38 gallon fuel tank is a joke 2019 TRD PRO
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bill Cogan, Nov 5, 2018.
  1. Nov 12, 2018 at 6:55 PM
    #91
    Crunch527
    Iowa
    TRD Supercharger/BAM
    My wife does same in her Highlander...she drives way past the low fuel warning...she will single handedly reduce the life expectancy of the fuel pump...not sure the engineers saw her coming...
    seth419 likes this.
  2. Nov 12, 2018 at 7:08 PM
    #92
    wilsonos2
    wilsonos2 New Member
    Don
    2018 Tundra Sport
    3” lift, 33” tires
    Not ballsy, dumb. LOL. I didn't start out to see how far I could go, just happened.
    15whtrd likes this.
  3. Nov 13, 2018 at 9:52 AM
    #93
    phabej
    phabej New Member
    2018 Platnium
    LOL, probably never.. moo moo moo from the government.
  4. Nov 13, 2018 at 11:26 AM
    #94
    15whtrd
    15whtrd Mr. Blonde
    :eek::rofl:
    NewImprovedRon likes this.
  5. Nov 14, 2018 at 4:44 AM
    #95
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The problem is that with such a big tank refueling is not always on your mind. If you know you have to fill up every other day then you keep your eye on the needle. My wife drives a Prius - same thing for her; she doesn't even think about filling up until she makes it home on fumes and not enough left to go to the gas station again, then I have to use the lawnmower supply to get her back on the road.
    Which, by the way, My Tundra get 500 miles per tank, and the Prius gets 500 miles per tank, so I don't have any reason to complain about gas mileage. (Prius has a 8 gallon tank :rofl:)
    Hammy68, classiccat, aperezsh and 2 others like this.
  6. Nov 15, 2018 at 11:12 AM
    #96
    UpSteer32
    UpSteer32 New Member
    I agree with the above in principle, but I disagree with it in practice.
    It just seems weird that the Tundra is designed to keep so much of its fuel capacity in reserve when other Toyota's (like the 4runner) have more usable capacity. The 4runner had a 23 gallon tank, and I could routinely squeeze 19-20 gallons of fuel into it.
    Only being able to squeeze 29-30 gallons of fuel into a 38 gallon tank just seems a bit odd.
  7. Nov 15, 2018 at 11:16 AM
    #97
    Grumpy Uncle
    Pat
    CO
    Has the OP even been back since posting this?
    15whtrd likes this.
  8. Nov 15, 2018 at 11:28 AM
    #98
    Boerseun
    Ferdie
    Sarasota Florida
    It's not that you cannot squeeze 38 gallons into it, it actually holds 38 gallons. You just can't use all of it. The 4Runner's 23 gallon tank is not nowhere close to 6' long, which is making the difference. If the 38 gallon tank was designed for that size from the beginning, it might have been done differently, but keep in mind that the Tundra was designed with the base 26 gallon tank and then the 38 gallon came as an upgrade afterwards - they had to use whatever available space there was under the bed to provide a bigger tank, which I assume was based on owner feedback that they wanted to see that. They delivered what the goal was, but it comes with the limitations that comes with the conditions that they had to work with.
    I have no reason to defend any of it; I just know that in my work I sometimes bend over backwards to provide clients with more than they expected, and then they complain about benefits that they did not even ask for.
    I appreciate the 38 gallon tank and I am more than happy with the 30 gallons that are usable, because I understand why 38 cannot be usable. Some people just stare themselves blind on the 38 and expect that they should get all of that - it just doesn't work like that. It's like telling a client you will try to do a task that would take 30 days to complete, in 20 days. Then when you complete it in 24 days they are upset because they think you are 4 days late, instead of appreciative that they actually got it 6 days early.
    tomsinamerica, Ostrich and 15whtrd like this.
  9. Nov 15, 2018 at 11:42 AM
    #99
    15whtrd
    15whtrd Mr. Blonde
    And you are effectively getting 10 more usable gallons of fuel than the 26 gallon tank. I know it’s not 12 more gallons but it’s relative. In my 26 gallon tank I have 20 gallons before my light comes on. 38 gallon tank has 30 gallons before the light comes on. Sounds reasonable to me.
  10. Nov 15, 2018 at 9:15 PM
    #100
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    I've read here and other places the need for cooling of the fuel pump is an internet myth.
    It is my understanding the fuel flowing through the pump, not surrounding it is what cools the pump.
    I can't say for certain but just another bit of information.
    jc153 and Boerseun like this.
  11. Nov 16, 2018 at 8:40 AM
    #101
    UpSteer32
    I understand there are engineering limitations with any modification to an existing design.
    But the burden is on companies, like Toyota, to try and meet consumer expectations; there is no obligation on the client's part to restrain their expectations.
    The 5.7l V8 is a hog on fuel. The Tundra should have come with a 38 gallon tank as standard from the factory. The consumer should be able to get as much driving range as possible out of that 38 gallon fuel tank before the empty light comes on; getting only 28-29 gallons worth of driving range is unacceptable in my view. Other companies have overcome that issue; the burden is on Toyota to figure that out as well. If they don't, they risk losing potential consumers. Plain and simple.
