3rd Gen Tuner
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Mar 5, 2022.
  1. May 10, 2022 at 8:51 AM
    #121
    jpmock
    jpmock New Member
    Jesse
    2022 White Tundra XP
    BONE Stock
    I did not read through every post, but if this has not been mentioned, I will just throw it out there...
    A lot of folks are saying the piggyback tuners cannot be detected and that it is like a ghost. This is very well true, but I highly doubt anyone here can 100% confirm this, unless you're a Toyota engineer. I am a software developer and have flash tuned GM's for past 20 years. I know some of the new vettes can detect just about any changes you make and void warranty.
    It is very possible they can and do detect changes to the boost and afr, timing etc.
    I wouldn't be surprised if Toyota is logging these things (boost levels and other telematic data) and can at least infer something was modified prior to a failure of some sort...
    I'm just making some possible assumptions. I could be totally wrong, but just saying its not out of the realm of possibility.
    southdunes likes this.
  2. Jun 8, 2022 at 11:25 PM
    #122
    Hawaii_2022TundraTRD
    Hawaii_2022TundraTRD New Member
    2022 Toyota Tundra Trd Sport
    Does the JB4 tune also increase top speed?
  3. Jun 9, 2022 at 6:10 AM
    #123
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    Negative.
  4. Jun 9, 2022 at 7:19 AM
    #124
    mass-hole
    mass-hole New Member
    But with these devices it doesnt know there is more boost. The device is only allowing the PCM to see the boost it wants. As far as the truck knows, everything is stock and it is just adjusting the fuel trims.
  5. Jun 9, 2022 at 8:52 AM
    #125
    OnThaLake
    OnThaLake New Member
    I had JB4 on my GTI. You are correct that the ECU is being fooled into making more power, and the OEM doesn't (didn't) look for a piggyback.
    I think, if they wanted to, they could definitely determine if the vehicle had/has (via telematics) a piggyback. They could check acceleration rates and possibly traction control duty. The JB4 on my GTI made a huge difference in acceleration and it needed TC to be more active for longer than at stock levels. You could say those 2 metrics could identify a piggyback.
    I know these ECU keep track of acceleration rates, even my old Nissan Titan ECU could display rates of acceleration when I had it tuned, my truck became about 1 sec faster from bolt-ons and ECU tuning, I was able to see the Delta improvement through the ECU time-stamping it's own speeds.
  6. Jun 9, 2022 at 10:26 AM
    #126
    mass-hole
    That would be hard to prove. What if you told them you had removed your tailgate, spare tire, and rear seats, and the truck was 500 lbs lighter?
    montera.built likes this.
  7. Jul 27, 2022 at 6:14 PM
    #127
    TundraCanada
    TundraCanada New Member
    2022 Tundra TRD
    Does the JB4 remove the factory governor while in use?
  8. Jul 27, 2022 at 6:15 PM
    #128
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Does not
  9. Jul 27, 2022 at 6:27 PM
    #129
    TundraCanada
    2022 Tundra TRD
    Ok, thank you
  10. Jul 27, 2022 at 6:37 PM
    #130
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    So a few of you have had the JB4 for a couple months now let’s hear some feedback! Y’all still like it? Worth the purchase? TIA.
  11. Jul 27, 2022 at 6:52 PM
    #131
    eddiefromcali
    Eddie
    100% Stock
    I've had mine since mid March and I love it. I've added their ethanol sensor kit and have discovered I can go up to E50 blend and not run into any fueling issues. I dont keep it at E50 since the stock timing tables don't offer any advantage over E30 or around there so I keep a blend of E30-40 in my tank and use Map 5 on the JB4. Absolutely no regrets with the purchase. I've taken it off a few times to take the truck in for service/recalls and can get it done in 10 mins or less.
  12. Jul 27, 2022 at 7:46 PM
    #132
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    For me it is worth it. Love it. Can set certain MAPs with different drive modes.
    Sparky916[QUOTED] and jeosbor1 like this.
  13. Jul 28, 2022 at 7:58 AM
    #133
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    If there is an updated MAP, does JB4 offer free updates?
  14. Jul 28, 2022 at 7:59 AM
    #134
    roboots21
    All firmware updates have been free/downloadable and simple to flash.
    jeosbor1[QUOTED] likes this.
  15. Jul 28, 2022 at 8:24 AM
    #135
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    This is good to hear. So we for sure know there’s no way the dealer can know we had the JB4 on there if we were to run into issues?
  16. Jul 28, 2022 at 8:53 AM
    #136
    mass-hole
    I suppose it could log how wildly far off the fuel trims are and maybe they could make the connection. But other than that the PCM is not aware of an issue otherwise I imagine you would get CEL's.
    OnThaLake likes this.
