3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Jan 10, 2025 at 6:32 PM
    #2641
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    I messaged Wilwood a couple weeks back and they will fit my Method 703’s that are 17” +35 with a 1” spacer. So I’d imagine 18” and up on wheels will be fine
    Have you noticed a reduction in the range of your FOB? I read that some noticed they had to be pretty close to the truck to lock/unlock it. Others have also expressed frustration with a delay in the front map lights turning on when you open the door? Have you noticed these things?
    RadixRyder likes this.
  2. Jan 21, 2025 at 4:02 AM
    #2642
    Garand
    Garand New Member
    2024 TRD OR Limited DC
    285/65R20
    Can you elaborate on this "tucking" procedure??
    I had a full bedrug in my 2015 TRD PRO, I had no issues with it at all for the 10yrs I drove that truck.
    I really miss having one in my new truck but hadn't found a clean way to deal with the lights and outlets until your post.
    I thought about getting just the XLT version that covered the tailgate and bed, but imagine getting all kinds of junk under the rug.
    Thanks for any info you can share!
  3. Jan 21, 2025 at 6:32 AM
    #2643
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Absolutely.
    The rug comes with outlines on the backside for you to cut out the holes for the 2 bed lights and the power outlet. I didn't want to do that, so I removed the majority of the outlined area instead. The lights simply pop out via a tab and the power plug has those 4 screws you see in the pic. I disconnected them and then slid them back into the cut out hole I had made in the rug. This gave me a rough idea of where the pieces would cover the rug. I then pulled the pieces out and CAREFULLY removed the foam backing all around and a little beyond the area.
    The foam backing is what gets in the way of tucking the carpet behind these pieces. By removing it with a box cutter, it leaves you with the thin carpet material which doesn't get in the way as much. It took a lot of trial and error but I was able to do it. The bed lights were the problem, not the power plug. Foam cuts really easily with a fresh blade...doesn't take much effort, just time.
    Garand[QUOTED] likes this.
  4. Feb 9, 2025 at 11:18 AM
    #2644
    CAPT_Squatchy86
    CAPT_Squatchy86 New Member
    2024 TRD ORCM Lunar Rock
    If I didn't have two car seats in the back, I'd be all over this.
  5. Feb 12, 2025 at 5:20 PM
    #2645
    RNOTahoe
    RNOTahoe New Member
    Looks as though you needed to remove the lower (chrome) front grill section to add the light bar. I'm trying to remove mine to install lights and can not get it lose. how did it go for you?
  6. Feb 12, 2025 at 8:14 PM
    #2646
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Typically for the behind-the-grille lightbars, you remove the whole front grille assy and mount to the crash bar. I haven’t seen a lightbar kit that you’d have to remove that valence for, but I did remove that valence when swapping grilles and when I swapped fog lights. Use plastic trim pry tools to pop it out from the middle / around the fog lights, but it has giant tabs that go into the lower part of the mustache so it can be a pain to remove and remount. What lights are you trying to install?
  7. Feb 13, 2025 at 7:39 AM
    #2647
    eddiefromcali
    Eddie
    100% Stock
    this guy explains and shows you. I just pulled mine out, real easy
    https://www.youtube.com/watch?v=PrSc-NIRrig
    chrisgibbs707 likes this.
  8. Feb 13, 2025 at 5:48 PM
    #2648
    RNOTahoe
    RNOTahoe New Member
    I'm trying to install Fog lights that go behind the valence.
    I have a 1794 with a factory 3" lift. They delete the fog lights with the factory lift. I went with an Amber set that I can aim down a bit for use in snow storms and such.
    I've yanked on the Chrome valence like there is no tomorrow and gave it a fair bit of encouragement with a interior pry tool as well - no luck.
    I'm thinking there is some easy trick/angle/something that once I figure out will allow the valence to come off.
    chrisgibbs707[QUOTED] likes this.
