285/65/20 On Stock Rims With No Lift?
Discussion in 'Wheels & Tires' started by plumber802, May 22, 2018.
  1. May 22, 2018 at 2:40 PM
    plumber802
    plumber802 [OP] New Member
    Andy
    Vermont
    2018 White Platinum CM
    Like the title says,I want a more aggressive tire that will fill in the wheel wells without a lift/level.I would also like to add spacers to the stock rims to improve the stance.Thanks in advance for any opinions/advice.
  2. May 22, 2018 at 3:55 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Spacers I've had excellent results with my SpiderTrax.
  3. May 23, 2018 at 3:12 AM
    plumber802
    Andy
    Vermont
    Thanks bud. Is the Tundra bolt pattern for a 2018 5X150?
    Cue_32 likes this.
  4. May 23, 2018 at 3:52 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I don't have an 18 but I believe all Tundras 07+ are 5x150
  5. May 23, 2018 at 5:42 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    if you try to use wheel spaces with a 34.5" tire and no lift, you are going to severely rub. you might be able to make that size tire work with no spacers, but you will be doing alot of trimming. you will have better luck with a 285/60/20 tire.
  6. May 24, 2018 at 12:16 PM
    plumber802
    Andy
    Vermont
    Thanks for the info.I want to avoid lifting so my thought was that maybe spacers would allow a 285/65/20 tire to clear.
  7. May 24, 2018 at 12:33 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I'm running 285/55r20 without a level or lift on a 2017 2wd. It's close, but zero rubbing at any time. 285/65 will definitely rub.IMG_20170915_192823409.jpg
  8. May 24, 2018 at 12:47 PM
    Netmonkey
    Georgetown, TX
    Wheel spacers make the turning clearance worse. Don't use spacers and stick to 285/60/20.
  9. May 26, 2018 at 3:15 AM
    plumber802
    Andy
    Vermont
    Thanks Netmonkey.I had a 285/34.5" tire on my previous truck (Duramax) and really liked the way they looked.I want to keep all the radar/safety features working properly which is why I am holding off on a lift.
  10. May 26, 2018 at 5:21 AM
    Netmonkey
    Georgetown, TX
    i have heard of some lifted 2018 tundras having issues with the TSS feature, but i think most people just disable it? but i also know that there are guys lifting their 2018's with no issues. have a chat with the guys at toytec lifts (https://www.tundras.com/forums/toytec-lifts.24/). they might have a better insight into the issues and solutions. the tire size that you want is totally reasonable with a 2 inch lift.
    zcarpenter92 likes this.
  11. Jun 12, 2018 at 4:43 PM
    plumber802
    Andy
    Vermont
    Yes,it's looking like I will need a lift to fit the 285/65/20 tires with the wheel spacers.
  12. Jul 15, 2018 at 6:26 PM
    Vladdroid
    Vladdroid New Member
    Vlad
    2013 White Tundra DualCab 2WD
    Leveled on Bilstein, Toyo's, and nothing else really
    Late reply. But I have a 3" leveling kit on front. Nothing on back . Running 295/65/R20 on Toyo A/T Xtreme's. No issues. No spacers needed .Stock platinum 20's. Only when I go full crank to the right and reverse, then it's a tiny rub..... So idk...
    NoRcptn, Hol Milk and LiftMeUp like this.
  13. Jul 16, 2018 at 2:50 AM
    plumber802
    Andy
    Vermont
    No worries Vlad.My truck goes to the dealership on Wednesday to have my Bilstein 5100s installed.I will be using the top setting which should give me approximately 2.25" of lift.As a compromise I think I will be going with a 275/65/20 tire which is about 34" tall.Also,I may ask the tire shop to try a 285/65/20 and see if there is any rubbing.They have a 30 day return policy so if they don't work then I can drop down to the 275/65/20s.
    LiftMeUp likes this.
  14. Feb 6, 2019 at 7:03 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    @plumber802 which tire size ended up working for you? I’m getting the bilsteins 5100 done next week on the front 2.5” nothing on the rear, currently have 285/55/20 but want to go to a taller tire...
