285/65/20 On Stock Rims With No Lift?
Discussion in 'Wheels & Tires' started by plumber802, May 22, 2018.
  1. May 2, 2019 at 9:30 PM
    #61
    Pupule Mike
    Pupule Mike New Member
    2015 Tundra Limited Crew Max
    Does it handle better with the wider tires? How the ride quality?
  2. May 3, 2019 at 1:54 PM
    #62
    LiftMeUp
    LiftMeUp New Member
    Wow, I'm running 275/60/20s on all stock. Want to lift the front by 3" and run 285/65/20s on stock wheels, but there was a question from tire dealer about whether I would have issues so one suggested that I run your size. But you're running those with stock, no lift and have no rubbing issues, after skid plate bend. I know the 285s are a bit wider, but we're talking less than .4" and I don't have discount tire near me. Guess, put on the lift and see what I'm working with before deciding on tires. Thanks!!!
  3. May 3, 2019 at 2:20 PM
    #63
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Had 285/55s on for the last four years. I don't think there was any noticeable difference in ride quality. This is on a 4x4.
  4. May 3, 2019 at 2:21 PM
    #64
    Drew615
    Drew615 New Member
    Tennessee
    2014 Red Tundra Ltd Sport Edition
    Tires 275/65/20, TRD Exhaust, TRD Sway Bar, Dual Air Intake
    I ran across a post somewhere about 18-months ago where someone said it would work, but they had no photos and others chimed in saying they didn't think that was the case. Was going to buy an '18, but ran across a very low mileage '14 from a farmer - only downside was that the gravel roads had chewed up the tires pretty good. Decided to try it and ran it for 1k miles before I ran into a situation where I had to do a hard-U in the middle of road and that's when I found the rubbing - took a 1k miles before I found the rub if that tells you anything. Bent the skid plate up and haven't looked back. My only real concern would be for someone up north that had to deal with packed snow/ice in the fender wells. Again - not a monster truck or huge tires, but now looks like a truck. The gearing / engine rpm's are perfect for this setup in my opinion. Tire dealer had a set of new takeoffs that were 285/60/20's I almost went with, but I really wanted the taller tire - gives a little over an inch more of ground clearance. If you go with an A/T tire it squares up the fender wells much better so the tires don't look tucked under nearly as bad as the rounded P tires. I obviously can't guarantee every tire is the exact dimension and mine is a 4x4, but there is still a little room just in case. I think the rubbing issue may have come from people that were using spacers which not only push the tire out, but also changes the way the tire interacts with the wheel wells when the tire turns. As far as the 285/65/20 - would probably work, but you might see rubbing at full lock on the foward splat - in that case, just take them off. If you go off-road a lot, you would probably want the lift or 5100's - I like the look, just wasn't willing to get into all of the hassles with that on my truck.
    LiftMeUp[QUOTED] likes this.
  5. May 3, 2019 at 2:24 PM
    #65
    bigblue14
    Craig
    I'm picking up my truck tonight with 285/65s installed on my stock platinum wheels. 1" spacers were needed for UCA clearance. Apparently I have a very slight front plastic rub and none in the back. I'll post pictures later.
    LiftMeUp likes this.
  6. May 3, 2019 at 2:28 PM
    #66
    Drew615
    Drew615 New Member
    Tennessee
    Awesome - be sure to post pics. On the front wheels you can remove / trim the splats if needed and I understand you can use a heat gun to bend the rear of the front wheel wells back enough if your just mildly rubbing at full turn.
  7. May 3, 2019 at 2:30 PM
    #67
    bigblue14
    Craig
    Spats are already removed - so hopefully it's nothing too serious with the heatgun!
  8. May 3, 2019 at 3:10 PM
    #68
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
  9. May 3, 2019 at 3:10 PM
    #69
    Drew615
    Drew615 New Member
    Tennessee
    Hopefully not. If its while turning the wheel - the spacer is likely exaggerating the issue. Going from a 275 to a 285 should be less than a quarter of an inch inside and a quarter of an inch outside - width difference based on what I'm seeing is only about .39/.40 of an inch difference in width total between the two tires, but I guess when you add in the height too I could imagine its getting tight. I'm sure you will be able to work it out - if you can't get it trimmed / melted in / cussed in, then you might consider a smaller spacer. The geometry gets in above my head, but I believe the spacer while helping the clearance on the UCA, also makes the liner rub worse when turning. Very curious to see what the 285/65/20 + the 1" spacer looks like on the truck - I might have to go shopping again.
