3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Nov 17, 2022 at 11:38 AM
    #541
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Sharing an update: I'm having my Icon setup installed today. Normally, I do all of my own work but I opted to have a local off road shop install this since it's so extensive. Full front & rear upgrades so I wanted to save my back.
    I noticed earlier that Icon has updated their tech notes for all lift kits (except for the Stage 1 &2 kits) to include this statement:
    My shop is going to do some flex tests on the truck at full droop once the front end is fully assembled. We were reading the Icon tech notes and we can't tell 100% if Icon is accidentally interchanging the terminology of the "TRD Off Road" package with the TRD Pro. My truck is an SR5 with the TRD OR package (i.e. the red off road axles) so we'll see if the kit over extends the front axles or not.
    They're going to call their Icon Rep to investigate that part # for the diff drop kit since that P/N isn't listed on the Icon site. More to come on that as I hear from the shop.
    SC4333, AND, tyman77 and 1 other person like this.
  2. Nov 17, 2022 at 12:01 PM
    #542
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Thanks for the update. I looked for the diff drop part number too and came up empty.
  3. Nov 17, 2022 at 12:24 PM
    #543
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Looking up the Toyota part numbers they list leads me to believe the TRD PRO and TRD OR package are both using the same front axles, like you indicated, so I imagine you'll be fine.
  4. Nov 17, 2022 at 12:50 PM
    #544
    WoodfordAZ
    WoodfordAZ New Member
    Alex
    2022 White Tundra SR5 TRD
    Thanks for confirming that @korslite. Of course, I had to run out and look under my truck to verify I did have those axles on my TRD OR. I'm having my Icon stage 7 installed next month and am curious what else comes up between now and then. I had to use a diff drop kit on my old 4Runner with an Icon lift. Cheap part. Wasn't a big deal.
  5. Nov 17, 2022 at 12:54 PM
    #545
    KroppDuster
    Bilstein 5100s
    Indeed. I think there is a design issue with dropping the diff on the 3rd Gen though. Case in point, the dudes @ AMKC have said on multiple occasions that they don't see an easy way to drop the diff. It seems it's much harder than slapping in a couple of spacers, like most trucks. I think that's the reason we haven't seen many (any?) diff drop kits become available yet. Not 100% sure though.
    DexterL likes this.
  6. Nov 17, 2022 at 1:01 PM
    #546
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Might be better to look into getting the longer axles from the TRD lift kit in the long run. I guess I'm just going to hope for the best since I already installed my Icon stuff weeks ago LOL. I don't recall this note from when I did mine.
  7. Nov 17, 2022 at 1:07 PM
    #547
    KroppDuster
    Bilstein 5100s
    I'm sure it'll be fine, but just something we'll keep an eye on. I think the tech note is relatively new. I don't recall it being there a few weeks ago when I had my last convo with my local Icon dealer.
    If...and hopefully it's a big "if"...we need extended length axles, it seems there are already aftermarket options out there. I posted about it earlier in the thread, but worth sharing again: https://www.tundras.com/threads/3rd-gen-suspension-lift-mega-thread.108483/page-17#post-2952431
    The TRD extended length axles are around $400/ea. The aftermarket options are ~$150/ea.
    korslite[QUOTED] likes this.
  8. Nov 17, 2022 at 1:37 PM
    #548
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Not saying it’s good or bad but here’s full droop with my icons I just put on. This is without the sway bar. I wanted to get the extended axles in there but you still can’t buy everything separate from the Trd lift kit yet 927C366D-B80A-4683-8973-D81EA2EABACC.jpg
    Here’s the other side stock.
    korslite and iiawah808 like this.
  9. Nov 17, 2022 at 1:54 PM
    #549
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Now I wish I had measured droop before I took the factory stuff off. Curious if there is even difference on mine since I left the factory UCAs.
  10. Nov 17, 2022 at 6:37 PM
    #550
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Do any of you guys know where I can get a rebuild kit for Elka suspension? I’ve had all 4 for about 50k miles now
  11. Nov 18, 2022 at 2:31 PM
    #551
    WildatheartTundy
    WildatheartTundy New Member
    Joe
    2022 SR5 TRD Off Road
    I think I’m switching up topics here and this may have been covered but I just purchased the icon dynamics stage 5 kit. Anyone have any reviews on it?
  12. Nov 22, 2022 at 1:39 PM
    #552
    KroppDuster
    Bilstein 5100s
    Update to my earlier post regarding CV angles & other topics post Icon install...
    Got the Icon setup installed. Parts list in my signature, if anyone is curious. Some notes:
    • CV angles are totally fine. Checked them at full droop and they're not binding or over extended at all. So the tech notes for Icon are spot on. If you have the TRD OR or the TRD Pro (same axles) then you're totally fine.
    • My spacer solution for the skid plate (Link to my build thread post here) worked out great. I have not noticed any clearance issues between the sway bar & skid plate using the Icon sway bar drop bracket.
    Initial thoughts: I drove 65 miles home from the shop and the ride is noticeably better. Responsiveness & recoil are much improved. It handles great and I notice the increase in travel without it being "spongy." Overall, 1 day later and only 65 miles into it...I'm impressed. I'll snap some pics, though it's nothing others haven't already seen before, this weekend. I also have before measurements so I'll take new measurements this weekend as well and share.
    bigblue14 and bigjuice like this.
  13. Nov 22, 2022 at 7:50 PM
    #553
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Thanks for the updates
  14. Nov 22, 2022 at 8:16 PM
    #554
    HusaUrDaddy
    HusaUrDaddy New Member
    Marty
    Fayetteville, GA
    2023 TRD Sport Crewmax 4x4 on order / 2019 TRD Pro CrewMax (sold)
    SQ1 package, Kenwood DDX9905 in the '19
    Thanks for the updates Kroppduster, looks great! So the Pro & OR trucks axles are okay but it looks like the TRD Sport would require new front axles? Is that the consensus?