  15. Feb 6, 2019 at 7:17 PM
    Disfigurative
    Disfigurative New Member
    james
    18 black TRD sport
    I have a 2018 with a 3/2 lift and 295/60/20’s. All of my tss features work perfect.
  16. Feb 6, 2019 at 7:34 PM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    I have 275/65/20's on my truck with Bilstein 5100's on the top setting with mine. I still had to do some trimming and hot gunning to get them to fit. I do not have spacers but you will definitely have rubbing.
    OR18TRD likes this.
  17. Feb 6, 2019 at 7:36 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @onetohunt after you did all of that did you still have rubbing? Also Do you have any pics where you did the trimming?
  18. Feb 6, 2019 at 7:40 PM
    onetohunt
    Marvin
    I still had a small amount in reverse only. I had to use the hot gun some more and finally got it taken care of. I don't have any pics at the present but will take some tomorrow in the daylight and post them up.
    LiftMeUp, OR18TRD and KELZ84[QUOTED] like this.
  19. Feb 6, 2019 at 7:41 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
  20. Feb 6, 2019 at 7:43 PM
    onetohunt
    Marvin
    your welcome, one thing I failed to mention, I have these on 20x9 vision wheels with a +12 offset.
  21. Feb 7, 2019 at 4:41 AM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Can I see a pic of your truck? I am running a 3/1 RC leveling kit on a 2018 CM. Factory XP Wheels 20x9. Running the factory 275 55 20s until they wear out.
    You have no rubbing?
    Did you have to remove any of your mud flaps?
    Thanks
    Disfigurative[QUOTED] likes this.
  22. Feb 7, 2019 at 9:07 AM
    Disfigurative
    james
    18 black TRD sport
    Stock TRD 20 inch wheels at + 60 offset. Had to bend the skid plate and remove front Mud flaps, but it still rubbed on the sway bar. So I got 1.25 spacers and that took care of the sway bar rub, but caused a front wheel well liner rub. So i had to heat gun the front wheel well liner a little and now its all good, no rubbing. I use my Radar cruise control every day and all the other Safety features work fine too
  23. Feb 7, 2019 at 9:40 AM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    Awesome! I appreciate your time Bro! Good looking set up.
  24. Feb 7, 2019 at 9:49 AM
    Disfigurative
    james
    18 black TRD sport
    no problem.. i guess the takeaway from my rambling is,if you have the correct offset all you might have to do is remove front mud flaps and do some minor heat gun work. What is the offset of the TSS wheels?
  25. Feb 7, 2019 at 10:16 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Looks good! I have my 3/1.5 system sitting around waiting for me and am planning 295/60s on my stock wheels as well. Do you have a new UCA?
  26. Feb 7, 2019 at 10:20 AM
    Disfigurative
    james
    18 black TRD sport
    stock UCA, but before I used the spacers the tires were Way too close for comfort
  27. Feb 7, 2019 at 10:27 AM
    bigblue14
    Craig
    Right I think I've seen this picture before! I have the SPCs, wheel spacers, and bumper spacers so hopefully serious cutting can be avoided.
  28. Feb 7, 2019 at 10:34 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    My stock TSS wheels are +50 offset. I reslly Don’t want to change my rims so to understand a lower number offset is better?
    TundraXPLover likes this.
  29. Feb 7, 2019 at 10:35 AM
    Disfigurative
    james
    18 black TRD sport
    Yea, I posted before i got my spacers. It looks like you should be fine... I am thinking about putting in the bumper spacer after these tires wear out and maybe bump up a size.
  30. Feb 7, 2019 at 11:00 AM
    Disfigurative
    james
    18 black TRD sport
    Well, not necessarily better it depends on the look you are going for and the fit you need. Essentially the lower the number the further the tire will stick out(I think.. i am no expert). but the lower offsets could just bring different problems like more rubbing in the front bumper.
    Just for an example, My Wheels are +60mm. I added a 1.25 inch(32MM) spacer that would bring them to about a +28MM.but that also pushed the wheel out and closer to the bumper when i turn..
    If i am talking out of my ass someone can chime in and correct me.. but thats my understanding.
    plumber802[OP] and TundraXPLover like this.
