4.7L Performance Upgrades?
Discussion in '1st Gen Tundras (2000-2006)' started by MSCRUGGS61, Jan 23, 2019.
  1. Jan 23, 2019 at 4:57 PM
    MSCRUGGS61
    MSCRUGGS61 [OP] New Member
    2002 Tundra 4x4 Limited TRD
    I looked around but couldn't find any threads that summarize the best set of HP/Torque upgrades for the 4.7L Gen 1 motors. Specifically the 2002. Anyone have any suggestions?
    because_wumbo-truck likes this.
  2. Jan 23, 2019 at 5:27 PM
    Whocares
    Whocares Member
    Headers
  3. Jan 23, 2019 at 5:29 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    get jba long tube headers, throttle spacer. good free flowing exhaust to start
    theblurry1 likes this.
  4. Jan 23, 2019 at 6:10 PM
    Casper421
    In the woods
    06 DC
  5. Jan 23, 2019 at 6:18 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    It depends on how much you are willing to spend, I am enjoying my JBA short tube headers, LSD, and rear sway bar. Decent power gain, and much better application of total power.
    Black Wolf likes this.
  6. Jan 23, 2019 at 8:36 PM
    MSCRUGGS61
    Well then. It appears that Dirty Deeds is in San Diego. And I'll be damned. So am I. Gonna give them a visit.
  7. Jan 23, 2019 at 9:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes, visit him. Ask for Keith.
  8. Jan 24, 2019 at 10:09 AM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Switch it out for a 5.7l
    wandering_boy likes this.
  9. Jan 26, 2019 at 7:07 PM
    stevechumo
    stevechumo New Member
    speedtre and Brown Bear like this.
  10. Jan 26, 2019 at 7:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why? Swapping for an LS is a third of the cost and makes more power.
  11. Jan 27, 2019 at 5:32 AM
    Professional Hand Model
    Hand Protectors
    What is ‘LS’?
  12. Jan 27, 2019 at 6:08 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's a Chevy motor, you know the American brand with the French name? I believe it stands for "Le Shitty"
  13. Jan 27, 2019 at 1:45 PM
    stevechumo
    I'd stick to the UZ family. Swapping may sound cheap at first, but it'll open up a can of worms and may not be cheap at the final stage.
    Tundyfundy likes this.
  14. Jan 28, 2019 at 1:57 PM
    MSCRUGGS61
    Winning8 and Black Wolf like this.
  15. Jan 28, 2019 at 2:17 PM
    MSCRUGGS61
    LSD = Limited Slip Diff? Is your truck a 2WD or 4WD? Mine's 4WD & so far I've not felt need to add LSD too. Hell, I barely have oppty to use the 4WD. Lot's of long nasty dirt roads in Baja, but not much of a rock climber (at least not yet).
  16. Jan 28, 2019 at 3:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Remote turbo setup?
  17. Jan 28, 2019 at 3:43 PM
    15whtrd
    15whtrd Mr. Blonde
    Long tubes aren’t legal in CA either. Only for off-road use.;)
  18. Jan 28, 2019 at 4:29 PM
    Danimal86
    Daniel
    Sacramento, CA
    Wouldn't show up on a visual inspection.
  19. Jan 28, 2019 at 4:32 PM
    15whtrd
    15whtrd Mr. Blonde
    I know recently they got a little more strict. But now they only hook up the OBD. But still walked around my wife’s car making sure. I had to remove her Volant intake as it’s not CARB legal here. And on my previous truck they were looking underneath making sure I didn’t modify catalytic converter‘s.
    Darkness and MSCRUGGS61[OP] like this.
  20. Jan 28, 2019 at 6:11 PM
    Whocares
    Whocares Member
    You can have Keith from DD to create mid pipes for you that would pass emissions.
    MSCRUGGS61[OP] likes this.
  21. Jan 28, 2019 at 6:13 PM
    stevechumo
    For you in Ca, install the turbo, and remove it every 2 yrs for smog check. Lol.
    tacoguybill and Darkness like this.
  22. Jan 28, 2019 at 7:01 PM
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
  23. Jan 28, 2019 at 8:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The kit in the installed pic at the bottom isn't the same. That turbo is from Turbonetics and its aimed in a different direction. If they're using pics of somebody else's work as an installed pic that scares me.
  24. Feb 7, 2019 at 7:47 PM
    MSCRUGGS61
    I guess I need to start a thread about California Legal Performance Mods eh?
  25. Feb 8, 2019 at 6:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sure. You can title it "Behind enemy lines". ;)
  26. Feb 8, 2019 at 1:15 PM
    Hand Protectors
    Denso 12 hole injectors for better mid range power/torque and higher gear shifting points.
  27. Sep 15, 2019 at 1:59 PM
    Maxwelltollefson
    Maxwelltollefson New Member
    Maxwell
    I’m running that kit above. You can find my build by googling turbo 03 sequoia. Should pop up. I go over some of the good/bad stuff.
  28. Sep 15, 2019 at 2:50 PM
    Rex Kramer
    Georgia
    4WD, and the LSD is great for added traction while in 2WD.
  29. Sep 15, 2019 at 2:56 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If you really in cali, then you can't do shit to it.
    buy newer 5.7 is your only option.
  30. Sep 15, 2019 at 3:02 PM
    15whtrd
    15whtrd Mr. Blonde
    Still a few things he could do. Gearing, 12 hole fuel injectors and coolant throttlebody bypass mod. I’ve heard the fuel injectors really make it nice. And gearing always makes the truck feel good.
    Tundyfundy and Rex Kramer like this.
