38 gallon fuel tank upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by Latitudes77, Dec 2, 2020.
  1. May 24, 2021 at 1:50 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Thank you!!! I’m on my search now.
  2. May 24, 2021 at 7:19 PM
    denverd1
    denverd1 New Member
    East Texas
    2014 1794 Super White 4x4
    3/1 lift, rims and tires
    auxiliary tank in the bed FTW. got other shit I would spend the cash on.
    BlackSheep likes this.
  3. May 24, 2021 at 7:50 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    point08 likes this.
  4. May 24, 2021 at 7:52 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    thought about it but I tow so it is more to keep me out of cramped gas stations
  5. May 25, 2021 at 8:14 AM
    denverd1
    denverd1 New Member
    East Texas
    aux tank saves you some coin, gives you more fuel capacity and gives you more miles between fillups....
  6. May 25, 2021 at 8:44 AM
    point08
    point08 New Member
    Kyle
    A dedicated aux tank also counts against my payload though which is already pretty limited with hitch weight. Not including when I'm not towing, it takes up precious bed space.
  7. May 25, 2021 at 10:41 AM
    denverd1
    denverd1 New Member
    East Texas
    15 gallons of fuel weighs 90 pounds. what are towing that 90 lbs of payload will create an issue?
  8. May 25, 2021 at 10:48 AM
    point08
    point08 New Member
    Kyle
    Ah, I thought you were referring to the 70 gallon aux fuel tanks that I've seen referenced where you can set it up to keep the main tank at a minimum level and then carry upwards of 100 gallons of fuel total.
    90 lbs isn't an issue. Adding an additional 420 lbs of fuel + the weight of the 70 gallon tank on top of my "4 bodies, 2 dogs, tow hitch, tongue weight" combo would tip me into the legal negligence zone.
  9. May 25, 2021 at 10:52 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    For that cost may as well do the 46 gallon transfer flow.
  10. May 25, 2021 at 11:58 AM
    point08
    point08 New Member
    Kyle
    The quote I got for it shipped to a local shop was $2500 after tax and shipping with another $1200-$1500 to install. It adds additional weight over the OEM tank and the profile of the tank sticks out a considerable amount compared to OEM. From what I can gather from other people's experience, you also lose the DTE calculation and fuel level indicators. Not including that the TF isn't legal in CA in case I ever move back.
  11. May 25, 2021 at 12:26 PM
    Black
    Wow, not a chance in the world I would ever use that shop. Their prices are ridiculous.
    https://www.tankandbarrel.com/toyot...placement-gas-fuel-tank-46-gallon-p-3838.html
    $207 for shipping.
    It’s about 4 hours of easy work for you and a buddy. A shop should be able to do it in much less than that.
    The tank hangs down just slightly more than OEM but nothing that will make a difference for anything.
    Yes, the DTE no longer works properly but I have never even looked at mine and the fuel level indicator works as it should.
    Not a chance in the world I would ever live in California.
  12. May 25, 2021 at 12:40 PM
    point08
    point08 New Member
    Kyle
    The shop didn't install it often and the guy was fairly new. He was spitballing it off the top of his head. He wasn't far off though... $1,763.28 + $176.33 for tax + $207 for shipping comes out to $2,146.61. With labor, he quoted it at $150 hr @ 8 Hours, coming out to $1,200 . I can give him the benefit of the doubt that if I was actually serious, he would have dialed the quote into something more concrete.
    Good to hear that it doesn't hang down more than OEM. I've read differently and other members have stated it. https://www.tundras.com/threads/extended-gas-tank.10644/page-3#post-810310
    I'd rather have 100 lbs of payload to put towards our bigger trailer that we want, so weight does make a difference.
    California is where I was born and raised. I don't live there any more but I can't rule out that I wouldn't ever move back for the right reasons.
  13. May 25, 2021 at 12:45 PM
    Black
    It does hang lower than OEM but nothing that will make any sort of difference. Plus it is steel so no need for a skid plate.
    If a full time shop needs 8 hours for a simple tank swap I would be concerned they don’t have a clue or are intentionally inflating their labor times for an already inflated labor price (granted this is somewhat regionally dependent). Labor rate where I go (if I can’t do it) is $110 which is still a touch high but he is the best around.
  14. May 25, 2021 at 12:50 PM
    point08
    point08 New Member
    Kyle
    Everything costs more here regionally. Just what it is. It's not a full time mechanic shop. It's a specialized restoration shop that just happens to be listed as the only local shop on TF's website to me.
    I'm happy with my purchase and won't have any issues with servicing since it's all OEM parts.
