37's are on !!!!
Discussion in 'Wheels & Tires' started by CM-LENNY, Jan 28, 2017.
  1. Mar 30, 2017 at 6:46 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Damn son!!
    You went BIG! I'm envious that your attention span allowed you to think up that setup
    Sunnier likes this.
  2. Mar 30, 2017 at 7:23 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So out stock is good enoUgh to run 35's with no problems?
  3. Mar 30, 2017 at 7:38 PM
    CM-LENNY
    CM-LENNY [OP] No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Probably the majority of guys running 35's will tell you that the stock 4:30 gears are fine for 35's. Their are numerous people including myself that think the truck will perform at its peak with a re-gear after upgrading the tire size. The engineers designed the transmission and diff gears to operate with a particular tire size. When that tire size is altered, the engine and trans suffer when the diff is not re-geared accordingly. I would strongly recommend the re-gear if it falls in your budget. Hope this helps with your decision. Contact Dirty Deeds if possible for more info.
    Jsena[QUOTED] likes this.
  4. Mar 30, 2017 at 7:43 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Question for you guys I see something about changing gears, I put 295 55 r20 on the truck would I have to change gears I don't off road with her
  5. Mar 30, 2017 at 7:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    That puts you at about 32.8". No you don't have to worry. It's for 37" tires.
    GodlessPro, Jsena and zcarpenter92 like this.
  6. Mar 30, 2017 at 7:51 PM
    CM-LENNY
    San Diego, CA
    Hey Phil, if I read your tire size correctly, looks like the height is not much over stock, mainly wider. I think you are fine with the OEM gears.
  7. Mar 30, 2017 at 8:06 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Thanks a lot guys never was big on suspension so that just made me feel better once again thanks!!
    joonbug likes this.
  8. Mar 30, 2017 at 8:37 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  9. Apr 21, 2017 at 9:39 PM
    geno0506
    geno0506 New Member
    Michael
    Love you truck.
    sent a PM!
    CM-LENNY[QUOTED][OP] likes this.
  10. Sep 5, 2017 at 11:20 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    Sexy truck! Who is John at auto fab? Hah I see your in San Diego too, been looking for a reputable shop. Had horrible experience with fci metal werks that guy is a scammer locally here in San Diego
  11. Sep 11, 2017 at 9:36 AM
    Steele6599
    Steele6599 New Member
    Markus
    Fredericksburg, Va.
    2017 Silver Sky Metalic 4x4
    None Yet
    New tundra owner here, is the concern with re gearing the differentials due to the weight of the wheel or the diameter? My thought is the weight is the concern so if you run lightweight rims and tires would re gearing be necessary?
  12. Sep 11, 2017 at 9:44 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I'd say both but more the diameter. For 37's, you can find the lightest wheel and tire combo out there but will still want to re-gear. And welcome to the forum bud.
    GodlessPro likes this.
  13. Sep 11, 2017 at 9:56 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome Markus. You should start a new member intro post if you haven't already so we can check out your ride.
  14. Sep 11, 2017 at 10:38 AM
    Steele6599
    Markus
    Fredericksburg, Va.
    None Yet
    Thanks, just created the thread there
    TXMiamiFan likes this.
  15. Sep 11, 2017 at 11:13 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Do it!!
  16. Sep 11, 2017 at 11:18 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I'm a little disappointed these 37s aren't 40s.
    SoCal619, Sunnier and Black Wolf like this.
  17. Sep 11, 2017 at 2:35 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    As you should be
  18. Sep 11, 2017 at 2:38 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    LMFAO :rofl::rofl::rofl::rofl:
    Well, I'm pretty cool then and getting it done!!!!!!! YEAHHHH
    dpast88 likes this.
  19. Dec 11, 2019 at 8:06 AM
    #49
    techoguy
    techoguy New Member
    Chase
    2016 Tundra CM 4x4
    @CM-LENNY Hey I'm hoping you still get this message. I love the fab work! I just got my tundra and plan on putting 37" on too. This thread most people are discussing gears, but I'm wondering, how did you fit 37" with a stock UCA without a BMC? It seems most have to do a BMC with only 35". Just curious.