  9. Feb 14, 2025 at 7:33 AM
    #2649
    bailey bulldog
    bailey bulldog New Member
    I was jacking with mine earlier this week. You really have to pop on the center. I started at the bottom and eventually got it out. And the screws on the fog lights seemed like they were put in with blue locktite.
  10. Feb 25, 2025 at 9:10 AM
    #2650
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    As a retailer of all things truck accessory, I have dozens of bed cover options at my disposal.
    This is the cover that I chose to install on my '25 Platinum;
    Agricover / Access - LOMAX
    Hard folding tonno cover
    - Very low profile, strong, light weight, single layer of heavy gauge aluminum. (vs thin panels over styrofoam).
    This eliminates the possibility of the cover absorbing water and becoming waterlogged and heavy (like some popular brands).
    - Seal / gasket is on the underside, pinched between the cover and bed rail, not stuck on top where it is exposed to UV rays.
    The hidden compressed gasket not only looks better than seeing rubber around the entire perimeter of the cover,
    it also provides a better seal, and it is much less likely to shrink or peel off since it is being pinched in place.
    - Durable Urethane / Spray liner style finish.
    - Easy to install. No drilling. No drain tubes. Easy to remove in seconds without tools.
    * Ask me questions if you want more info.
    image000002.jpg image000003.jpg image000004.jpg image000005.jpg image000006.jpg
  11. Feb 25, 2025 at 9:28 AM
    #2651
    astrength22
    astrength22 New Member
    2023 Silver Tundra Platinum
    Some notable features/improvements over the MX4, which I just bought last month. What's this one cost? Thanks for sharing
    Tundrastruck91 likes this.
  12. Feb 25, 2025 at 9:41 AM
    #2652
    Noobo Baggins
    Glenn
    The Access Lomax is retailing for about $1100-$1500.
    The Access Stance has the fold up vertical option (like your MX4) to eliminate the need to remove the cover for full bed access.
    I prefer the Lomax and just take the cover off to still have my rear visibility.
    As a retailer myself, obviously I'd prefer people buy from a brick and mortar but they can be had directly from Agricover online.
    Please consider the advantages of using a local auto / truck accessory dealer.
    Yes, you will pay a premium, just like buying dinner at a restaurant vs a grocery store;
    Local dealer support provides solutions for;
    - optional installation
    - shipping damage
    - missing components
    - defective product
    - product boxed incorrectly (wrong size)
    - future warranty issues
    - supports local economy
  13. Feb 25, 2025 at 11:28 AM
    #2653
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    I have this same bed cover - I purchased it through WeatherTech. It's called the Tundra Alloy Cover. This thing is awesome, very low profile, basically water tight, sturdy, and easy to operate. Looks great. I did my research and determined it is much more premium than better known competitors like Backflip.
    As someone who is in the biz and knows a lot more than I do, I feel vindicated that you chose the same one. Thanks for sharing.
  14. Feb 28, 2025 at 6:28 AM
    #2654
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    I have a 25 TRD off-road 4x4 in Terra. It came with the white and black bedside decals. I don’t like the contrasting white. I’d like to replace them with the red and black bedside decals. I believe they would blend better with the Terra color and match the black rims with red TRD center caps. I found 2 OEM decals online. The description said light decal and a dark decal. No pictures available. Does anyone know if the dark version is the red and black decal?
  15. Mar 1, 2025 at 7:50 AM
    #2655
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Two questions.
    do the oem rails work with this? I have the older model of mx4 and don’t want to lose that.
    does the elevate t slot rails work with it?
  16. Mar 1, 2025 at 9:25 AM
    #2656
    Noobo Baggins
    Glenn
    Good questions...
    Guessing you're speaking of the Toyota utility track system...
    Yes, the mounting clamps utilize the OE Utility Track system. You must order the cover for WITH OE UTILITY TRAC to get the proper clamps that work with the track system.
    It's very tight but there is just enough room for the OE tie downs to fit. See photos #3 and #4 above (sorry, my phone camera sucks). The adjustment position of the OE sliding tie down is limited to the space between each clamp. Seems they would work fine in the front track without any limitations but I haven't tried them there.
