22+ 3rd Gen Wheel offsets/fitment thread
Discussion in '3rd Gen Tundras (2022+)' started by randomquickness, Dec 23, 2021.
  1. Jan 26, 2022 at 6:37 AM
    #181
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I have the 8” screen. That sucks they keep pushing everyone’s delivery date. I feel like it’s going to get worse, especially with the new Sequoia releasing later this year. I read an article before I even got my truck, that said they’re expected to be 18 months behind in production.
  2. Jan 27, 2022 at 3:27 AM
    #182
    tundrapolaris
    tundrapolaris New Member
    Ontario Canada
    2022 Tundra Platinum Blueprint
    Yeah i'm not getting my hopes up thats for sure. Too many factors. Every auto manfufacturer is in the same boat. Chips, other parts shortage, shortage of trained workers (people getting sick) transporting of incoming parts and finished vehicles and working the bugs out of this new launch.
    Rwaters[QUOTED] likes this.
  3. Jan 27, 2022 at 11:00 AM
    #183
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Installed pics yet?
    arrampico likes this.
  4. Jan 27, 2022 at 1:45 PM
    #184
    randomquickness
    randomquickness [OP] New Member
    I wish! No truck yet. I will have the tpms and tires mounted on Tuesday probably so i might have pics of the wheel/tire combo and what they weigh by then.
    Rwaters likes this.
  5. Jan 29, 2022 at 8:12 AM
    #185
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    Anyone have any good recommendations on lug nuts and/or know the size for the 2022?
  6. Jan 29, 2022 at 9:11 AM
    #186
    Summit72
    Summit72 New Member
    Summit
    2018 Tacoma TRD OR LB
    14x1.5 lug sizes I have yet to find et threads but it also all depends on what kind of rims you have. If they are conical or mag seating and so forth so make sure they are acceptable with your rims you get most manufacturers will sell lugs for their rims and “seating”
  7. Jan 29, 2022 at 9:54 AM
    #187
    MMTundra
    MMTundra New Member
    Thanks! Good info.
    Planning on going with black Method 316’s (18x9, 18mm offset) for my Army Green when it lands. Love the low weight of those wheels, there’s some better looking options but really can’t beat the weight.
    For tires I’m either going to go 35x12.5x18 or maybe 305/70r18 for something slightly slimmer after a Westcott lift (3” front, 1” rear). A little worried about trying to put a 35” spare tire under the truck, has anyone had experience with this? Will it fit, and will it actually fit well? I can’t imagine everyone’s putting 35’s on without a spare but I haven’t seen anyone post to confirm it yet.
    Dmon187 likes this.
  8. Jan 29, 2022 at 11:22 AM
    #188
    Bradanglin22
    Bradanglin22 New Member
    Brad
    So on the tires, I was in the same boat as you. I wanted to do 35x12.5/18 with the Westcott lift because I think that’s the best looking setup I’ve seen. But I also wanted to shave some sizing so the setup is actually functional. I ended up finding that the falken wildpeak at3w’s in 295/70/18 are 34.25x12 after inflation which I think will be perfect clearance! And I imagine it will also provide proper clearance for the spare. Plus that 1/4” difference saved me about 120 bucks a tire compared to 35x12.5/18.
  9. Jan 29, 2022 at 11:52 AM
    #189
    Rwaters
    Rwaters New Member
    What is that Westcott spacer lift going to run?
    MMTundra likes this.
  10. Jan 29, 2022 at 1:24 PM
    #190
    bigjuice
    bigjuice Researching and collecting parts…
    WA State
    2022 MGM Crew Max SR5
    I have been looking at those same wheels for that same reason (Gloss Titanium for my MGM CrewMax)
    …I even considered going down to the 17x8 to shave another 4 lbs off each wheel but I would like to reuse my current 295/70/18 Trailblade that I have on stock rims so it’s a decision I need to make as I would rather not buy rims AND tires.
    The 17’s are +25 offset though…not sure if those will be too tucked
    MMTundra[QUOTED] likes this.
  11. Jan 29, 2022 at 1:30 PM
    #191
    MMTundra
    MMTundra New Member
    I believe it’s just a bit over $400. Not too bad.
  12. Jan 29, 2022 at 1:31 PM
    #192
    MMTundra
    MMTundra New Member
    Nice, the titanium color would look awesome on MGM. I mean the +25 would be less positive than the stock right?
  13. Jan 29, 2022 at 5:46 PM
    #193
    bigjuice
    WA State
    I see your point there…Yes it would.
    I will do some measurements but as I think about it now I am inclined to pull the trigger on that setup.
    hairychestedfrog likes this.
  14. Jan 29, 2022 at 5:53 PM
    #194
    hairychestedfrog
    hairychestedfrog New Member
    Idaho
    22 Tundra SS Red Plt CM
    Need to look at wheel width also, a +25 on a 9" wheel will poke more than +25 on an 8" wheel
    MMTundra and bigjuice[QUOTED] like this.
