2nd gen cluster
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraCarter, Jan 31, 2022.
  1. Apr 14, 2022 at 12:46 PM
    #391
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    You guys should swap switches now and see if any of those work?
    You can send me your non dimming switches to see if they work in my truck. I find it hard to believe I just got lucky and I’m leaning towards wire harness differences.
  2. Apr 14, 2022 at 1:06 PM
    #392
    FredB32
    FredB32 New Member
    2011 TRD RW
    I'd be more than happy to send one out. I'll package it in a little smaller box though... No wonder these guys charged $10 shipping!
  3. Apr 14, 2022 at 2:00 PM
    #393
    FredB32
    FredB32 New Member
    2011 TRD RW
    So...that's a total bummer. Got my new heat gun and removed the chip from the old cluster...still only reads as a 24 EEPROM in the EZP software...and with the test clip attached I noticed it started to smoke a little bit. That can't be good at all. I noticed it sort of "bit" my finger when I was adjusting the chip and didn't think much, but the smoke coming off it...definitely bad! Guess I'm back to the modifying the CH341. Yikes.
  4. Apr 14, 2022 at 2:21 PM
    #394
    Dirtytun
    Dirtytun New Member
    2013 Black Tundra Crewmax
    This actually happened to me . It was getting so hot, it starting smoking. I had the wires backwards or the chip backwards.
  5. Apr 14, 2022 at 2:25 PM
    #395
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    so installing the switch took like 20-30 mins. Popping out the dummy plug and installing solar sensor and wiring it up took like 10 minutes…but getting the right connectors and getting them seated properly in the bcm took me like 6hrs over 2 days of trying!! I finally figured out that using 22g wire wasn’t a recommendation and was required and when I swapped my 18g wire for the 22g wire finished the install in 20 minutes!!
  6. Apr 14, 2022 at 2:26 PM
    #396
    FredB32
    FredB32 New Member
    2011 TRD RW
    Tried it both ways, upside down...nothing really worked. The other way it didn't read the chip at all, so I'm kind of at a loss. :boink:
  7. Apr 14, 2022 at 2:29 PM
    #397
    FredB32
    FredB32 New Member
    2011 TRD RW
    See, this is why we're here: you're a trailblazer...you just saved me, in theory, 6+ hours of fiddling with the wrong sized wire!
    Ohannon7 likes this.
  8. Apr 14, 2022 at 5:44 PM
    #398
    Musicmasterd12
    Southern Louisiana
    I try to be of assistance when I can!! I ran out of swear words during that project, he’ll I think I may have even made some new ones up!!
  9. Apr 14, 2022 at 7:29 PM
    #399
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Do you have a photo of the heat gun you used? I heard of hot air solder for chip removal, not a heat gun though. If you have your chip removed, send it to me and I'll see if I can program it on my set up.
  10. Apr 14, 2022 at 7:48 PM
    #400
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    There was no wiring harness change. The dimmer wheel was used in 2007-2013 trucks and the only thing that changed was the wiring color. Pin number and labels for each are the same across all years. The 2014 has a new cluster with the dimmer built into the ODO stalk.
  11. Apr 14, 2022 at 7:51 PM
    #401
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    We need more data on whos works vs whos doesn't. I still lean very strongly to a solar sensor, ecu in high trim trucks sending a signal (maybe CAN) to allow the optitron to DIM.
    You guys that it is working for what trim level is your truck? Did it come with auto AC (Digital AC Controls), Solar sensor from the factory? Auto headlights?
    You guys its not working for same question.
    Just adding the sensor in might not be good enough as a base model say AC ecu might not sending solar sensor readings to the cluster while the higher trim one will. Hard to say right now.
    One guy was supposed to report back tomorrow if his worked and he has a truck with factory solar sensor.
  12. Apr 14, 2022 at 7:56 PM
    #402
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Mine works: 2012 SR5 CM / formerly Texas Edition but I didn't add any solar sensors or have any on my truck, not that I am aware of.
    Edit: I have no auto AC or headlights either.
    Jeff_5_7[QUOTED] likes this.
  13. Apr 14, 2022 at 8:02 PM
    #403
    Musicmasterd12
    Southern Louisiana
    do you have auto headlights? Auto ac?
    When I added my auto headlights my research showed that the solar sensor has 5 wires (3 have to do with auto headlights and remaining 2 were for the auto ac). So still don’t get how that would tie into optitron cluster
  14. Apr 14, 2022 at 8:07 PM
    #404
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The AC ecu or maybe even body control ecu unit can report the the level from the Solar Sensor to the rest of the ECUS of the truck on the CAN bus. Basically, the AC ecu could tell the cluster hey the sensor says its really bright so its daytime or the sensor says its not bright so its nighttime. I am not sure if it is doing this but it could.
    If true the cluster could be waiting for a message on the CAN bus to tell it if its day or night time and if it should allow the dimmer to work or not.
  15. Apr 14, 2022 at 8:09 PM
    #405
    Shanet421
    San Diego,CA
    Mine worked SR5 2013
    no auto lights or a/c
    Tundra3k likes this.
  16. Apr 14, 2022 at 8:22 PM
    #406
    Musicmasterd12
    Southern Louisiana
    this is what makes it seem like there is no rhyme or reason to it. At this point I wish I had another optitron cluster just to try and see if it was actually the cluster itself
  17. Apr 15, 2022 at 7:20 AM
    #407
    FredB32
    FredB32 New Member
    2011 TRD RW
    It's this one from Amazon:https://www.amazon.com/gp/product/B09MYLSC77?ie=UTF8
    I did it pretty slowly to just the point where the chip popped off.