  20. Dec 11, 2019 at 8:10 AM
    #50
    Spvrtan
    Kris
    San Diego, CA
    You need as much positive wheel offset as possible. He used the stock wheels which is as best as it gets (eg. +60mm). Then you need skinny 37" tires, which are usually ~12.5" wide. After that, when getting an alignment, max out your forward caster.
    But if you just simply read his first post in this thread, he outlines everything he did.
  21. Dec 11, 2019 at 8:11 AM
    #51
    Spvrtan
    Kris
    San Diego, CA
    Another concern is the diameter of the 37" tire. Not all are really 37". Some are closer to 36" in actual measurement.
  22. Dec 11, 2019 at 8:35 AM
    #52
    techoguy
    techoguy New Member
    Chase
    2016 Tundra CM 4x4
    What's up Kris!?
    Yeah, in his first thread he doesn't mention anything about caster or pushing caster all the way forward. So I am curious about what caster numbers he was running. He also says no rubbing, that surprised me too because I would have expected that size tire to rub the sway bar at full lock with that wheel offset.
  23. May 12, 2020 at 4:20 PM
    #53
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA to Austin,TX
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    So with 18' oem trd wheels, instead of doing the modification to the uca,can I just use a small wheel spacer to clear the 37s?
  24. May 16, 2020 at 5:15 AM
    #54
    codename607
    codename607 New Member
    Chicago
    2019 Tundra / 2024 Tundra
    You could but then you risk having some rub on the body mount and possibly the front bumper. I wonder if an aftermarket UCA would prevent the need for adding a spacer and the need of trimming the stock UCA?
    equin and Jman245[QUOTED] like this.
  25. May 16, 2020 at 7:22 AM
    #55
    Jman245
    Jay
    Thats what I was thinking
    Mountun Goat likes this.
  26. May 26, 2020 at 11:41 PM
    #56
    37x12.50r20TundraDude
    37x12.50r20TundraDude 37x12.50r20TundraDude
    Tomas
    CORPU SCHRISTI , Texas
    2015 Tundra crewmax 4X4 5.7L FFV
    6in. Lift 37x12.50r20
    Whats my lift look like to you. It has 37x12.50r20 Nitto Terra Grappler G2 Alterains.
  27. May 27, 2020 at 7:01 AM
    #57
    Tomas
    I just got my 2015 tundra SR5 4x4 5.7 . O believe it has 4:30 rear gears. I was told those are good I drove 3 hours away from home and drove smooth. I didn't smell anything burning and truck drove smooth on the highway at 75mph -80 pmh. I got around 11mpg going and coming home to Corpus Christi. If I change the rear gears to 4:88 what do I have to change also the front gears and transfer case too? And will that be okay to drive on the highway at 80mph? Please let me know what you think friends my first lifted truck ever and I'm kinda clues I'm sorry to say but I do need all the advice .also I'm on disability so I ain't got much money left out my monthly check after payment Truck Payment, Warranty's and Insurance.. thank you all again.
  28. May 27, 2020 at 7:04 AM
    #58
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    @codename607
    when you buy uca (I run spc) they actually have less room than oem uppers. I’m on 37x12.5x18s with 1.5” spacers up front for clearance. Could prolly get away with 1” ones. I also did the bmc for reference and this is a 4” lift
    Edit* I should add, this thread and op are the reason I went 37s :) thanks op who no longer is active on the forum haha.
    equin and 37x12.50r20TundraDude like this.
  29. May 27, 2020 at 7:16 AM
    #59
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    You’ll need to swap both front and rear gears.
    check this out for good info:
    https://www.tundras.com/threads/diy...ntial-regear-at-home-not-for-beginners.67185/
    Otaku4life69 likes this.
  30. Jun 19, 2020 at 8:30 PM
    #60
    warhammer44
    warhammer44 New Member
    Grant
    Kansas
    2016 Tundra Crewmax Black 4x4 SR5
    Do you think it would be possible to mount the 37x12.50 on the factory TRD +60 wheels without a wheel spacer and without modding the UCA? On a 2.5 level...
    Mountun Goat[QUOTED] likes this.
