22+ 3rd Gen Wheel offsets/fitment thread
Discussion in 'Wheels & Tires' started by randomquickness, Dec 23, 2021.
  1. Jul 7, 2022 at 3:54 PM
    #451
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    Nice, I’ll check it out.
    Diezelo likes this.
  2. Jul 8, 2022 at 9:25 AM
    #452
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    Thanks! Did you vinyl wrap the rear bumper as well? And then overlays for the emblems?
  3. Jul 11, 2022 at 2:50 PM
    #453
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Just got my Westcott design lift today. It came with some clips. I guess to pin back the wheel well liner. :monocle:
  4. Jul 11, 2022 at 6:19 PM
    #454
    MMTundra
    MMTundra New Member
    Wow, interesting - I was an early buyer of the kit so cool to see they’ve added these. I couldn’t find anything at Ace that fit quite right so I ended up just trimming the liner just a bit… maybe a 5” diamond shaped section. No more rub!
  5. Nov 20, 2022 at 6:08 PM
    #455
    fatbacktom
    fatbacktom New Member
    Tom
    22 Lunar Rock TrdOR
    How is that Pokémon those Amethid 316s…. Ready to pull the trigger just want them close to flush….
  6. Jan 28, 2023 at 1:20 PM
    #456
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    After a year of running stock TRD OR wheels with Cooper LT275/65R20 tires, decided to go all out.
    First, coopers are awesome, not my first cooper set. However, these tires are heavy; significant hit on mpg, power and ride quality. For me, the latter two were major problems.
    I decided to go for larger tires, but lighter. Specially, went for Wrangler Territory 315/70R17, which are 9lbs lighter than coopers, wrapped around Methods (MR305 17x8.5 +25mm offset). Total wheel tire package is now about 18-20 lbs lighter per wheel, which is a lot.
    wow, ride quality is awesome now, will have to wait to give an opinion on power and mpg..
    In 2 months, my King suspension is coming, so front will get 1.2 inch lift.
    ps: truck has stock height and suspension. The rear axle has about 400lbs load,my old tires and wheels.Hence it does look relatively level.
    C9F6005E-34D6-4E24-A60F-7B565E733B54.jpg DFE88711-5A9F-4628-B51E-E3297EEB08ED.jpg 122CC333-E8A6-41F5-A4C9-D973747C0188.jpg D4AFAAB8-8D03-404D-9B51-4CE8AAAC23AE.jpg
    2ayne and dekeman like this.
  7. Jan 28, 2023 at 3:50 PM
    #457
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    According to their website, they still haven't released anything with a useable offset for the Tundra.
  8. Jan 31, 2023 at 12:32 PM
    #458
    raylo
    raylo not so new member
    Frederick, MD
    I like the look of the 30 or 25mm offsets. To my eye they look right. Lose the tucked in look, but no real poke. That's what I did in my Tacoma, went from +60 stock Sport wheels to +30 TRD Pro wheels. So, does Toyota make any OEM Tundra wheels with that 25 or 30mm offset? I have been through this thread and see some aftermarkets with that. But I'd prefer OEM.
  9. Jan 31, 2023 at 5:42 PM
    #459
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    Method 316's 17x8 +25
    285-70R17 Falken Wildpeaks AT3W
    Ks_SR5 likes this.
  10. Feb 8, 2023 at 3:18 AM
    #460
    RedSam
    RedSam New Member
    2022 Black Tundra SR5
    Sorry Im a little late on this subject. Been reading & getting some Great info on this forum. Im looking for some wheels for my 22 Tundra - I have a friend who has some +12 20" Black Rhino Sentinals Ive been wanting to get. I put them on my truck but they seem to have poked a lot more than your pic. What size tire did you install? Have they been chewing up your paint since youve had them on? Thanks for any info!!
  11. Feb 8, 2023 at 6:14 PM
    #461
    OleMissReb
    OleMissReb New Member
    I’m sure it has been answered 10000 times but I’m new to the forum and not sure how to search it. I’m picking up a 23 platinum in a couple of weeks and looking to do the westcott 3/1 and a 35 inch tire. What is the best width to go with on the factory 20 inch rim? 12.50?
  12. Feb 10, 2023 at 12:36 AM
    #462
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    In short…depending on the brand of tire you may rub on the upper control arms given the 12.5 width of those 35’s you plan to get. It’s a 50/50 proposition and some folks have put a thin spacer to alleviate that condition if they discovered it.
    Your other Options:
    Nitto does make a recon grappler I believe that comes in 35 X 11.5
    You can do a 295 /60 or 65/ 20
    You can do a 285 /60 or 65/ 20
    Play around here and you can see how they compare to the 35X12.5 or your current factory setup
    OleMissReb[QUOTED] likes this.