    It's the one from my original cluster, so I may give the CH341A a go again this weekend and see if I can do it myself, but if not, it's headed your way!
  18. Apr 15, 2022 at 7:31 AM
    #408
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
  19. Apr 15, 2022 at 7:34 AM
    #409
    FredB32
    FredB32 New Member
    2011 TRD RW
    I thought about it, but I have multiple uses for this one as well, that the other one wouldn't fit the bill for. It didn't make a lot of sense to invest into something that would have little to no use after removing a single chip...
  20. Apr 25, 2022 at 10:35 AM
    #410
    cfe4130
    cfe4130 New Member
    I got my Optitron speedometer in and the gas gauge works fine. What is the best way to get the mileage corrected?
  21. Apr 25, 2022 at 10:48 AM
    #411
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
  22. Apr 25, 2022 at 11:00 AM
    #412
    Showtz
    Showtz New Member
  23. Apr 25, 2022 at 11:11 AM
    #413
    Showtz
    Showtz New Member
    Gauge is back from programming and I installed a new tinted cover on from Toyota. I’m very happy with the upgrade and additional settings that I can adjust. It looks so much better than the old orange faces.
    I have the all black dimmer switch. When you adjust it all the way up there is no notch for full brightness. Unfortunately it is not dimming with the headlights. I am watching this forum to see if any of the Toyota dimmer switches will correct this.
    I had the dealer remove seatbelt chime when I first bought the vehicle. There are some situations like driving in on private property to go hunting that i don’t want it going off. After I installed the Optiron gauge the seatbelt chime is going off again when you are not buckled in.
  24. Apr 25, 2022 at 11:28 AM
    #414
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Try these
    4 PCS Car Seat Belt Clip,Universal Seat Belt Buckle Auto Metal Seat Belts Clip https://www.amazon.com/dp/B08L3FPNB5
  25. Apr 25, 2022 at 11:31 AM
    #415
    Showtz
    Showtz New Member
    I could use those for hunting. There are other scenarios like backing up trailer that I don’t want seat belt chime going off. I have the cable but was never able to get tech stream working. I’ll prob have the dealer turn it off again.
  26. Apr 25, 2022 at 12:20 PM
    #416
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    did they charge you to turn it off?
  27. Apr 25, 2022 at 12:42 PM
    #417
    Showtz
    Showtz New Member
    the first time they didn’t charge since they were already connected for TPMS
  28. Apr 25, 2022 at 5:06 PM
    #418
    Musicmasterd12
    Southern Louisiana
    Showtz[QUOTED] and joseph_womack like this.
  29. May 3, 2022 at 6:18 AM
    #419
    FredB32
    FredB32 New Member
    2011 TRD RW
    Phew - been swamped lately but wanted to circle back here. I've noticed a couple things:
    1. Installing the Optitron cluster made my seatbelt chimes start up again. I need to hook up the laptop and turn them off...
    2. I noticed that the trans temp needle was WAY off to the left when cold. I worried at first that it might be broken and I just didn't notice, but it creeps up as I drive. Settles in at about a quarter way, so I think it'll just need a little adjustment.
    With the above said, does anyone have a pic of where the trans temp needle should start? I'm guessing it's as simple as popping it off and re-installing in the correct starting place.
    Also installed my new integrated rear camera, figured out there must have been a connection issue or something with the other cam, so I'll be re-purposing it to a front cam. Win-win!
    joseph_womack likes this.
  30. May 4, 2022 at 11:24 AM
    #420
    chrisf111
    chrisf111 New Member
    I'll admit I didn't read this entire thread, but wanted to share some of my experience with non-dimming switches. The dimming function works based on 2 things. The ILL+ side is just switched 12V power that works with the tail light assembly, the ILL- is where the dimming happens. The dial to change brightness gets fed into the cluster and to a chip that converts the signal to send to the negative side of the switch lights. It can vary between 0 and 12V. 0V and you get full brightness, 12V and the lights are off (at 12V both sides of the switch light are at 12V and there is no voltage across the bulb.
    In the process of installing a new switch I connected two wires wrong and shorted out the negative side of the circuit. My temp fix was to wire that side of the circuit directly to a ground. This gave me 12V of voltage difference across the bulbs, only when they were supposed to be on in the first place (12V comes through the headlight/taillight trigger). This worked fine, but no dimming.
    To fix the dimming I had to take apart the entire cluster to find the issue. There is a chip K1284 that was clearly the culprit. This is the chip that send the 0-12V signal to the negative side of the circuit. With this chip blown up, there was no ground to the circuit and thus no lights. In order to fix I would need to replace that chip (and hope no other part of the circuit board was affected) or replace the whole board. I went with replacing the whole board. I have a Optitron board waiting for me when I get home today. Found it on ebay for $100 shipped. There are others on there in the same price range.
    See attached picture of blown up chip.
    Process for resetting the needles is simple. Remove cluster and cover. Pull off needle that needs to be calibrated. Start truck and then turn off to get dial to "off position". Dial will be in the correct spot. Reinstall needle to point the correct spot in "off position". For trans temp it should be at the low side of the dial.
    Update: Installed the new cluster. Took all of 15 minutes. As suspected my switch dimming issue is fixed.