  17. Jul 28, 2022 at 9:17 AM
    #137
    vosaeroplane
    2022 Tundra SR5
    I've taken the JB4 off twice and took it into the dealer twice for those two recalls. No issues that I've run into. Same with my pedal commander. It's all plug and play.
  18. Jul 28, 2022 at 9:32 AM
    #138
    Jeb80
    Jeb80 New Member
    anyone put this on a hybrid yet?
    MateoAirborne likes this.
  19. Jul 28, 2022 at 9:45 AM
    #139
    eddiefromcali
    Eddie
    100% Stock
    They can always pull the data but the truck doesn't know it's making more boost (JB4 intercepts that info and reports a lower boost level) but they will notice the wastegate command. The JB4 doesn't leave a footprint but that doesn't mean that the data left behind when a CEL is set off. For day to day stuff at the dealer it seems like it doesn't raise any red flags.
    And this is assuming the fuel trims are off...which they're not even at E40. Once we get into E50, we start seeing the fuel trims rise in order to compensate for the extra ethanol. I've been testing with BMS and this has been what we've found so far. No real need for this high of a mix though since the oem timing tables probably can't take full advantage of the added E.
  20. Jul 28, 2022 at 10:04 AM
    #140
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Still waiting on a speedo correction from Hypertech or another company. I'm not sure why it bugs me so much, but I'd like to correct it. More so for the mileage tracking, I guess.
    jeosbor1 likes this.
  21. Jul 28, 2022 at 11:10 PM
    #141
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    Hypertech is working on a speedo calibration when I asked them back in June.
    Rwaters[QUOTED][OP] likes this.
  22. Aug 2, 2022 at 6:21 AM
    #142
    montera.built
    Jordan
    Also forgot to ask, people that are running this, do feel a big difference just normal-ish driving? I know the gains are significant at WOT but I'm curious if it's a noticeable difference just driving around town, up steep grades, etc.
  23. Aug 2, 2022 at 6:25 AM
    #143
    eddiefromcali
    Eddie
    100% Stock
    Only feel a difference when boost kicks in.
  24. Aug 2, 2022 at 7:18 AM
    #144
    roboots21
    Agree, but to piggyback on this you feel it less in normal city driving. If you drive up steep grades and such, you will definitely feel it more. So normal-ish driving, not so much.
  25. Aug 2, 2022 at 7:30 AM
    #145
    montera.built
    Jordan
    I'm on 37's so I'm in boost probably more frequently than the next guy. So I'm thinking this will be perfect.
  26. Aug 2, 2022 at 7:34 AM
    #146
    eddiefromcali
    Eddie
    100% Stock
    It'll drive like stock off boost and at very low boost levels but once it has some boost readings and it can trick the ecm into commanding more psi, thats when you feel the bump in power. Being that youre on 37s, youll likely feel the difference a bit more than me thats still on stock tires and doesnt go into boost as easily/early because of the low load on the engine. Consider throwing some E85 in the tank and really take advantage of the extra psi in their hottest map...the truck loves E
    montera.built and roboots21 like this.
  27. Aug 2, 2022 at 8:01 AM
    #147
    montera.built
    Jordan
    Love it. Used to run E85 on some boosted cars back in the day and damn it made a huge difference.
    eddiefromcali[QUOTED] likes this.
  28. Aug 2, 2022 at 8:11 AM
    #148
    eddiefromcali
    Eddie
    100% Stock
    I got BMS' ethanol sensor kit when it came out and use that to get an E40ish blend. You get E content readings in the JB4 app and makes mixing easy since you know the actual E content in your tank now.
    Taikowaza likes this.
  29. Aug 2, 2022 at 3:33 PM
    #149
    2022-1794-4x4
    2022-1794-4x4 New Member
    Question for anyones who's listening. You CAN run 87Oct with this, you’ll just see no results, right? Meaning, 87 won’t ping or mess anything up, I’ll just have no power gains form the tuner while using 87, correct? Thanks.
  30. Aug 2, 2022 at 3:58 PM
    #150
    eddiefromcali
    Eddie
    100% Stock
    You have to understand what this box is..its simply a smart boost controller. It does not have different timing tables and does not control anything other than manipulating map sensor readings. Having said that, it COULD cause issues if you run a map intended for higher octane (AKA producing higher boost). If you run 87, you could leave the box in the stock map until you fill up with premium or mid grade, totally up to you. You wont see any gains on the stock map, obviously, but you might be able to run a map intended for a bit higher octane and I wouldnt think that the truck would hurt itself as it is still limited to its oem timing tables, knock retard detection and safety nets. I havent seen ANY pinging on any of the maps (No KR) I've logged, tells me that the map is safe and not pushing the limits of what the fuel can handle...but your results might vary.
    Are you simply asking in case you ever have to run 87 or do you plan on buying the JB4 and just running that gas 24/7?
    Taikowaza and montera.built like this.
