285/75/18 Will it Rub?
Discussion in 'Wheels & Tires' started by cdmagor, Aug 21, 2018.
  1. Oct 28, 2020 at 7:36 AM
    #91
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    How do you like the Wheeler's AAL? Did it give you an inch of lift as they claim?
  2. Oct 28, 2020 at 6:01 PM
    #92
    biebs96
    PA
    I’m on 285/75 on stock wheels, no spacers, no rubbing.
    5100s middle setting, truck was dead level. Added a 1” lift in the rear to regain the “truck” rake I prefer.
    I trimmed about 3” off each side of the skidplate as a precautionary action, it was close but did not hit.
    I already had all of my mudflaps removed, so I can not comment on rubbing with that.
    Clears the UCA about 3/4”
  3. Oct 28, 2020 at 6:09 PM
    #93
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Yea it did, I have a full decked system so it’s just over factory height so it got rid of the sag from the weight and gave me just a little. You do have to purchase a new u bolt kit to install it though.
  4. Oct 29, 2020 at 6:54 AM
    #94
    danno266
    danno266 n00b
    With the Fox 2.0 system and no rear lift, I'm sitting at a 1/2-inch rake due to my canopy. I've had these in mind for a bit since I also tow some relatively light to medium loads. How does the rear feel with that leaf installed?
  5. Oct 29, 2020 at 7:34 AM
    #95
    19crewmaxTRD
    Seth
    With the weight I have back there now between 5-600 lbs it feels like an unloaded truck and matches the stiffness of the front 5100 on the top setting. Definitely not a huge difference from stock but it is noticeable
  6. Oct 29, 2020 at 7:37 AM
    #96
    danno266
    danno266 n00b
    Thanks! I'm going to go for it and get a set. Also appreciate the heads up on the u-bolts.
    19crewmaxTRD[QUOTED] likes this.
  7. Nov 28, 2020 at 11:55 AM
    #97
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    I have the following setup right now.
    Trd pro fox shocks (2” level from stock)
    Trd skid plate
    Trd pro bbs forged wheels
    So would the 285-75-18 (looking at Goodyear Duratracs) fit with my setup without rubbing and modifications other than the front mud flap? Am I better off with 295-70-18?
    Seems like a different manufacturers fit differently even with the same tire size.
  8. Nov 28, 2020 at 12:05 PM
    #98
    biebs96
    PA
    They will fit. I am on stock wheels (same offset as yours)
    Tundra1078[QUOTED] likes this.
  9. Nov 28, 2020 at 4:48 PM
    #99
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I’m having those tires installed on stock TRD Off Road wheels with the TRD Pro suspension on Tuesday. I’m going to remove the little front mudflaps beforehand. My skid plate is RCI, though, so no worries there.
  10. Nov 30, 2020 at 5:26 PM
    #100
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    You will be ok, I have 285/75r18 Yoko X-AT, true OD is 35.1 and width is about 11.5, no rub at full flex and lock to lock
  11. Dec 2, 2020 at 11:24 AM
    #101
    Tundra1078
    Peter
    Los Angeles
    Can you take a pic from the side to see how much the tires come out. Love the look of those tires on your truck. This might be the perfect setup for me.
  12. Dec 2, 2020 at 11:29 AM
    #102
    Downytide
    GTA
    Thought about adding spacers, but not keen for rock chips.
    Tundra1078[QUOTED] and equin like this.
  13. Dec 2, 2020 at 12:02 PM
    #103
    19crewmaxTRD
    Seth
    Does anyone else rub just the sway bar at full lock with there 285/75r18s? I rub just enough that I want to do something about it.
    Current options would be
    Option 1 remove sway bar, that’s my least favorite as I tow quite a bit and my truck is always loaded.
    Option 2 adjust steering stops, I’m kind of on the fence here as I would lose some turning radius.
