285/65/20 On Stock Rims With No Lift?
Discussion in 'Wheels & Tires' started by plumber802, May 22, 2018.
  1. Jan 15, 2023 at 11:27 AM
    #121
    JT828
    JT828 New Member
    2019 Platinum
    Thanks for the reply. I have 20” platinum wheels and a 2.25/1” level.
    I was going to run 275/65/20 but I want 285/65/20 if I can. I do not want to have to use wheel spacers for UCA clearance.
    How much space do you have between your tire and the UCA? Do you have any pics of your setup on the truck?
  2. Jan 15, 2023 at 11:47 AM
    #122
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    I’ve got the Bilstein 5100s on all four corners, set to the middle setting up front.
    No idea how much clearance I have from the UCAs, but I imagine it is pretty close but I do not hit them.
    I was able bend the skid plate out of the way and removed front mud flaps, but I still make slight contact with my TRD sway bar when near left full lock.
