757
    Tom
    Norfolk, VA
    That's exactly how I did it: left it open and poured about half a quart until I saw clean oil coming from the drain. Additionally, I leveled out the truck with 1.9 (6120) in the front and 5100 in the rear and changed it without a lift—I just rolled right under. One thing to note is that I parked the truck with the front facing the garage, as the driveway slopes slightly away from the garage, though the decline is minimal.
  29. Apr 24, 2024 at 9:52 AM
    #119
    AZBoatHauler
    So.Arizona
    Dump in 8, verify no leaks, call it good.
    Henry1jg and Terndrerrr like this.
  30. Apr 24, 2024 at 6:45 PM
    #120
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here are the pictures I promised. The filter was bought at a Toyota dealership.