    Option 3 would be grind a relief in the sway bar (keeping it cool to make sure I don’t mess up grain of the metal) I like this option the best but I’m not sure I like the idea of grinding on the sway bar. It should twist in the middle of the bar, so where I would be grinding shouldn’t see any twisting load, but it will be used as a lever for the twisting load. Seeing as how this area is necked down to just 1/4 flat where it connects to the end rod I can’t see it being weaker than that area.
    thoughts?
    pics
  14. Dec 2, 2020 at 2:10 PM
    #104
    Tundra1078
    Peter
    Los Angeles
    which brand of tire for that size does it rub?
  15. Dec 2, 2020 at 2:17 PM
    #105
    Downytide
    GTA
    I don't have it on mine, but that doesn't seem worrisome to me, I've had way worse on track cars and the sway bar didn't break after years of abuse.
  16. Dec 2, 2020 at 2:33 PM
    #106
    19crewmaxTRD
    Seth
    The tires are copper at3 xlt. I think I’d only have to grind out an 1/8 of an inch.
  17. Dec 2, 2020 at 7:59 PM
    #107
    biebs96
    PA
    I checked as well.. I do not have any rubbing on the sway bar (285/75, stock wheels)
    Y0TA PR0 likes this.
  18. Dec 2, 2020 at 9:21 PM
    #108
    Tundra1078
    Peter
    Los Angeles
    What brand of tires? Seems like rubbing occurs based on the brand of tire.
  19. Dec 2, 2020 at 9:58 PM
    #109
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    7B55BBE3-4F47-4A83-B245-421AE5A26BA9.jpg Mine has a slight rub also...same spot. Running 285/75/18, stock wheels with Toyo AT2 tires.... time for new wheels!!
    COTundra23, toyofan87, equin and 2 others like this.
  20. Dec 3, 2020 at 3:22 AM
    #110
    biebs96
    PA
    yokohama x-at
  21. Dec 4, 2020 at 9:34 PM
    #111
    Tundra1078
    Peter
    Los Angeles
    Anyone have 285-75 as a spare? Does it fit?
    Pangaea and biebs96 like this.
  22. Dec 5, 2020 at 9:52 PM
    #112
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    Mine rubs pretty annoying thinking about removing my flaps. Don't want too though.
  23. Dec 6, 2020 at 3:32 AM
    #113
    biebs96
    PA
    start with the front ones on the front bumper.
  24. Dec 6, 2020 at 8:53 AM
    #114
    Tundra1078
    Peter
    Los Angeles
    what brand of tires?
  25. Dec 9, 2020 at 8:59 AM
    #115
    COTundra23
    COTundra23 New Member
    What option (1,2 or 3) did you go with for the RXT leaf pack? Great looking truck!
  26. Jan 2, 2021 at 8:23 PM
    #116
    Bronzeback
    Bronzeback New Member
    x2. Debating between 285/75 and 295/70. Like a taller skinnier tire but i dunno if it’s gonna fit
  27. Jan 2, 2021 at 8:39 PM
    #117
    McCrapper
    McCrapper New Member
    It trips me out how each truck has so much variance. I like this tire size but it’s a crap shoot if it will fit with stock wheels.
  28. Jan 2, 2021 at 8:45 PM
    #118
    cmack
    cmack New Member
    AZ
    2018 Burrito
    yes I have one as a full size spare under the bed. The guide brackets will need to be cut or bent to accommodate. Also have heard if running CB shackles it won’t fit. I have toytec adjustable ones and I fit my spare no issues
  29. Jan 2, 2021 at 8:49 PM
    #119
    Bronzeback
    seems like it’ll fit, and most guys have the Duratrac which is 35.1”. Most other 285/75 are around 34.8. Not much of a difference, but might be enough to keep from rubbing some spots. The width of the 285 helps. Some guys have problems with 295/70 and some don’t as well.
  30. Jan 2, 2021 at 8:51 PM
    #120
    Bronzeback
    I figured. I have CB+2 ready to go in. Might have to go 295/70. It’ll still be close but maybe that 1/2” makes a difference.
