3rd Gen Tuner
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Mar 5, 2022.
  1. Jan 13, 2023 at 11:51 AM
    #271
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Still interested in getting rid of it? I have been considering one for my pro.
  2. Jan 14, 2023 at 2:50 PM
    #272
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    I think I’m going to wait. JB4 said they’re coming out with an updated tune for hybrids. I’d like to try that when it comes out.
  3. Jan 15, 2023 at 3:40 AM
    #273
    Decius615
    Decius615 New Member
    Phillip
    2022 Toyota Tundra 1784 Edition
    Did they say when they plan to release the new update for hybrids?
    Kendub likes this.
  4. Jan 25, 2023 at 8:30 PM
    #274
    Llamafood
    Llamafood New Member
    2023 limited hybrid
    If you go to their website they have an option to order one for hybrids but it says “beta” next to it …
  5. Jan 25, 2023 at 10:26 PM
    #275
    Max713
    Max713 New Member
    Good... I don't even use their original maps anymore, makes the truck drive like dogshit. Really expensive gauges at this point...
  6. Jan 28, 2023 at 5:39 PM
    #276
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    I just updated and checked my app. The “new” hybrid version is not available. Has anyone purchased one recently to confirm what firmware is loaded if hybrid is selected?
  7. Feb 3, 2023 at 10:51 PM
    #277
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Fox 3.0 Camburg UCA's and Trailing Arms KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV K&N Cold Air Intake and charge pipes Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs and Focal Components 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    I like mine. Be caref with the BOV though.
  8. Feb 3, 2023 at 10:55 PM
    #278
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've had no issues with their BOV plate after I plugged most vent holes
  9. Feb 3, 2023 at 11:14 PM
    #279
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Good to know I think I had no holes plugged and my car would go into safety mode and a lot of lights would turn on.
    how many holes did you plug?
    eddiefromcali[QUOTED] likes this.
  10. Feb 3, 2023 at 11:19 PM
    #280
    eddiefromcali
    Eddie
    100% Stock
    All but one on each plate
    iiawah808 likes this.
  11. Feb 17, 2023 at 11:21 AM
    #281
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Any feedback from BMS in regards to issues with those Blow off valve adaptors. How to fine tune them. Did the do any R&D ?
  12. Feb 17, 2023 at 11:24 AM
    #282
    eddiefromcali
    Eddie
    100% Stock
    I was part of their r&d. No issues once you figure out how many holes you need to plug. I've seen guys say they have no problems with no plugs, others like me only leave one vent open on each plate.
  13. Feb 22, 2023 at 12:39 PM
    #283
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    what about map 8 anyone tried it? better mpgs?
  14. Feb 22, 2023 at 2:04 PM
    #284
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    So to clarify? The tuner does work in the same way as a throttle controller? Or do I need both to get rid of the throttle lag?
  15. Feb 22, 2023 at 2:10 PM
    #285
    Black widow TRD
    Manuel
    I use my JB4 with the Beta firmware. The Beta firmware give you the option to make the throttle response linear.
    I absolutely love it. No throttle commander needed.
  16. Feb 23, 2023 at 6:54 AM
    #286
    mayan
    Mayan
    DFW
    Off topic but can JB4 connect with carplay or android auto to integrate it's gauge that be pretty cool.
  17. Feb 23, 2023 at 7:07 AM
    #287
    Black widow TRD
    Manuel
    No it does not and yes that crossed my mind also, that’d be freaking awesome!!
  18. Feb 23, 2023 at 7:25 AM
    #288
    RickyBobbysTundra
    Phoenix
    And with you running the hybrid TRD Pro, I can expect similar results with mine?
  19. Feb 23, 2023 at 9:21 AM
    #289
    eddiefromcali
    Eddie
    100% Stock
    You need Binize box to do so
  20. Feb 23, 2023 at 9:24 AM
    #290
    mayan
    Mayan
    DFW
    OHHHHH SHIT!! look at that does Binize box work for iOS? I think this is it I'm doing it lol
  21. Feb 23, 2023 at 9:45 AM
    #291
    Black widow TRD
    Manuel
    That would be the only reason I’d purchase a Binize. See what you’ve done!!
  22. Feb 23, 2023 at 10:22 AM
    #292
    eddiefromcali
    Eddie
    100% Stock
    The box runs android...all you need to provide from your inferior phone is a Hotspot :)
  23. Feb 23, 2023 at 12:38 PM
    #293
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    How do you do that?
    Taikowaza likes this.
  24. Feb 23, 2023 at 1:00 PM
    #294
    mayan
    Mayan
    DFW
  25. Feb 24, 2023 at 7:50 AM
    #295
    Black widow TRD
    Manuel
    The JB4 device rolls out firmware updates. Currently they offer the original firmware and the beta firmware.
    The bata firmware gives you give you the ability to changes maps on the fly using your driving mode. For example you can designate eco mode for normal driving, normal mod for map 1 ( which is for 91 octane) and sport mod for (map 2 for e30).
    in the options menu it also gives you an option to make your throttle response liner.
    In the customization tab you simply keep scrolling to the bottom the customize those features.
  26. Feb 27, 2023 at 8:36 AM
    #296
    jeosbor1
    jeosbor1 New Member
    North Carolina
    Figured it out! I like the on the fly change of tunes. Gas pedal feels much better also.
  27. Feb 27, 2023 at 8:44 AM
    #297
    Black widow TRD
    Manuel
    If you want some extra grunt, you can add about 5 to 6 gallons of E85 and run maps 2 or 3. It’ll get you to about E30.
    Here is a calculator I use to figure out percentage ratios.
    https://www.morepowertuning.com/emix
  28. Feb 28, 2023 at 6:06 AM
    #298
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    You can still run maps 2-3 with just 93, although it will run a little better on 93+E85 mix
  29. Feb 28, 2023 at 10:26 AM
    #299
    Black widow TRD
    Manuel
    Wish I had 93 in my area, I only have 91 but Atleast I have E85.
  30. Feb 28, 2023 at 10:43 AM
    #300
    eddiefromcali
    Eddie
    100% Stock
    I just mix e40 at the pump and run map 5. If you've got android, download E85 Blend app. Most california pumps are E10 and pump E85 is E80. Knowing this, plus having the BMS E85 sensor makes mixing super easy.
