3rd Gen Tuner
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Mar 5, 2022.
  1. Sep 25, 2022 at 10:52 AM
    #241
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    So why can't you use 87 octane and make more power? I mean, is it at the limit of what can be had with the lower octane? What does VR offer?
  2. Sep 25, 2022 at 1:29 PM
    #242
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    Sorry I’m not a tech guy at all and have no way to answer your question. I have the jb4 and just use it as advised by them. I would say if you send them an email they will answer any of your questions. Go to their website and initiate contact via email. I don’t have the VR so again no answer for that. Hopefully someone in this thread can actually help…:sorry:
  3. Oct 14, 2022 at 3:54 PM
    #243
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    May seem a dumb question, I want to order a JB4. Do you have to disconnect your android auto every time you change maps ect. Because of the blutooth?
  4. Oct 14, 2022 at 3:55 PM
    #244
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Not sure. I don't use AA.
  5. Oct 14, 2022 at 5:05 PM
    #245
    JoeInMinn
    2022 1794 Trd
    Jb4 reached out it doesn't effect it.
    eddiefromcali[QUOTED] likes this.
  6. Nov 3, 2022 at 9:36 AM
    #246
    Hozzie
    Hozzie New Member
    2022 Tundra SR5 TRD OR
    Thanks to those with more knowledge than I about all of this. Waiting on my truck, but the JB4 and PedalCommander will be here waiting when it does get here in a couple of weeks. This won't be a DD, so figure might as well have fun with it. Will just stick to 93 octane as I am too lazy to keep up with mixing, but am sure it will still be plenty of power for me while tooling around doing chores.
    eddiefromcali likes this.
  7. Nov 3, 2022 at 10:39 AM
    #247
    mass-hole
    mass-hole New Member
    Couple things going on.
    1. Because, as you increase boost/power over stock you are also increasing cylinder pressure which is widdling down on the overhead you have with the 87 octane. There is not a lot of overhead available to increase boost with 87 over the stock tune. In fact, if you look in the Ecoboost tune, they will limit maximum boost as it detects lower octane. This is why 3.5L Ecoboost pick up like 35 WHP and like 70 ft-lbs of torque just switching from 87 to 93 octane on the stock tune. One the top Ecoboost tuners claims these numbers from his auto octane tune based on octane, so virtually zero gain running the tune on 87:
    87 octane - 0-10whp
    89 octane - 20-30whp
    91 octane - 30-45whp
    93 octane - 35-55whp
    E30 (mix of 93 and e85)- 45-70whp
    2. Because the JB4 is spoofing the engine into running at higher air loads(boost), the engine is continuing to run the ignition timing as if it is at lower boost, which is more advanced. So in order to allow the timing to not become overly advanced, you have to offset it with additional octane. below is a screen shot of one of the boarderline spark tables in my Ecoboost tune as an example. If you are accelerating at 3000 RPM, and the PCM thinks its at an air load of 1.3, it wants to target a spark angle of 4.5* (the green box). However, you have the JB4 increasing the boost without the PCM knowing, so in reality the engine is actually at an air load of 1.6. Well at 1.6 it should really be at -.8* of spark, 5.3* less advanced. So you have to run a higher octane fuel to make up for that 5.3* of timing difference.
    Taikowaza and ryanwgregg like this.
  8. Nov 3, 2022 at 10:50 AM
    #248
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I appreciate the explanation as it may help other people. I was just looking for a year or no, if we were already at the limit of 87. As for your eco, so if you run 87, is it detuning it from what the truck is rated at stock?
  9. Nov 3, 2022 at 11:20 AM
    #249
    mass-hole
    I would say yes, you are about at the limits of 87 on the stock tune. The iForce and Ecoboost are extremely similar in both power and specs(same compression ratio for example).
    No, Ford always rated the Ecoboost on 87. So they increased in power on higher octane. If you look at the specs on the 2015-2017 Navigator, they rated them on 93 octane. Same engine as my 2014 F150 but my truck was spec'd at 365hp/420 tq and the Navigator was 380/460.
    The 2017-2020 3.5 Ecoboosts allow for a much larger increase than my truck and its across the entire RPM range. So they can pick up a huge amount of torque down low as well as a good amount of HP up top. It was rated at 375hp/470 torque, but on the Dyno they make 350-360 whp on 93 vs ~320 on 87. This is consistent across multiple tuners that have dynod the stock trucks. So basically, on 93, the Ecoboost is making nearly as much HP at the wheels as its rated for at the crank.
  10. Nov 3, 2022 at 11:26 AM
    #250
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    Just got my JB4 and finally got to test with the 91 tune and wow what a difference. Would there be any benefit doing an exhaust, intake, etc while running the JB4? Or would you need a specific tune to gain anything?
    Taikowaza likes this.
  11. Nov 3, 2022 at 11:51 AM
    #251
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. It's nice that Ford stock tune would increase power with higher octane. In 2014 a friend had a Silverado w/V6. I was looking up specs and read that on E85 it went up in hp/tq. But in my 14 Tundra 5.7, E85 made less power. Yrs ago I drove my bosses' 13 Ecoboost, and that small bump in tq but at alot lower rpm vs my V8 felt better when pulling a loaded trailer. I will eventually get a JB4 or something for my 22 but maybe not if I have to run premium all the time.
