4.88 or 5.29
Discussion in 'Performance and Tuning' started by turboser91, Jan 30, 2019.
  1. Mar 18, 2019 at 10:17 AM
    #91
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Even though 5.29’s are “too low” for 35s. I wonder if someone like me who does 95% city commuting would see a mpg decrease vs 4.88s. A few extra rpms just don’t seem to bother our engines. But too few rpms definitely bogs down efficiencies
    Warren are you able to estimate mpg of 5.29 compared to the 4.30s yet?
    Toyotoholic and 831Tun like this.
  2. Mar 18, 2019 at 10:30 AM
    #92
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, yes and no. I put just over 1,000 mi on this weekend. On the way to Mojave, bit of a head wind, I averaged somewhere in the 10-11 range. On the way home, driving a little slower and with a shorter stretch of headwind, the computer says 12.8. I've noticed there's a huge difference in mpg between 70 and 75+. I was closer to the 75+ on the way there and closer to 70 on the way home. So, if my calcs are correct, 12.8 mpg is actually closer to 13.8. That's given that a 305 70 r18 is 8.5% larger than the stock 275 65 r18.
  3. Mar 18, 2019 at 10:48 AM
    #93
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yeah the wind signature of our truck is so big, especially when youre lifted and wider as you are. Im sure that does more damage to mpg than the rpms.
    Im on stock tires lifted 2 inches. My mpg goes down from 17 to 14 if i go above 70
    831Tun and 15whtrd like this.
  4. Mar 18, 2019 at 11:07 AM
    #94
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, that's what I've experienced, above 70 = no bueno. I really don't need to go that fast..........on the road.
    Lifted Tundra aerodynamic profile:
  5. Mar 18, 2019 at 1:08 PM
    #95
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There for a sec I had to double check I was in the first gen page...
    lsaami, Darkness, Brown Bear and 3 others like this.
  6. Mar 18, 2019 at 1:14 PM
    #96
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sorry, I've got a 3rd gen. Thanks for pointing out my error.
    bmf4069[QUOTED] likes this.
  7. Mar 19, 2019 at 8:19 PM
    #97
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    2006 double cab 4x4
    35” tires=4.88
    37” tires=5.29
    (30” tires=3.92 stock ratio)
    first gen v8’s are turning somewhere around 2100-2200 rpm (give or take) at 70mph on stock tires.
  8. Mar 20, 2019 at 8:01 AM
    #98
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Its not that hard to clear 37s with LT. You need upper heims, push the lowers all the way forward and do the alignment with the uppers. That will clear the rear of your fenderwell and you won't have to do a body mount chop. Then, take a bottle jack and wood and bend/push the inner fender up about 2".
  9. Mar 20, 2019 at 8:07 AM
    #99
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Where in this particular area of the inner fender you're referring too? Curious on that part.
    831Tun likes this.
  10. Mar 20, 2019 at 8:08 AM
    #100
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Alex. I'm having problems with too much camber and a lack of good alignment techs in this area. So, I might have to upgrade to heims. The 37s should arrive today.
    You're going to T2S I hope?
    GodlessPro, joonbug and dcsleeper408 like this.
  11. Mar 20, 2019 at 8:10 AM
    #101
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The pinch weld gets "folded" over and the top of the inner fender gets moved up. It was helpful to actually "see" what Alex did. So, you'll have to hook up with him for a run
  12. Mar 20, 2019 at 8:11 AM
    #102
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The metal part of the inner fenders. When you install long travel you have to ditch the plastic.
    Yeah I'll be there Wed - Sun. Let me know when you install the 37s. I'm currently debating with myself 4.88 vs 5.29...
  13. Mar 20, 2019 at 3:24 PM
    #103
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There's those pesky 2nd/3rd gen guys again, hijacking our little first gen discussions.
  14. Mar 20, 2019 at 3:40 PM
    #104
    Professional Hand Model
    Hand Protectors
    Time for your not a first gen meme!
    Darkness likes this.
