2nd Gen TRD Pro Style Grille Insert
Discussion in '2nd Gen Tundras (2007-2013)' started by Rube207, Jan 26, 2021.
  1. Sep 3, 2021 at 4:10 PM
    #151
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I received my grille and it didn't come with the Toyota name badge.
  2. Sep 3, 2021 at 4:28 PM
    #152
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    Mine came in a separate package. Separate tracking number as well.
    Peeeheeuuu and Mattyc like this.
  3. Sep 3, 2021 at 5:07 PM
    #153
    audiowize
    Paul B.
    Groovy. The TSS insert is definitely a must!
    Rube207[OP] and Shanet421 like this.
  4. Sep 3, 2021 at 5:16 PM
    #154
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Agreed!
    mcharfauros likes this.
  5. Sep 4, 2021 at 12:40 PM
    #155
    idiggplants
    PA
    2013 DC 4wd
    ok! got my grill installed. wish i had a color matched surround, but ohh well. definitely a nice grille. an improvement over stock for sure. couple things to note... they send 8 screws with the toyota insert. 4 large, 4 small. dont use the large ones. they will poke through the grill. ask me how i know. lol.
    looking forward to getting the 3d printed insert, as the glossy nonsense that comes with it is awful. but even with that, its still an improvement over stock.
  6. Sep 4, 2021 at 2:37 PM
    #156
    Tundra1D6
    If you don’t have Ali baba or know how to use it where can someone get this ?
    Fleabay has them, but they are over 200+
  7. Sep 4, 2021 at 2:40 PM
    #157
    Shanet421
    San Diego,CA
    Alibaba only for now
  8. Sep 5, 2021 at 12:12 PM
    #158
    Caliwheysted
    Caliwheysted New Member
    Commiefornia
    08 CrewMax Limited 4x4
    Here’s my before and after. Just waiting for the nuts to come in. I forgot to order them from the dealer.
    I’m pissed at myself. I over tightened the screws for the emblem.
  9. Sep 7, 2021 at 4:57 PM
    #159
    mhp8884
    mhp8884 New Member
    Hi! Are you still selling the TSS insert piece? Thanks!
  10. Sep 7, 2021 at 5:03 PM
    #160
    Rube207
    Rube207 [OP] New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
  11. Sep 8, 2021 at 10:42 AM
    #161
    idiggplants
    PA
    2013 DC 4wd
    THIS IS VERY IMPORTANT.
    i did the same. in my case anyway, it wasnt overtightening, it was that they shipped the emblem with 2 sets of screws... one set was too large. i didnt even find the second set of screws till after i made the mistake. 4 screws, 4 holes... these must be the right screws, right? wrong. if you use the larger screws, use at least a few washers on each one. but its better to use the small washers.
    also something to note, is the new grill comes with new clip nuts to go on the new grill. they are the things that the 10x m10 bolts screw into in order to fasten the grille to the hood. they are garbage. its real easy to take the oem clips off of the oem grill and put them on the new grille.
    these look similar to what you get:
    and really, these are probably a bit heavier guage sheet metal than what you get. regardless, the bolts get as much bite as the thickness of the sheet metal. probably 1 thread worth.
    the oem ones look like this:
    obviously much more bite. you can see why its better to use the oem ones. probably took like 2 minutes extra to remove the oem ones. i highly recommend doing so.
    and it was already noted in OP's first post, but ill post it here as well in case you missed it. after using these 4 small screws for the emblem, there are no small screws for the hood latch lever. the screws used in the oem grill are too large. you are going to want some screws that are a similar size to the small ones that you used for the emblem.
    Fett1138, Hilandr, D4x4TRD and 2 others like this.
  12. Sep 8, 2021 at 2:09 PM
    #162
    audiowize
    Paul B.
    I definitely paused this morning when I went to put the Toyota emblem on and opted for the small screws based on this advice.
    McYoda likes this.
  13. Sep 12, 2021 at 7:52 AM
    #163
    D8181V3
    D8181V3 New Member
    2013 Tundra
    Just adding another pic for the thread
  14. Sep 12, 2021 at 10:56 AM
    #164
    Rube207
    Rob
    Atlanta
    Looks great Mike!
  15. Sep 12, 2021 at 12:04 PM
    #165
    audiowize
    Paul B.
    I got mine stuffed on today.
    Peeeheeuuu, McYoda, Blang805 and 2 others like this.
  16. Sep 13, 2021 at 7:11 AM
    #166
    D8181V3
    D8181V3 New Member
    2013 Tundra
    It's hard to tell in this photo as I tried to crop it but the piece came out nice and fit great. Very happy with it and how it looks and blends much better than the plastic piece it came with before. Much appreciated, Rob!