  15. May 25, 2021 at 12:57 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    possibly dumb question - say I find a junked truck, and go to pull the tank and misc parts I need to do this job. will there still be gas in the tank? or do junk yards remove any remaining gas?
  16. May 25, 2021 at 1:01 PM
    point08
    point08 New Member
    Kyle
    In CA, I've seen them pulling tanks completely. I assume they would drain them as much as they could but may have some residual fuel if they left the tank or in the fuel pump assembly. Probably best bet to go the safe route and assume there's something flammable in there.
  17. May 25, 2021 at 1:11 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I would go in assuming it's full of fuel - much safer to go in expecting possible vapors and the additional weight than to expect empty and end up with a full one. It's not something I've done first hand so can't say from experience what occurs.
  18. May 25, 2021 at 1:57 PM
    RussellVaughan
    Houston
    Anyone have experience with LKQ Online? I called and they have two 38 gal tanks - one in Houston and one in Livingston LA. I ordered one for $300 after tax, to be picked up at their Houston location. They mentioned they deliver to autoshops for $25.
    wv00097 likes this.
  19. May 25, 2021 at 2:03 PM
    #49
    point08
    point08 New Member
    Kyle
    Not bad if they only charge $25. Or is that above what you already paid? I think they have to ship these mostly by freight.
  20. May 25, 2021 at 2:05 PM
    #50
    denverd1
    denverd1 New Member
    East Texas
    safe to assume they did as little work as possible AND that you have a ticking time bomb on your hands
  21. May 25, 2021 at 2:06 PM
    #51
    RussellVaughan
    Houston
    tank was $275, plus tax. would be another $25 to deliver to a shop in my area.
    also, they only "guarantee" the tank itself. but he put a note in the order to include all the straps and hardware if possible....so we'll see what I actually end up with. He mentioned they don't even put the fuel tanks in their online inventory because they often get "bagged"...meaning damaged upon removal from the vehicle. So he also said there is a good chance my order will be canceled lol
    edit: should clarify what LKQ rep told me. parts get added to LKQ online inventory when they're pulled from the vehicle. parts like fuel tanks don't get pulled unless a customer orders them. and then many times they're damaged during the removal process and the order has to be canceled.
  22. May 25, 2021 at 2:24 PM
    #52
    point08
    point08 New Member
    Kyle
    That's not a bad gamble though. $1000 off the tank price before standard freight shipping.
  23. May 25, 2021 at 2:30 PM
    #53
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Let us know how this turns out. This is the only way I'd ever accomplish this upgrade. It's just cost-prohibitive to order new.
  24. May 25, 2021 at 3:12 PM
    #54
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    How did you find this on LKQ? I searched online, didn't find one listed. On hold with them now. I'll snag the one in LA
  25. May 25, 2021 at 3:29 PM
    #55
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Called LKQ, they mentioned one in CA and the one in Livingston LA. However, they said they would not ship because Hazmat. $225 plus tax. Considering making the drive if its still there in 2wk.
  26. May 26, 2021 at 5:59 AM
    #56
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    Here's the results of a search on car-part dot com for a 2017 38 gallon tank. It shows the Livingston, LA one for $200.
    https://www.car-part.com/cgi-bin/search.cgi
    Linky no worky for the search I ran. Looks like you'll need to set up your own search parameters.
  27. May 26, 2021 at 9:59 AM
    #57
    RussellVaughan
    Houston
    the LKQ guy told me they don't add parts like fuel tanks to their online inventory. parts get added to inventory when they're pulled from the vehicle, and fuel tanks don't get pulled unless a customer places an order for one like I did. Basically, have to call LKQ which sounds like you did.
  28. Jun 15, 2021 at 1:50 PM
    #58
    18TUNDRANW
    18TUNDRANW New Member
    Paul
    WA
    18 Tundra SR5
    I'm leaning toward replacing my small 26 gal tank with the 38 gal. I like the transfer flow with the comprehensive instructions and all the needed parts but I'm hesitating to go away from stock, the extra weight and that it hangs down some.. Has anyone seen a comprehensive list of the parts needed to upgrade to the 38 gal tank? I'm sure some things will cross over but plenty of things that will need to be replaced. I'm thinking like the fuel pump, hangers/hardware, filler hose, etc... Someone may have already posted a list I'm just not savvy enough to find it and have looked at dozens of related posts. Thanks
  29. Jun 15, 2021 at 2:03 PM
    #59
    Black
    The added weight and slight added depth of the Transferflow tank are no issues and nothing to worry about.
    But your comprehensive factory swap thread is here.
    https://www.tundras.com/threads/07-14-38-gallon-tank-swap-install-thread.27144/
    18TUNDRANW[QUOTED] likes this.