  12. Nov 16, 2018 at 8:48 AM
    #102
    15whtrd
    15whtrd Mr. Blonde
  13. Nov 16, 2018 at 8:54 AM
    #103
    Boerseun
    Ferdie
    Sarasota Florida
    Toyota sold me a 381 HP truck. I only get 190 at 1500 RPM. Toyota should give me 381 HP all the time.
    Just kidding. I know what you are saying and yes, :deadhorse:. :D :thumbsup:
    NewImprovedRon and 15whtrd like this.
  14. Nov 16, 2018 at 8:58 AM
    #104
    UpSteer32
    Good joke, I guess.
    Your original post was implying that consumers have unrealistic expectations with regards to the Tundra's usable fuel capacity. Maybe 10-15 years ago, that may have been the case. Considering what the competition offers nowadays, those expectations are not at all unrealistic.
  15. Nov 16, 2018 at 9:03 AM
    #105
    Grumpy Uncle
    Pat
    CO
    NewImprovedRon, Casper421 and 15whtrd like this.
  16. Nov 16, 2018 at 9:06 AM
    #106
    15whtrd
    15whtrd Mr. Blonde
    Here’s the thing. You can use the fuel. Just keep driving. The light turning on does not mean you can’t keep going. But at that point you probably should just get gas. You have used about 80% of your fuel.
  17. Nov 16, 2018 at 9:21 AM
    #107
    Grumpy Uncle
    Pat
    CO
    This is Toyotas way of trying to save you $30-$50 when it time to fuel up.
    I think we can all agree on that. Now please for the love that all holy let this puppy rest.
  18. Nov 16, 2018 at 9:29 AM
    #108
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Truth. I don't have the 38 gallon tank, but I have run my 26 gallon tank down so low that I put about 24 gallons in it once.
    If I stop and put fuel in it when the light comes on, I put in about 19.5 gallons to get it full.
    15whtrd[QUOTED] likes this.
  19. Nov 16, 2018 at 9:29 AM
    #109
    15whtrd
    15whtrd Mr. Blonde
    Same!
  20. Nov 16, 2018 at 9:38 AM
    #110
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Unfortunately, it wasn't even close:
    Pass: No 6 Repeal of Fuel Tax Approved by Voters. 4,252,095 43.6% 5,492,611 56.4%
  21. Nov 16, 2018 at 9:43 AM
    #111
    15whtrd
    15whtrd Mr. Blonde
    Yeah! Total bullshit. People are idiots. My younger cousin voted no because he wants better alternate public transportation. The guy lives at home and thinks Gas is still relatively cheap. I told him, you know you gave them the OK to raise it whenever they would want without a vote now. Hey says, then we just vote them out of office next time. LOL really?
    Some of the same assholes that vote yes on a cigarette tax because they think it’s going to help cancer research. It’s just more money to steal for the greedy politicians.
    aperezsh, Trooper2 and Moon Puppy like this.
  22. Nov 16, 2018 at 9:46 AM
    #112
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    This is what happens with a super-majority in both houses. They can do whatever they want so long as voters are drinking the Kool-Aid. I hate this state sometimes.
  23. Nov 16, 2018 at 9:48 AM
    #113
    15whtrd
    15whtrd Mr. Blonde
    :cheers:
  24. Nov 16, 2018 at 9:48 AM
    #114
    tundras00
    tundras00 New Member
    I don't freaking understand the logic behind the bickering of people that complain that they can't use all of their gas when it is in their damn tank. Hey fella, you want to use all of the 38 gallons go right ahead, but don't go complaining to daddy Yota to replace your damn fuel pump because you are freaking OCD. There, I said it... Jesus /rantover
    Trooper2, Ostrich and 15whtrd like this.
  25. Nov 16, 2018 at 9:50 AM
    #115
    tundras00
    Man, I am in the same boat of People's Socialist Republic of Chicago. Yeah, IL doesn't exist when it controls the whole state like the Chicago Machine they're named after.
    Trooper2 likes this.
  26. Nov 16, 2018 at 10:07 AM
    #116
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I always fill up at 1/4 tank left - typically close to 300 miles per tank - well that was before I moved to a state where gas is only 2.40 a gallon. Now it is more like 250 miles lol stupid lead foot
    :burnrubber:
  27. Nov 16, 2018 at 10:19 AM
    #117
    tundras00
    Heck, in winter time I fill at 1/2 tank most of the time, just in case there is a blizzard and you get stranded. Summer is around 1/4 for me also.
  28. Nov 16, 2018 at 10:29 AM
    #118
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Fuck a A boys let this one go. Beating a dead horse.
    15whtrd and Grumpy Uncle[QUOTED] like this.
  29. Nov 16, 2018 at 10:35 AM
    #119
    15whtrd
    15whtrd Mr. Blonde
    This horse has been stabbed, shot, mutilated, desecrated and chopped into tiny pieces.
    aperezsh, Casper421 and Grumpy Uncle like this.
  30. Nov 16, 2018 at 10:50 AM
    #120
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    Most jacked thread I've seen in a while. Well done.
    OP, um, welcome from SoCal?
