4.30 rear end gear?
Discussion in 'Performance and Tuning' started by awq735, Apr 9, 2019.
  1. May 20, 2020 at 1:50 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I agree with StoneyWV. I was looking at Tundra and Ford Super Duty F250 for potential purchase, obviously Tundra won out. Looking at the two trucks:
    Ford: 6.2 liter engine, 6 speed tranny, 3.73 axle ratio
    Tundra: 5.7 liter engine, 6 speed tranny, 4.30 axle ratio
    By using the transmission gear ratios with the axle ratio to get the overall ratio, it was surprising how close the two trucks are.
    Ford: 1st 15.55, 4th 4.25, 6th 2.57
    Tundra: 1st 14.32, 4th 4.30, 6th 2.53
    The Ford is bound to get less fuel economy, .5 liter larger engine displacement, and 500 to 800 pounds heavier.
    Most of the newer half ton trucks are getting better fuel economy with one or more of the fowling.
    Smaller displacement turbo charged engines.
    Engines with cylinder deactivation.
    Engines with start stop technology.
    More tranny gears, and maybe higher axle ratio.
    I wanted to avoid all of those things (not necessarily more tranny gears) both the Ford and Tundra did avoid them. But the Tundra just had more of what I needed and wanted and of course reliability, besides I really don't need a 3/4 ton truck. I didn't want to wait for the new Tundra as I would have been afraid to buy for a few years.
    So far I love this truck but only had a couple of months and haven't yet pulled my boat, although I expect to be impressed.
    dan_osms.io and Petrone like this.
  2. May 20, 2020 at 2:40 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Get the pedal commander you have no idea what the 5.7 engine can really do and it wont void warranty...
  3. May 20, 2020 at 2:42 PM
    Tundra_power
    Nick
    you made a good choice 10 years from now you will still get what you paid for 2020 is probably the best year for resale if they stop making the 5.7 in 4th gen
  4. May 20, 2020 at 3:08 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Oh and one other thing I forgot to mention. The use of direct fuel injection, that also has a tendency to be troublesome. I'll take more old fashion simplicity any day!
    SomeGuy4 likes this.
  5. May 20, 2020 at 3:11 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    We just moved about 20 miles up into the mountains and I wanted to improve my mileage. We bought a VW Beetle TDI that gets 45-50 mpg. Now we have a reliable great gas mileage car and a bad ass real mans truck! Great combination with good combined mpg.
  6. May 26, 2020 at 8:01 PM
    Frizzen
    Frizzen New Member
    Poop Green Turd Pro
    To restate what several have said regarding mileage, I think what you need to look at is final drive ratio (i.e. transmission and rear gears) and the resultant engine RPM at highway speeds. My Tundra with 4.30 gears shows pretty much the same RPM at 70 as my Ford did with 3.55s. In fact, in my my short ownership of the Tundra, I've found top gear to be too steep for even a lighter trailer and it best to lock out 6th gear while towing to keep the engine from lugging and shifting back and forth between 5th and 6th (mine does this even in towing mode). In theory and as an added benefit, the lower gears (numerically higher) in the Tundra should improve mileage around town where you are accelerating from a stop and thereby getting the engine up into its power band sooner. I think this to be especially true with the Tundra in that I believe it is running a pretty low first gear in the transmission, which combined with 4.30s makes for low gearing from a stop.
    As someone mentioned above, Ford is doing many of the same things with a 10-speed transmission. I had a loaner Lariat with the 10-speed and the big Ecoboost for a couple of months when my last Ford was in the shop. That 10-speed really kept the turbo Ford in its happy spot pretty much all the time when in the throttle. That Ford setup was super fast, and would slip the tires a little on up-shift all the way up to 40-50 mph on many streets.
  7. Aug 17, 2020 at 10:32 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I just towed my daughters Gx470 that was packed to gills including drivers seat from Ohio-Florida. Tundra platinum crew max bed loaded, cab loaded with only room for driver. I averaged 9.8-10.3 mpg with a steady speed of 70-75 most of the way. I had tow haul locked in and never had a need for power. I’ve towed a lot of things from coast to coast and the Tundra is right up there with the best of them. Ram constantly hunted for gears. I know I was packed over weight but really didn’t have much choice. It was either load it or throw it away. I must say the Tundra really impressed me from smooth take offs, sudden abrupt stops due to a trailer issue, to going through the mountains it was rewarding knowing I was in a Toyota that had power. The best of both worlds. Oh yea I’m running 10 ply 315/70/17 ridge grapplers & I’m also stock height on Rock Warrior wheels. So there’s extra tire to turn.
  8. Aug 19, 2020 at 7:27 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Personally... I like the 4.30 gears because it helps alot with a taller tire.
    I know some guys go straight to a 4.88 or 5.29 gear when running 35-37" tires... but after a couple weeks on my 35's, I honestly see no need for more gearing. The 4.30's handle the bigger tire just fine. 37's might be a different story... but I think 35's and 4.30 gears are still a safe combo.
    I also remember a time that gear swaps were unheard of... and guys were running around on 44" Super Swampers with 3.08 gearing. :rofl:
    Rex Kramer likes this.
  9. Aug 19, 2020 at 7:35 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I like my 4:30, especially with double over drive.
  10. Sep 13, 2020 at 5:58 PM
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    I love the 4:30s. Even after going up to a 34” tire It still rips my 5000lb+ boat around with ease.
    Ely010606 likes this.
  11. Sep 13, 2020 at 6:22 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    No issues w/37's & 4.30 gears after 10k miles.
    Nannies off exclusively.
    S4 on the stick around town.
    Currently 12.3mph interstate travel @75mph(GPS) w/400lbs in the bed+ driver and Transferflo 46g tank.
    That was the average last Moab trip. Temps in the 100's if that matters.
  12. Sep 26, 2020 at 2:28 PM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    Anyone know the gearing in a 2012 4.0 V6 5SPD tundra? no towing package not even a hitch lol
  13. Sep 26, 2020 at 2:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There should be a code on a white sticker on the driver side door jamb. A quick Google search of the code should give you the info.
  14. Sep 26, 2020 at 2:38 PM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    My dad has a 2019 RAM Laramie with the tow package and my brother has a 2020 RAM REBEL. I'm at 14.7 almost entirely city and they are usually pretty much the same, with the REBEL usually actually being work than my 2018 Tundra. I was surprised. I agree that the numbers they publish aren't very accurate. I know the feds let them add 1mpg for things like stop / start. My brother's REBEL even has the 43VOLT e-Torque thing. (One thing that does is make the stop start unnoticeable. )
  15. Sep 26, 2020 at 2:46 PM
    Cg13055
    South Florida
    I'm a little confused on which code it could be
  16. Sep 26, 2020 at 2:51 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm going to guess it's a 3.91 ratio.
    Cg13055[QUOTED] likes this.
  17. Sep 26, 2020 at 2:55 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cg13055[QUOTED] and Ely010606 like this.
  18. Sep 26, 2020 at 3:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cg13055 likes this.
  19. Sep 26, 2020 at 5:37 PM
    #49
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    Wow, you have the same exact truck i have right down to the tow mirrors. and I'm towing a 25' KZ sportsman BHS, I agree it tows incredibly awesome, Mine is a 2020, traded in my 2013 Tacoma back in July for my Tundra. Best thing i ever did. Happy camping
    awq735[QUOTED][OP] likes this.
  20. Nov 21, 2020 at 7:53 AM
    #50
    Cg13055
    South Florida