  15. Jan 29, 2022 at 6:45 PM
    #195
    Rwaters
    Rwaters New Member
    When you’re playing with width and offset, that’s when backspacing comes into play. The setup bigjuice is talking about wouldnt be tucked. Just based on other setups that people have ran. I’d like to see it though
    bigjuice and hairychestedfrog like this.
  16. Jan 29, 2022 at 7:54 PM
    #196
    bigjuice
    WA State
    Thanks for the feedback
  17. Jan 31, 2022 at 1:00 PM
    #197
    Bradanglin22
    Brad
    I just called Method Wheels to get clarification on lug size as they sent me 12x1.5 extended... They confirmed that this is the correct set - not 14x1.5. I guess we'll see when my truck finally gets here... Whenever it gets here...
  18. Jan 31, 2022 at 1:08 PM
    #198
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    As soon as my wheels and tires get here I will post some pictures. Ordered 17” icons with a +25 and bfg ko2 315/70/17
  19. Jan 31, 2022 at 2:01 PM
    #199
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    The lugs are 14x1.5 on the 2022 not 12x1.5. I just put wheels on and had to get 14x1.5 after the 12s didn’t fit.
  20. Jan 31, 2022 at 6:09 PM
    #200
    Bradanglin22
    Brad
    I’ve read so many posts with the same testament… I find it odd that the method rep was so adamantly positive that it was the 12 extended. I think I’m just gonna order a set of 14’s too and then return the set that doesn’t fit.
  21. Jan 31, 2022 at 6:14 PM
    #201
    jgoliath
    Ya it’s absolutely not 12mm lol. They’re probably just sticking to the info they have. Top lug is a 12mm. Bottom is the stock 14mm. upload_2022-1-31_21-14-36.jpg
    Bradanglin22[QUOTED] likes this.
  22. Jan 31, 2022 at 8:36 PM
    #202
    Bradanglin22
    Brad
    You’re probably right lol! Dude made no sense.
    jgoliath[QUOTED] likes this.
  23. Feb 1, 2022 at 9:15 AM
    #203
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    Ordered a set of Method MR310 Con6 in Bronze 18x9 last night. Going on my Midnight Black SR5 which should be here end of this month. Believe it or not walmart.com had them in stock for 30% off, couldn't pass up the deal. Now to order some "correct" lugs. Lol.
    reywcms and Rwaters like this.
  24. Feb 1, 2022 at 10:14 AM
    #204
    Summit72
    Summit72 New Member
    Summit
    Anyone run balance beads ? I have in the past and never seemed to have any problems. I’m just a bit nervous if I run 17’s with wheel weights they may come in contact with the caliper. Just some food for thought.
  25. Feb 1, 2022 at 11:10 AM
    #205
    Rwaters
    Rwaters New Member
    In my experience about seven years ago the balance beads tear up the inside of the tire (inner liner). Maybe I’m thinking of the sandbags you can buy, it’s been so long I can’t fully remember. I’m sure someone with actual experience now days will have a much better opinion. Maybe some of that technology has changed. Because of that past experience I had with a couple of customers that were adamant on using them I’ve never tried them personally.
  26. Feb 1, 2022 at 1:39 PM
    #206
    bigjuice
    WA State
    I wondered aloud about this (on another thread perhaps) on running 17’s with such little caliper clearance.
    Is this something I need to worry about should I run 17’s
    1- Tire shop put wheel weights in an area that doesn’t have best clearance?
    2- Rock getting caught in between that same area (I drive/park on a fair share of gravel /unimproved roads)
    I’ve only ran 18’s before on my 2015 but like 17s for a variety of reasons with weight being the biggest one…so asking those who may know more on running this setup.
  27. Feb 1, 2022 at 3:15 PM
    #207
    DexterL
    DexterL New Member
    pretty sure clearance is the same as the prior gen and there are TONS of us running 17’s with no issues. One of my favorite places to fish is 20 miles of dirt/ gravel roads each way, I haul ass in there going 40-60mph a shit ton of times a year and never have had any gravel issues
    bigjuice[QUOTED] likes this.
  28. Feb 1, 2022 at 3:31 PM
    #208
    bigjuice
    WA State
    :thumbsup:
  29. Feb 1, 2022 at 3:48 PM
    #209
    randomquickness
    Welp, I got my tires mounted! My goal was 80lbs or under. Mission accomplished!
    273156808_10113530122563402_126074760345_345d59bae85a491814dccf084ece4bc897225e8e.jpg
    272956187_10113530122588352_646770250522_853ae061058e3f19e1a9ffcecec453e83c59a0bf.jpg
  30. Feb 1, 2022 at 4:33 PM
    #210
    hairychestedfrog
    Idaho
    Well done! That's impressive for a 34" tire.
    Do you know the weight of the stock setup?
