22+ 3rd Gen Wheel offsets/fitment thread
Discussion in 'Wheels & Tires' started by randomquickness, Dec 23, 2021.
  1. Dec 26, 2024 at 5:40 AM
    #541
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    I debated 17 vs 18 too but went with 18s to avoid any tight clearance issues, plus it snows here and ice can build up in there. I just put on method 316 18x9 +18 with 35x11.5 Wildpeaks but I do have TRD lift. Removed bracket in rear of front wheel wells but it rubbed the front liner too. Used big zip ties around the front plastic bracket behind the liner to the front bumper then heated the plastic up with heat gun before tightening zip ties to pull the liner forward maybe an inch. Installed EGR painted flares that added maybe 3/4 - 1" to eat up some poke, top of the tread is about flush with the new flares.
    Here's before and after the flares:
    20241220_150206.jpg 20241220_163859.jpg 20241220_121725.jpg 20241220_163940.jpg
    Ohbewan23 likes this.
  2. Dec 26, 2024 at 7:02 AM
    #542
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Opinions based on what I've seen/read here:
    1) You're going to have a tough time at stock height with a 35" tire.
    2) Both 17" and 18" same width rim? +25 offset= slight poke, maybe a little more than slight depending on your definition. +18 = 1/4"+ more poke than that.
    I'm going 18X9 +12 offset with a 285/75/18 (a skinny 35) and it will poke a fair amount. I'll be adding aftermarket (EGR or RC) flares for more coverage.
    If you can wade through the monster thread on 3rd gen wheels and tires, you'll likely find both your combos there with pictures.
  3. Dec 26, 2024 at 11:09 AM
    #543
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    that's probably the main issue right now, they also have a 285/75/17 as well as a 285/70/18 which might work better for me, basically the same size 275/65/20 I'm currently running on stock weels, just a little wider but smaller offset wheels should take care of any issues. Both C rated 6 play since I was trying to avoid a E 10 ply to keep things more comfortable to ride. I might have to keep it 34ish to avoid major problems or rubbing
    Bjoew likes this.
  4. Jan 16, 2025 at 4:37 AM
    #544
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Rims are in! Now, do I go with 35’s?
    4mm and mach1man001 like this.
  5. Jan 16, 2025 at 4:40 PM
    #545
    Mastortillas
    Mastortillas New Member
    Larry
    2025 Tundra Limited TRD Off Road
    None
    Is anyone else finding that when you select a positive offset when selecting the rim you get a “Does Not Fit This Vehicle” message? The only offset it says that fits is zero. WTF
    Shit like that makes scavenging for accurate information that more frustrating. If the stock rim on a 2025 Tundra is a +60 how can a +25 not fit? Just shoot me already
  6. Jan 16, 2025 at 4:51 PM
    #546
    SoCal_Erik
    Depends on your source. Method, SCS, and Icon are a few with accurate website information.
  7. Jan 16, 2025 at 5:04 PM
    #547
    Mastortillas
    Larry
    None
    You are correct. The manufacturers site (Method) has more accurate information than the distributor.
    Thank you
  8. Mar 9, 2025 at 10:01 AM
    #548
    get me outta socal
    get me outta socal New Member
    Did you put these on? Looking at the same with 295/70r18.
  9. Mar 9, 2025 at 11:16 AM
    #549
    A wider wheel will need more offset to clear the suspension components and frame when turning. If you’re looking for 10-12” wide rims, factory offset probably ain’t gonna work.
  10. Mar 16, 2025 at 4:20 PM
    #550
    Mastortillas
    Larry
    None
    Rolling the ‘25 Limited TRD OR and planning to install the Fox 2.5 Performance Elite shock package with Camburg UCA in the next month or so. I’m practically going blind reading up on wheel and tire packages and have settled on the Falken AT4W in a 35x11.5x17 (11.9” wide).
    I really like the Method 703 wheels but they come with a +35mm offset and wonder if that may cause some rubbing on the inside. It seems like this setup would really minimize the poke and look clean and be functional.
    Is anyone running this setup or familiar enough with it to comment on how it will fit, look, and function with what I plan to install.
  11. Mar 18, 2025 at 5:24 PM
    #551
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
    My setup is very similar...
    '25 Limited TRD OR with Eibach Stage 2 (leveled).
    305/70-18 Nitto Recon Grappler - measures 34.85 X 12.25 per the Nitto site. I went this way to get the D load range in lieu of E.
    18X9 +30 KMC IMS wheels
    I have removed the bolted in fender liner block at the rear inner of the front fender liner as well as the mud flap and pinned the liner back.
    I get a very slight rub on the inside at the rear of the fronts at full lock in reverse only.
  12. Mar 18, 2025 at 8:02 PM
    #552
    Mastortillas
    Larry
    None
    Hey, thanks for the reply comments and yes they should be very similar. I must say I’m disappointed to hear about the rub and need to remove those items. I was really hoping the offset and lift would eliminate carving crap out but it sounds like any time you go over an 11.5” tire it’s a challenge.
    Much appreciated
  13. Mar 18, 2025 at 9:09 PM
    #553
    SoCal_Erik
    Yes, if you look through some of my recent posts I’m sure you’ll find a picture and some additional details.
    Went with 35’s and have a 2” level life.
  14. Mar 18, 2025 at 9:10 PM
    #554
    SoCal_Erik
    Great name lol