  10. May 3, 2019 at 3:12 PM
    #70
    Drew615
    Drew615 New Member
    Tennessee
    Nevermind - I just noticed you were running the 285/55 currently. Still want to see what it looks like!
  11. May 3, 2019 at 3:22 PM
    #71
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    285/55 bfg ko2's.
  12. May 3, 2019 at 3:29 PM
    #72
    Drew615
    Drew615 New Member
    Tennessee
    Very nice - with or without spacer?
  13. May 3, 2019 at 3:31 PM
    #73
    easleycrawler
    Travis
    No spacer, lift or anything. The wheels are 20x9, offset is +50.
  14. May 3, 2019 at 4:36 PM
    #74
    bigblue14
    Craig
    Totally understand the spacer tradeoff. It's very close to 1" UCA clearance with the spacers. I do need to so some minor plastic cutting.
  15. May 3, 2019 at 4:42 PM
    #75
    bigblue14
    Craig
    Here we go. I think I'll have to cut/mold plastic but I'm clear of metal. Some rub at full lock and reverse. 285/65 Cooper AT3 XLTs
  16. May 4, 2019 at 8:03 PM
    #76
    Vladdroid
    Vladdroid New Member
    Vlad
    2013 White Tundra DualCab 2WD
    Leveled on Bilstein, Toyo's, and nothing else really
    Sorry I'm not here often. But I ended up swapping the UCA a bit after it. They got like 99% perfect alignment but it was very slightly off, not much but I wanted it perfect lol. Had to get UCA's for more adjustment range. But I guess the tires had alot to do with it not rubbing.
  17. May 6, 2019 at 9:43 AM
    #77
    LiftMeUp
    LiftMeUp New Member
    Looks sweet! Sorry, but what are the specs again for lift/level, wheel spacers, etc. Thanks.
    bigblue14[QUOTED] likes this.
  18. May 6, 2019 at 10:03 AM
    #78
    bigblue14
    Craig
    285/65/20s Cooper AT3 XLTs on stock platinum wheels with 1" Bora spacers. I have the Toytec Boss kit w/ the add a leaf kit (3/1.5) and SPC control arms. I pushed my front plastic forward so that doesn't rub anymore. The back plastics still rubs slightly. I'll trim it later. I could probably do without the spacers but it's fine for now.
  19. May 6, 2019 at 10:42 AM
    #79
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    thanks for the info..
  20. May 6, 2019 at 1:18 PM
    #80
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Out of curiosity, why the 1" spacers?
  21. May 6, 2019 at 2:48 PM
    #81
    bigblue14
    Craig
    I bought them just in case and let the shop decide while they were installing tires. I think it looks like they will clear but I need to grind down a 22mm socket to take them off. I didn't have the time to do that yesterday - so I just focused on trimming plastic.
  22. May 6, 2019 at 3:10 PM
    #82
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I may be wrong but I think the need for a spacer has to do with UCA clearance. My stock TSS wheels clear the BFG KO2s by about an inch. If I had spacers, I believe I would be in the same situation your pictures show. I have 1/2" clearance at the mud flap. Spats didn't clear.
  23. May 6, 2019 at 3:20 PM
    #83
    bigblue14
    Craig
    Yes you're right it was about UCA clearance. The tech thought they might be needed for the UCA clearance but it looks like plenty of room to me. Because of spacer / tire combination I have some slight plastic contact. I had the tools to change the plastic yesterday so I tackled that.
  24. May 6, 2019 at 3:42 PM
    #84
    easleycrawler
    Travis
    I've got plenty of clearance from the uca with my 285's without spacers.
  25. May 6, 2019 at 3:54 PM
    #85
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Is that the 285/65/20 you have?
  26. May 6, 2019 at 3:57 PM
    #86
    easleycrawler
    Travis
    285/55. But as much room as I have, still should leave enough room for 285/65's
  27. May 6, 2019 at 3:59 PM
    #87
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Yeah that’s what I’m currently running and have a lot of space. Waiting for tires to run down more so I can jump to 285/65. I have 2.5” Bilsteins front nothing rear and Spidertrax 1.25” spacers.
  28. May 6, 2019 at 5:56 PM
    #88
    bigblue14
    Craig
    I thought so too when I had 285/55s but bought the spacers just in case. I also bought bumper shims but don't need them now. I wanted to have all the knobs to turn when I put on the bigger tires.
  29. May 6, 2019 at 6:01 PM
    #89
    easleycrawler
    Travis
    I forgot to mention, my wheels are +50 offset.
  30. May 6, 2019 at 6:08 PM
    #90
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Same here +50 offset