  13. Feb 10, 2023 at 4:23 AM
    #463
    OleMissReb
    Thanks. Seems like the 295/65 would be the way to go maybe to retain a true 35 inch tire height and get a little skinnier tire. I assume there aren’t commonly any rubbing issues on a 11.6 inch width? Any other reason that would be a less than desirable option? Also, lastly do you know what the stock tire is on the platinum. I’ve don’t some googling and have come up with different answers. I appreciate the help, I am new to Toyota after a long line of GMCs.
    Bushwood77 and wxman91 like this.
  14. Feb 16, 2023 at 8:45 AM
    #464
    DEEBO_TX
    DEEBO_TX New Member
    i was thinking of getting same set up. did you have any rubbing? what size tire did you use? have any pics?
  15. Feb 16, 2023 at 6:09 PM
    #465
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    I have 35x11.5 recon grapplers on stock TRD Sport wheels and they fit great. No rubbing and clear the UCAs by about 3/4 of an inch.
  16. Mar 13, 2023 at 11:14 AM
    #466
    Bushwood77
    Bushwood77 New Member
    Would sincerely appreciate any sort of follow-up on this. About to pull the trigger on the Wescott 3/1 lift for AVS and need to figure out the shoes for the factory Plat wheel. TIA
  17. Mar 13, 2023 at 12:03 PM
    #467
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    To play it safe, you could go with 35/11.5/20, 295/60/20 or 295/65/20 with the Westcott lift. 35/12.5s have a good chance of rubbing the UCAs.
    Edit: every tire manufacturer has varying specs for these sizes. The best route to go is have the shop who you're getting your tires from test fit them. Out of those 3 sizes listed above, the only one that may rub slightly with the factor platinum wheels is 295/65/20 (depending on manufacturer), but I highly doubt it.
    Bushwood77[QUOTED] likes this.
  18. Mar 13, 2023 at 12:05 PM
    #468
    Bushwood77
    Thanks! We are talking about a 1 inch spacer as well, which Wescott recommended (thinking I had the TRD wheels rather than plat). Would you agree that is necessary?
  19. Mar 13, 2023 at 12:08 PM
    #469
    22platitundy
    Only if you're going to go with 35/12.5/20. If I recall correctly, Westcott only recommends a wheel spacer for the 12.5s. I personally don't prefer a wheel spacer for a couple of reasons, so I went with 295/60/20 on stock TRD offroad wheels, which I believe have the same offset as the platinum wheels. I have stock suspension, no lift/level and zero rub. With any lift/level, the 295/65s should be just fine and that is what I would do personally.
  20. Mar 13, 2023 at 12:14 PM
    #470
    Bushwood77
    I am leaning towards the 295/65s on the stock plat wheels with the Wescott 3/1 lift. I believe the offset is 60 on the stock Plat wheel and 55 on the TRD. Plats are 20x8 and TRD are 20x8.5 per Toyota...
    22platitundy[QUOTED] likes this.
  21. Mar 13, 2023 at 12:20 PM
    #471
    22platitundy
    I think that is a sound decision.
  22. Mar 13, 2023 at 12:27 PM
    #472
    Bushwood77
    We are looking at the BFG KO2s. Testing may be our best bet.
  23. Mar 29, 2023 at 5:15 AM
    #473
    OleMissReb
    Don’t know if you are still looking but I wound up going with the 2.5/1 lift from Cornfed Suspensions and a 295/65 Ridge Grappler and it fits great. I definitely would have had to use wheel spacer if I’d gone with a 12.5 inch tire.
  24. Mar 29, 2023 at 6:56 AM
    #474
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    will these higher tires also cause the speedometer to read wrong? Will it effect any other systems.
    Thanks I am new to the forum as well.
  25. Mar 29, 2023 at 9:48 AM
    #475
    wavyota
    wavyota New Member
    Spike
    Lunar Rock Limited
    Toyo Open Country AT3 35x12.5x17
    Rays TE37XT 17x8.5 -10 diamond silver
    Minor rubbing at full lock. Ordered the Westcott bracket to replace the body mount where it rub’s for more clearance.
    More pics on IG: @wavyota
  26. Mar 29, 2023 at 9:49 AM
    #476
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    I went with 33x12.50x20 on 20x9+1 offset.
    I also installed my Readylift 3"/1.25".
    It's barely rubbing when fully turned. I might have to remove the mudflap.
    I think my setup is really cool but I lost a bit of power. I can't make the turbo whistles from 1800-2200rpm like I used to with stock tires.
  27. Mar 29, 2023 at 12:52 PM
    #477
    ArticTundra
    ArticTundra New Member
    Cold
  28. Mar 29, 2023 at 12:54 PM
    #478
    trailhunters
    trailhunters New Member
    So good. Deciding whether I should get center caps for my TE's. So expensive.
  29. Mar 29, 2023 at 4:32 PM
    #479
    trailhunters
    When I look at proper 18" setups, I regret my 17's.
    Durtywrench likes this.
  30. Mar 29, 2023 at 5:16 PM
    #480
    Fxclm5
    Fxclm5 New Member
    very interesting, i want 17s since the rim/tire combo is lighter then 18, curious if anybody else regret running 17's