  15. Nov 22, 2022 at 8:29 PM
    #555
    KroppDuster
    Bilstein 5100s
    It seems that way. It looks it would apply to the TRD Sport and the standard 4WD models, basically any truck with the standard black axles. My guess is the standard black axles aren’t high angle axles and the red axles are. It’s tough to know 100% without being able to put them side by side.
    iiawah808 likes this.
  16. Nov 23, 2022 at 6:12 AM
    #556
    Joaopac
    Joaopac New Member
    16 platinum Crewmax 4x4
    3,1
    Please excuse this if it has already been covered, read through most of the pages on here and haven’t been able to find and mention if previous gen suspension will work on 3rd gen trucks? Have a set of kings on my current truck (2016) that I would love to use when my 2023 comes in. Thanks in advance!
  17. Nov 23, 2022 at 6:14 AM
    #557
    KroppDuster
    Bilstein 5100s
    Unfortunately, no.
    The top hat is the same between the 2nd Gen and 3rd Gen, but the bottom mounting point on the LCA is different.
  18. Nov 23, 2022 at 8:48 PM
    #558
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    As are the lengths of the shocks
  19. Nov 24, 2022 at 7:41 AM
    #559
    Baldilocks
    Baldilocks New Member
    4wheelparts has good Black Friday sale on Icon happening - significant discounts
    https://www.4wheelparts.com/b/suspe...ynamics/_/N-cm868Z1yzahlr?skuSelectedTab=true
    Am getting stage 7 tubular w/ 2.5" resies on all four corners + track bar for $3200 including tax
    plus front/rear icon bump stops & OME2866 from Summit Racing - $470
    plus yota rear extended brake - $70
    Yaboy and KroppDuster[OP] like this.
  20. Nov 26, 2022 at 9:54 AM
    #560
    HooahMP12
    HooahMP12 New Member
    Justin
    2022 Tundra
    Hey All,
    I pulled the trigger on the Stage 4 and I am now worried because I have a TRD Sport. I sent Icon an email asking about the diff drop bracket and if its actually needed. Had I knwn this one I bought it I prob would have waited. Anyone running this setup on a TRD Sport? Im curious what everyone is setting theres too. I did order a cornfed rear 1" spacer kit and wanted 3 inches ain the front but Im a bit worried that may not be pratical now. Thanks
    Dfrink likes this.
  21. Nov 26, 2022 at 11:58 AM
    #561
    Dakota3645
    Dakota3645 New Member
    Dakota
    2022 Tundra SR5 - Army Green
    Did you get it with the extra discount from 4WP? I was eyeballing the stage 3 kit all day at $1408 normally $1758 per their site. Waited until the evening to order and it wasn't at the $1408 anymore. Called 4WP this morning and they said the system had a error and gave the 20% off retail then an additional 20% off. So bummed I was finally good for once and decided to check with the wife first and it bites me in the ass lmao. Ohh well still ordered, gonna have them price match Summit Racing to save another $140 and I got 12% in cash back from Rakuten along with the $125 4WP bucks and 10% back for using my car care credit card!
  22. Nov 27, 2022 at 7:58 AM
    #562
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I’m curious as well. I have a base SR5 4wd (no trd). I’m about to put RC 2” coil overs on front with a cornfed 1” on back (parts are sitting in my garage). Should I be concerned about my axle length?
  23. Nov 27, 2022 at 8:19 PM
    #563
    Baldilocks
    Wow! Yes, I guess I got the extra discount - got the stage 7 for $2745.71 + tax. They already called to confirm that all items except two were in stock and ready for pickup.
  24. Nov 28, 2022 at 4:05 PM
    #564
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    seems like this is the right thread to post this question since it has been discussed several times generally...
    for those of you who have pinned back the felt in the front wheel well, how specifically did you do so?
    it looks to be a 12mm hole in the body but it isn't threaded. i could tap it and add threads but haven'theard of anyone needing to do so. i haven't found a plastic rivet that will work either.
    295/65/20 toyo at3's going on this week and trying to get the pinning out of the way beforehand. thanks in advance for the help.
  25. Nov 28, 2022 at 5:18 PM
    #565
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Behind the wheel, I made a small L bracket from one of the holes where the bracket was to existing hole in the felt than I installed two extra zip ties thru the felt.
    The front was more of a pain. I removed the existing bracket, cut a piece and bend it back to original shape. Nothing too complicate.
    Bo-Hunter and Fr0zenTundra like this.
  26. Nov 28, 2022 at 5:30 PM
    #566
    iiawah808
    Oahu, HI
    I just drilled out the hole to enlarge a little. Hit it with some black spray paint and used an oem push pin.
  27. Nov 28, 2022 at 5:32 PM
    #567
    Fr0zenTundra
    Wi
    '22 platinum hybrid
    thank you both for the replies!
    do you happen to know which push pin? advanced auto was of no help when i was looking to go this route. did you get it from the dealer?
    iiawah808[QUOTED] likes this.
  28. Nov 28, 2022 at 5:55 PM
    #568
    iiawah808
    Oahu, HI
    Shucks. Pretty sure its the same push pin size used to hold the grill on in the corners by the grill plugs.
    I drilled out the hole based on the size of the push pin. So any pin can work I guess.
  29. Nov 28, 2022 at 6:18 PM
    #569
    Fr0zenTundra
    Wi
    '22 platinum hybrid
    thanks! i'll give that a try as well.
  30. Nov 29, 2022 at 11:51 AM
    #570
    Taikowaza
    Taikowaza New Member
    wmsvol88 and Bustedandrusted like this.
