4" Rough Country Lift w/ Build
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rebel Tundra Man, Sep 25, 2019.
  1. Dec 2, 2019 at 8:06 AM
    Rebel Tundra Man
    Rebel Tundra Man [OP] New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    also got big things coming this afternoon, I will try to get pics posted as soon as possible. I had a week off from work lastweek so it got a little dangerous me and dad being in the garage with my truck haha.
  2. Dec 2, 2019 at 8:12 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Great job: looks great!:thumbsup:
    Rebel Tundra Man[OP] likes this.
  3. Dec 2, 2019 at 8:45 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I did solve my crappy JBL system sound this past week while I was off work too, I replaced all the door speakers with my usual Kicker DS series speakers, $75 for the front 6x9's and $65 for the rear 6.5" ones from local Walmart. The sound is 1000 times better than before. the front speakers were an easy change. The speaker holders are easily removable with screws and then the speakers unplug and remove as well. I unsoldered the factory speaker plug and re-soldered it to the new speakers (kicker DS 6x9) and re-installed it the the door frame, it did require a spacer to push it off of the window track, I will have pictures soon for this. The rear was a little more difficult as the speakers were made to the plastic holder. I'm sure these things can be bought. but I did reuse my factory stuff as the speakers were useless anyways. Here is the pics of how I modified the rear speaker holders to hold the new Kicker DS 6.5" speakers.
    I had to trim the Door Grill down to allow clearance because of speaker depth issues.
    The speaker holder unscrews from the door. next pop the magnet loose off the back old factory speaker and use a dremel or oscillating tool to cut the supports around the edge holding the speaker into the factory holder. These supports will no longer be needed with the new speaker. I left the foam around the outside of the speaker to maybe reduce vibrations and in the last picture I hot-glued some weather stripping foam around the outside to cushion the speaker against the door panel grille as well.
    I did reuse the factory wire plug, I cut the wires loose off the factory speaker and soldered the new speaker wires into the holes where the old ones were soldered as you can see above. I don't now if I got the polarity right on them or not, I compared the plugs to the front of the truck as they were labeled black and red.
    I have been running the sound system with the bass turned all the way down because the crappy JBL stuff couldn't handle the sound of it all. Once all the speakers were installed I was able to turn the bass, mids, and highs up to the levels I preferred and every song sounded full like it should have to begin with. not the complete fix to this problem but I can live with the sound it produces now compared to what it did have. I will probably still add some actual subwoofers to the system at some point though.
  4. Dec 2, 2019 at 7:18 PM
    Spoolnms
    Spoolnms New Member
    Ryan
    2014 Tundra
    7" lift, 37x13.50r18, catback dual exhaust, intake, etc.
    Looking good. Ive been looking into a speaker upgrade as im happy with the factory unit.
  5. Dec 3, 2019 at 9:07 PM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Been waiting to do this since I bought the truck just had to wait for everything to come together. But y’all let me know what ya think!
    here’s before
    Here’s the finished headlights with LED DRL
    and here’s the finished product of all the color match stuff.
    TundraDude18 and Ely010606 like this.
  6. Dec 5, 2019 at 7:51 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I did a few more things lastnight while I had the dash tore off for other unknown reasons... (pics to come)... :cool:
    When I installed the new wheels and tires after the lift, I eliminated the TPMS sensors from the wheels. This caused the light on the dash to stay on, after searching on this topic I found this thread here.
    https://www.tundras.com/threads/disable-tpms.1056/
    The TPMS Module is located behind the glove box on the passenger side of the truck, I did not snap a pic of it while I had it apart, but it is the little gray box that sets up vertical, right beside the blower fan box. It does say "Tire Pressure Monitor" on the side of it as well. As stated in the thread there is a yellow and light green wire that are side by side. I cut the green wire close to the plug, I did leave a little tail coming from the plug incase I ever need to revert it back as well. There will no longer be a green wire going into the plug, instead it is to be connected to the yellow wire next door to it this sends either a voltage or an ohm reading back to the computer/dash board which tells the light to turn off, I was unclear which one of these occurs because I did not have the battery connected to the truck. I used a diode in between the two wires as some stated they did since I just happened to have some on hand. The diode is set where the signal can only flow FROM the yellow wire TO the green wire. NOTE: DO NOT CUT THE YELLOW WIRE!!! On the yellow wire back from the plug about 2" I stripped a small bare spot just big enough to wrap the other end of the diode around the yellow wire. I did solder all my connections and tape over everything, and bundle the wires back together, but there are other options that can be used to connect these two wires together without having to cut the yellow wire.
    The other thing I did lastnight was disable the factor amber DRL since I added the LED DRL that are in the platinum headlights I did not need or want both of the running together. as one was white and the other was amber. to complete this I used this thread:
    https://www.tundras.com/threads/help-with-disabling-the-orange-drl-on-2016-sr5.16347/
    The module was kinda tricky to find but it is located behind the switch panel to the left hand side of the steering wheel. It is a little black box that is also setting up vertical to the far left in the cavity closest to the driver side door. I did not snap a picture of this one either. It has one plug going into it, IIRC it says something about Daytime Running Lights on the side of it but it cannot be seen from the mounting location. Anyhow, there are is a SMALL gray wire you cut on the first row of wires in the plug, it is in the middle of a white w/ black stripe wire, and a light green wire. NOTE: THERE IS ALSO A LARGE GRAY WIRE IN THIS PLUG. THIS IS NOT THE ONE YOU CUT!!!!!
    Both of these mods worked great once I hooked the battery back up and cranked the truck, no more tire sensor light on the dash, and no more amber DRL's
  7. Dec 5, 2019 at 1:06 PM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    I also did some trim work lastnight. I can’t stand having chrome everywhere. Wish they gave an option to not have chrome all over everything but it gives us tinkerers something to do! Haha EA39649A-5AF1-4838-BFFB-4530E0B52FD5.jpg
  8. Dec 5, 2019 at 1:10 PM
    Looking good!
  9. Dec 10, 2019 at 10:28 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
  10. Dec 10, 2019 at 10:32 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Looks great man!
  11. Dec 10, 2019 at 11:01 AM
    That's a badass looking rig!
  12. Dec 10, 2019 at 11:02 AM
  13. Dec 10, 2019 at 11:28 AM
    VA_tundra_gal
    VA_tundra_gal New Member
    Kimberly
    Botetourt, VA
    2014 Toyota Tundra Crewmax Limited
    6 inch Rough Country lift 20x10 -19 inch Hardrock Affliction wheels 35x12.50x20 Kenda Klever R/T wheels Custom design wrapped Opt 7 rock lighting BAMuffler Standard Dump System
    Thanks!! Bad ass looking ride!!!
  14. Dec 10, 2019 at 1:35 PM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Thanks for the love everyone. I still have a long list of things to do. One thing at a time. I am hoping to get a lot accomplished during my 2 week Christmas vacation.
  15. Dec 10, 2019 at 2:17 PM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    Truck looks great. I love black when someone else owns it. ;) I also like those wheels so much more in all black.
  16. Dec 11, 2019 at 5:21 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Thanks! I still have alot to do to it but, I am very pleased with everything so far. My Tacoma is black, and everything ive owned since then has ended up being black... just wouldn't feel right not having a black vehicle now. my jeep is the only thing that is not black, but if it ever gets repainted it will be. haha.
    GasGuzzler[QUOTED] likes this.