  12. Nov 3, 2022 at 11:11 PM
    #252
    dutch2112
    dutch2112 New Member
    2023 Limited hybrid Trd
    35” Falken Wildpeak AT3, 17x8.5 method 305 nv, trd lift kit, trd pro grill, trd exhaust
    How about the j b4 alone on a Hybrid? Is that a thing? If so anyone have such
  13. Nov 7, 2022 at 8:33 AM
    #253
    Hozzie
    Hozzie New Member
    My truck was delivered on Friday. For those that know way more about this than I do (which is just about everyone) is there a break in period where I shouldn't run the JB4 and Pedal Commander. I have both ready to put on, but don't want to create issues if I need to run for a thousand miles or so before adding them so things can wear in as the factory expects?
  14. Nov 7, 2022 at 8:35 AM
    #254
    eddiefromcali
    Eddie
    100% Stock
    Slap it on and leave it on map 1. Pedal commander won't hurt anything so install that and adjust to your liking. Think I have mine set at City -3
    Taikowaza, roboots21 and Hozzie like this.
  15. Nov 7, 2022 at 8:47 AM
    #255
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    I agree here. You can even have both of them disabled if you wanted to, but have them installed so whenever the desire hits, you can enable them. That being said, I'd do just as Eddie said. The Pedal Commander will become how you like it. I know some people run Sport (which is too much for me) and others run City (I'm at City -1).
  16. Nov 7, 2022 at 9:10 AM
    #256
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    Why have both pedal commander and JB4?
  17. Nov 7, 2022 at 1:16 PM
    #257
    eddiefromcali
    Eddie
    100% Stock
    JB4 does not address the initial dead pedal area. The PC will fix that issue and the JB4 will add the additional boost once you get on the skinny pedal
  18. Nov 7, 2022 at 5:31 PM
    #258
    Hozzie
    Hozzie New Member
    Well, they're both installed and nothing melted down, so I guess step 1 is down. Seems the app defaulted to Map 1 so I changed it for now to Map 0 as I am guessing the dealer filled up with the cheapest thing he could. Once I fill up the first time with 93 I will switch over.
    Maybe a dumb question, but I don't like to assume with these things. I am guessing the JB4 will start back at the setting you left it at? I won't be monitoring things with the app on a normal basis or changing Map Settings so I am assuming it's kind of set it and forget it?
  19. Nov 7, 2022 at 5:39 PM
    #259
    eddiefromcali
    Eddie
    100% Stock
    Correct, settings are saved
    Hozzie likes this.
  20. Nov 25, 2022 at 6:18 PM
    #260
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Anyone interested in buying my JB4? I’ve had it installed for 2 weeks. Paid $678 with the Bluetooth kit
    Jr3volution likes this.
  21. Nov 27, 2022 at 5:44 PM
    #261
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Didn't like it? I see you have a Pro, did it make any noticeable difference on it?
    RickyBobbysTundra likes this.
  22. Nov 27, 2022 at 6:26 PM
    #262
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    I like it and yes it made a noticeable difference. It’s fun in sport mode since the truck stays in a lower gear. You stay in the power more.
    I’m willing to let it go if someone wants it. If not then I’ll keep it. Figured if someone wants it they can save some dough.
  23. Dec 9, 2022 at 10:05 PM
    #263
    charlieyankee88
    charlieyankee88 Taco to Tundra
    22 SR5 TRD OR
    TRD 3" Lift, 18” Vision Manx 2, BFG KO2, Fas-Top
    Can you elaborate on this? I am looking at one for my SR5, but debating the Bluetooth kit or not. How do you change MAPs without the app?
  24. Dec 12, 2022 at 9:14 AM
    #264
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    You would have to set it up first via the app. Put it in the mode you want and then set the MAP and it should save it for that mode. I purchased the BT version. Afterwards I don't even turn the app on unless I want to watch the gauges or make changes.
  25. Dec 12, 2022 at 9:43 AM
    #265
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
    Has anyone run map 1 in tow haul +?
    It seems to be acting strange.
  26. Dec 13, 2022 at 5:39 AM
    #266
    roboots21
    Whatever map you run in 'Normal' mode is the same map that will be used for 'Tow Haul' and 'Tow+'. That being said, I've no issues on Map 1 or Map 2 in any modes.
  27. Dec 14, 2022 at 10:19 AM
    #267
    eddiefromcali
    Eddie
    100% Stock
    map 1 -5 in tow or tow+ work just fine
  28. Dec 14, 2022 at 10:22 AM
    #268
    jeosbor1
    jeosbor1 New Member
    North Carolina
    First time using the 93 octane tune (Map 3), while cruising down the highway I notice stutter. I don't feel this with the stock tune or Map 2. Any ideas?
  29. Dec 14, 2022 at 10:24 AM
    #269
    eddiefromcali
    Eddie
    100% Stock
    email BMS. I noticed stutter and they had me activate an option within the app. Theyll likely ask you for data logs
  30. Jan 4, 2023 at 11:10 AM
    #270
    MateoAirborne
    MateoAirborne New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    How did the equipment turn out? Are you happy with your decision? Any pros and cons?
    ryanwgregg likes this.
