3'' front 1'' back leveling VS only 2'' front leveling
Discussion in 'Suspension' started by herchi79, Sep 26, 2018.
  1. Jan 7, 2019 at 5:01 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Idk but I started questioning what if i already had a leveling from previous owner...can someone help me out with following photos and let me know? Thank you
  2. Jan 7, 2019 at 5:31 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    It would look like this. First pic is 2” level and the second is 3” spacer (plus 1” block in back not shown). I only know this because my dealership had the wrong lift installed the first time so I took it back.
  3. Jan 7, 2019 at 5:34 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @DvilleMafia ok thanks for the quick reply i guess its safe to say I don't have a leveling kit.
  4. Jan 7, 2019 at 5:40 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    There are more leveling options than the top spacers. You can also have in-strut spacers, which will look a little different. From your photos it does not look like you have that either. The third option is diffent than OEM shock and/spring setup to give you a lift or leveling.
    equin and KELZ84[QUOTED] like this.
  5. Jan 7, 2019 at 5:55 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    Nice Setup!!
    KELZ84 likes this.
  6. Apr 4, 2020 at 7:35 AM
    blackCat1
    blackCat1 New Member
    Tyler
    Black 2021 Toyota Tundra SR5 TRD sport Crewmax
    5100s up front on middle setting
    I know the 3"/1" is popular, but does anyone have a 5100s middle setting with a 1" shackle in the rear set up on a Crewmax? Pictures please.
    I want to do this set up, but I want to see what it looks like first. I haul a lot of wood and tools in the bed and don't want the rear end to sag when loaded.
    (I'm new on here so any guidance helps)
    Thanks,
    T
  7. Apr 6, 2020 at 11:21 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Can’t help you with the middle setting but here is 5100’s on the top setting with 1” ToyTech shackles. I have exactly 1” of rake and when I tow my 14’ enclosed trailer or boat, the truck sits perfectly level. 7B7A9515-55AD-4886-A53C-166A59B3062C.jpg
    tbutler likes this.
  8. May 7, 2020 at 4:32 PM
    blackCat1
    Tyler
    5100s middle setting, one CB shim on drivers side. Buuutt the rear is stock.
  9. Sep 29, 2020 at 4:40 PM
    fedorachef
    fedorachef New Member
    2020 Tundra CrewMax Platinum
    TRD Exhaust JL sub / Kenwood amp Fox 2.5 w/ dsc front and rear Fuel Blitz 20x9 Toyo AT III's LT285/55/20 TRD Skid plate Firestone riderite 2445's WirelessOne 2nd Gen
    I just installed Fox 2.5 w/ dsc front and rear. Front set at 2" lift out of box according to Fox. My truck sits 1" taller than rear now. So now wondering if I should do rear shackles to level or have slight rake or wait a bit to see if suspension settles. Fox recommended getting alignment then see how it sits after. I will say trying to adjust the coils is tough. With coilover on or off truck I can't get collar to spin. Tried with punch and with fox spanner wrench.
  10. Sep 29, 2020 at 5:09 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    If you backed out the set screw and it won't budge, you may need to compress the spring.