  15. Mar 20, 2019 at 6:40 PM
    #105
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  16. Apr 20, 2019 at 11:45 AM
    #106
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    All this info and still I have one question...who can just make this decision for me? 2017 crewmax going up to 37’s, putting in lockers, should I regear and if so 4.88 or 5.29? I almost never tow, I drove mostly highway 80+mph, I will likely supercharge in next year. 4.88 seems plenty to me, but am I missing something? Will be breaking lose all the time after I supercharge? Aside from all the times I am doing it on purpose?
  17. Apr 20, 2019 at 11:57 AM
    #107
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    If it were me, I’d do 4.88. I went 5.29 mainly because I tow a heavy trailer and needed to be as close to stock as I could with my 37’s, plus I live at a high elevation
    tbrown[QUOTED] likes this.
  18. Apr 20, 2019 at 12:25 PM
    #108
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I'm putting 5.29's on in the next few weeks. My tires are ~ 34" (275/65/20) I drive mostly back roads and tow occasionally. I went back and forth on this many times, but in the end I want it to make a difference that is purposeful, and noticable on a daily basis. I've added a lot of weight with sliders, bedliner, rack, TONS of sound deadener, and gear. As it is stock, I never use 6th gear (even on the highway it won't stay in 6th for anything other than downhill) so...
    4.88's would be back to stock, but with the additional weight of mods and tires, the 5.29's were unanimously recommended by 5 different, unbiased, professional opinions, whom had no hesitation to go with the taller gear, and explain why. The answer is: You are simply putting the truck into it's powerband 100% of the time, and the transmission is happiest when it's in the powerband.
    In the end it is roughly 400-500rpms different from stock... for the 5.29's
    tundra_20, Overisland and tbrown like this.
  19. Apr 20, 2019 at 12:29 PM
    #109
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    And just like that I’m torn again Lolololol...ok question, on 5.29 running 95 mph will it love it or be screaming rpms? Real world scenario here
  20. Apr 20, 2019 at 3:52 PM
    #110
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    If you really drive 95mph, go with the 4.88's. I'm under 55mph 90% of the time I drive...
    tbrown likes this.
  21. Apr 20, 2019 at 3:57 PM
    #111
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    I hang around 85-90 when traffic opens up. If the 4.88 are better for top end that helps a ton
    Toyotoholic[QUOTED] likes this.
  22. Apr 20, 2019 at 4:07 PM
    #112
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    4.88 are the way to go for those speeds. You 6th gear is .58 overdrive... You'll be fine.
  23. Apr 20, 2019 at 5:46 PM
    #113
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    According to calculators, stock is almost dead nuts the same as 37s and 4.88s.
    This of course doesn’t account for the weight of the tires/mods and the significant wind drag added when the truck gets taller and taller.
    5.29s with 35s sounded good to me at first, but it is considerably more rpms than stock for every given speed
  24. Apr 21, 2019 at 5:56 AM
    #114
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They're back! Get outta the first gen section with your behemoths and what not!
    :D
  25. Apr 21, 2019 at 6:16 AM
    #115
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    Didn’t even realize this was in 1st gen section, it was best thread i could find for a gear comparison. I haven’t seen a good first gen running around in a while, any of y’all in middle tn?
    Toyotoholic and Darkness like this.
  26. Apr 21, 2019 at 6:56 AM
    #116
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wow im terrible too
  27. Apr 21, 2019 at 7:07 AM
    #117
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Guys, guys :rofl:
  28. Apr 21, 2019 at 5:08 PM
    #118
    Hand Protectors
  29. Apr 22, 2019 at 7:56 AM
    #119
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I did the math, purely on diameter, the diff's gears should be about 4.93 to get back to original power band. Of course this doesn't account for added load such as mass of the tires, added rig weight and rolling resistance. If you are going 37's, then go with 5.29. If you are going with 35's, stay with 4.88. In my opinion, 5.13 is ideal for mpg, performance and top end, but no one makes it for our truck.
    Jsena likes this.
  30. Jun 10, 2019 at 6:58 PM
    #120
    CallMeD
    CallMeD New Member
    5.29 gears installed. Just noticed the truck stalls (feels like I’m hitting the speed governor) when the speedo shows 90mph. I recreated the failure a few times now. Spoke to Keith from DirtyDeeds and pulled the ABSII fuse and the problem seems to go away. Trying to figure out what to do from here. Has anyone come across this issue? I have a 2010 Tundra Dbl cab 4x4.