    No, the Elevate T-Slot rails do not work with this as far as I know ...
    But if you are in need of a rack system, Agricover makes their own.
    https://www.agricover.com/adarac/pro/
    The Adarac PRO has a straight leg that allows for the solid folding cover to be opened.
    Don't make the mistake of installing a rack with a leg that tapers in ... as the last panel of the cover will hit the leg and not be able to be opened.
  17. Mar 2, 2025 at 9:29 AM
    #2657
    Boomer08
    Boomer08 New Member
    2024 white platinum I Force Max
    I love the looks of these but I just can't get myself to open up the wallet. I know I'm a cheap ass
  18. Mar 4, 2025 at 8:15 AM
    #2658
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    picked up a scangauge 3 this morning. Advance was running a sale. :spending:
    BlackNBlu likes this.
  19. Mar 5, 2025 at 6:38 AM
    #2659
    tallg53
    tallg53 New Member
    2024 CMLB 1794 TRD OR
    Just getting started...
    I am trying to do the same as you and have had no luck. (1794 w/ 3" TRD lift) I pulled the lower valence and side caps off as well to get better access to it. I can get the bottom started and pulled away but cannot get the top to let go for the lift of me. I wanted to avoid pulling the whole front end off if possible, but am thinking I will have to pull it all off. Have you had any luck? The videos online sure make it look easy...
  20. Mar 5, 2025 at 10:02 AM
    #2660
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    lower valence is a pita... you can get it off without removing the bumper, I looked at bottom clips and took my time on top clips. I will probably take front clip off next time I have anything to do there. no help just a heads up. :)
  21. Mar 5, 2025 at 10:05 AM
    #2661
    eddiefromcali
    Eddie
    100% Stock
    yup, gotta get under the truck, undo the clips and then yank it out. Wont go back in unless u nip 2 tabs off, one on each side. At least I couldnt get it on with those darn tabs...but its been fine with the other 20 million clips holding it on
    oddhours[QUOTED] likes this.
  22. Mar 5, 2025 at 1:10 PM
    #2662
    tallg53
    tallg53 New Member
    Thanks gents. I was more worried about breaking multiple pieces with how hard I was pulling on the fog light cover. I did get under the truck and pull the tabs away from the anchors on the lower portion but could not physically reach enough of the upper clips to make any progress. Sounds like the smart money is on full front clip removal if it is that much of a PITA. Cheers.
  23. Mar 6, 2025 at 8:05 PM
    #2663
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    What are the measurements for the custom bed divider you have there? Need something like that for my bed as am my kids sports gear rolls around.
  24. Mar 6, 2025 at 8:15 PM
    #2664
    astrength22
  25. Mar 6, 2025 at 8:30 PM
    #2665
    SoCal_Erik
  26. Mar 7, 2025 at 6:11 AM
    #2666
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    In your user manual there are dimensions
  27. Mar 7, 2025 at 8:40 PM
    #2667
    TommyTwoFingers
    TommyTwoFingers New Member
    2025 ice cap Tundra
    The Lomax looks like a decent cover. Can it hold a human walking on it? I know the diamondback can and prefer something I can walk on.
    you’re a dealer, but where are you located? Sorry if I missed that.
  28. Mar 8, 2025 at 7:01 AM
    #2668
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    Cali Raised is in Dallas Area......
  29. Mar 8, 2025 at 8:04 AM
    #2669
    sudobash
    sudobash New Member
    75996-0C100-A0 is what you're looking for. You will need two of them.
  30. Mar 8, 2025 at 10:12 AM
    #2670
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I have the LOMAX since June 2024, awesome cover. Can be used with OE rail system and OE tie-downs. Bought it from RealTruck through the rep on this site. Paid less than 900$ delivered.
    Can a person walk on it? That depends. A 60 lbs person can for sure but a 300 lbs person => hmm, probably not