    Rube207[QUOTED][OP] likes this.
  17. Sep 16, 2021 at 4:22 PM
    #167
    07tundradad
    07tundradad New Member
    Alex
    Hi all, I have been following this tread and it's amazing. I have 07 Tundra that my late father passed to me and would like to give it a face lift. I've read that I need an 10-13 surround so that I can install the grill insert from Alibaba seller. Anyone have success doing this and can offer guidance on 10-13 surround that will fit 07 Tundra? Any advice would be appreciate it. I am attempting to see if anyone has had success with this.
    Peeeheeuuu likes this.
  18. Sep 16, 2021 at 5:00 PM
    #168
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I did the same thing. Fixed it with a heat gun on low and gently pressing it back into place. Be VERY careful and do it slowly and you’ll never see the punctures again. Mine came out like new
    Caliwheysted[QUOTED] likes this.
  19. Sep 16, 2021 at 5:24 PM
    #169
    audiowize
    Paul B.
    Yes, I just did this on my 08. You need the 10-13 surround and some extra parts. Sparks has the extra parts here: https://www.sparksparts.com/p-2010-grille-assembly-installation-kit-for-2007-2009-tundras-pk53100kit
    When you remove the old grill, it will become abundantly obvious where the two steel brackets go. On your hood, you'll need some plastic pry tools (Harbor Freight has a good set for a few dollars ) to pop out the white plastic pieces that receive the screws from the old grill. With all those out, the yellow pieces from Sparks go in the middle holes. The two outside holes don't appear to be used. The new grill surround will have little nodules that pop into the yellow pieces. The screws from Sparks will attach the surround to the brackets that you replaced. The only old hardware I reused was some of the hardware used to mount those brackets.
    On the 10-13 grille you get, I found it easier to take a pair of tin snips and cut apart the old insert so it comes out very easily, as it's a tight fit.
    The hood latch release requires different screws. For what it's worth, a Metric sheet metal screw sized M2.9 at about 12mm length seems to work about right. I would get some washers also since the screw head may want to pass through the release. If you're feeling really brave, you could probably drill and tap for a 4-40 machine screw.
  20. Sep 16, 2021 at 5:41 PM
    #170
    07tundradad
    Alex
    @audiowize thanks Paul, incredibly helpful. If you recall any other challenges, please let me know.
  21. Sep 26, 2021 at 10:11 PM
    #171
    brettski7
    brettski7 New Member
    Brett
    Ordered tonight from same as OP for $150 shipped to MD. Also picked up a MGM Rock warrior grill from someone local to install it into. Got to start somewhere with getting rid of the chrome. Will post pictures once it comes in.
  22. Sep 29, 2021 at 11:35 AM
    #172
    brettski7
    Brett
    Already shipped and will be here this weekend likely. Also the Tacoma TSS insert will fit. May add some of the lights also up front since I don't like the Amber. Not decided though. Can always be added later.
  23. Oct 25, 2021 at 8:13 AM
    #173
    ][v][att
    ][v][att New Member
    2010 sr5 Double Cab Nautical Blue Metallic
    I'd love to try printing the file myself. PM sent! Thank you Rube.
  24. Nov 18, 2021 at 10:44 AM
    #174
    EagleClaw972
    EagleClaw972 New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    So it DOES fit on an 08 tundra? I got confused with all the threads...
  25. Nov 18, 2021 at 6:19 PM
    #175
    Rube207
    Rob
    Atlanta
    You will need an '10-13 grille surround and support brackets for the Alibaba grille insert to work on an '08. Then it will be a direct swap onto your truck.
  26. Nov 18, 2021 at 6:25 PM
    #176
    Shanet421
    San Diego,CA
    The Rube custom garnish is a must have imo as well
  27. Nov 24, 2021 at 10:51 AM
    #177
    MilesToEmpty
    MilesToEmpty New Member
    Charles
    2007 DC 4x4 Linited
    What is this custom garnish you are speaking of?
  28. Nov 24, 2021 at 1:10 PM
    #178
    Rube207
    Rob
    Atlanta
  29. Nov 24, 2021 at 1:45 PM
    #179
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Thats sweet!
    Rube207[OP] likes this.
  30. Dec 1, 2021 at 6:06 AM
    #180
    MilesToEmpty
    Charles
    2007 DC 4x4 Linited
    Can anyone provide me to the chrome, or unpainted 2010 grill surround? My Tundra is Sky Silver and Im pretty sure that isnt a pre-painted option.
