21 TRD Pro JBL Upgrade
Discussion in 'Audio & Video' started by bstringrandy, May 8, 2022.
  1. Dec 5, 2022 at 6:00 PM
    #91
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Tech12volt@gmail.com I just checked my email and yes it’s tech. Sorry. I also have his number because he gives you that incase you need to call him for install. But I prefer not to give that because he might not want you to give it out.
    bstringrandy[OP] likes this.
  2. Dec 5, 2022 at 7:09 PM
    #92
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  3. Dec 5, 2022 at 7:17 PM
    #93
    SAGE63
    San Diego County
    Tripleconpanna likes this.
  4. Dec 11, 2022 at 5:05 AM
    #94
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    How can I adjust the settings if I want to add more midbase to door speakers? I just finished the installation and it does wake the factory system up you can actually hear it with the windows open. It's not an active 3 way system or even a headunit upgrade but for 400 bucks it will work for me.
  5. Dec 11, 2022 at 6:43 AM
    #95
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    There was a thumbdrive and a usb cable that came with the unit.
    Install the software and drivers on a windows laptop from the thumb drive, plug the usb cable into the amp and the laptop, SAVE an export of the current settings in case you need to revert back to the “tune” that James loads on it, then fiddle around as you want.
    there’s a few youtube videos about how the software works and what the settings are
  6. Dec 11, 2022 at 7:27 AM
    #96
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    Playing with the settings might seem a little overwhelming at first, but you'll figure it out. I added bass back into the door speakers. The original tune had crossover frequency set too high for me. The software allows you to mute the different channels. I found this useful when making adjustments so I could hear what was coming out of each speaker and then turn the others back on to listen to them together.
  7. Dec 18, 2022 at 10:16 AM
    #97
    DME109
    DME109 New Member
    David
    So I just did my install on my system (amp and sub) from James. So supplied from James the JBL amp front switch settings are “LO” and “REM”. The system keeps shutting down. If I move the switches to “lo” and “DC” the power light on the amp comes on and I get sound through the speakers. Can someone that has done the install on a stock JBL system tell me what their switches are set to?
    Thanks
    bstringrandy[OP] and ATV25 like this.
  8. Dec 18, 2022 at 10:20 AM
    #98
    RainMan_PNW
    Casey
    Clark County, WA
    From an email I had received from James when I got mine:
  9. Dec 18, 2022 at 10:31 AM
    #99
    DME109
    DME109 New Member
    David
    Thanks RainMan_PNW, changed the settings and now I’m getting sound.
  10. Mar 8, 2023 at 11:59 AM
    #100
    Team_Green_Bird
    Team_Green_Bird New Member
    Bird
    i’m trying to find pics on here of the subwoofer box installed in a crew cab and can’t seem to find anyone posting one. This is the box/subwoofer that comes from tech12volts.com. Does it go behind the seat where the existing one is? Have I missed someone’s write up on it?
  11. Mar 8, 2023 at 12:05 PM
    #101
    Tripleconpanna
    He's got a couple of different boxes. If you are talking about the single sub (in lieu of the dual sub box), yes it sits in exact same location as the factory box behind the driver's side rear seat. Dimensions are slightly larger, so the fit is very tight; but this is to help keep the box from moving and vibrating as the output, especially w/the upgraded JBL DSP/AMP that he sells, is significant.
    Sorry I have no pics for you, but I was fighting weather (heavy rain) during the install. So, I just got it done when I could and didn't slow down for pics, etc....
    Just for reference this is the one that I used, it's a "loaded" box (comes w/sub); most of them on his site are just empty box and you add your own sub...
    Navigating his website is a little tricky, but if you go to 'Tundra Audio Packages'; then '07-21 Tundra JBL Sub Replacement Loaded w/JBL Sub', it should take you here...
    https://www.shop.tech12volts.com/product.sc?productId=540&categoryId=124
    bstringrandy[OP] and bulldog93 like this.
  12. Mar 8, 2023 at 12:05 PM
    #102
    RusPro21
    Don
    Pa.
    Yes Bird, I have the tech12volts and it’s goes behind the seat to replace your JBL one if you are doing a full system upgrade like I did. Tough to take a pic with the seat in the way. I did not have my install take a pic when he put it in.
  13. Mar 8, 2023 at 12:33 PM
    #103
    SAGE63
    San Diego County
    When i received mine I had to mount the sub supplied by tech12volts into the box. yes very tight fit. I did not think to take pictures ir at least if I did dod not save them. same box as tripleconpanna posted
  14. Apr 5, 2023 at 6:52 AM
    #104
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    Wow what a difference I should have pulled the trigger sooner. To the ones that added Tech12volts sub have you found your over all volume lower? Wondering if its worth getting the Amp from them as well.
  15. Apr 5, 2023 at 6:55 AM
    #105
    SAGE63
    San Diego County
    definitely love the AMP
  16. Apr 5, 2023 at 7:05 AM
    #106
    RusPro21
    Don
    Pa.
    I got everything from James. All arc audio. Love it. Planning down the road adding new headunit. It’s fine for now.
    AgileTundra[QUOTED] likes this.
  17. Apr 5, 2023 at 11:37 AM
    #107
    Tripleconpanna
    Not sure I understand the question, but I'll give it a go....
    If you're saying that your sound throughout the range of frequencies and through all speakers is lower now that you installed a replacement sub, I can't give you feedback w/my personal experience as I replaced both at the same time.
    However, the OE head unit does not do a great job processing signals and the system in general is underpowered, so it's feasible that the factory amp and signals coming from the head unit are fighting each other to perform.
    Yes, the JBL DSP/AMP combo is a night and day difference not only in power to your sub and other speakers but in signal processing as well. You won't be disappointed :thumbsup:
  18. Apr 5, 2023 at 1:11 PM
    #108
    AgileTundra
    No, sound seems lower since I have sub that actually works now.
  19. May 1, 2023 at 11:41 AM
    #109
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Is everyone still liking their Amp from Randy?
    Anyone have any issues?
  20. May 1, 2023 at 11:52 AM
    #110
    RusPro21
    Don
    Pa.
    I’m still loving my system from Randy. Would like to change the headunit out. Still have not pulled the trigger.
    Bergy24[QUOTED] likes this.
  21. May 3, 2023 at 3:20 PM
    #111
    bstringrandy
    bstringrandy [OP] New Member
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    Still loving mine! Single sub enclosure, JBL DSP amp, JL speakers! Just what I wanted! :rockband:
    Bergy24 and Tripleconpanna like this.
  22. May 3, 2023 at 4:39 PM
    #112
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Loving mine. I got sub, amp, and hertz speakers. Absolutely love it.I’ll upgrade head unit some day but in no hurry.
  23. May 3, 2023 at 5:02 PM
    #113
    Bergy24
    Bergy24 New Member
    Has anyone has any issues at all? I still haven’t bought the amp yet. I’ve got less than 8k miles on my 21 and while I’m sure the amp makes a huge improvement, I don’t hate the way it sounds with just the upgraded sub.
  24. May 3, 2023 at 5:10 PM
    #114
    RainMan_PNW
    Casey
    Clark County, WA
    No issues. Just thinking of getting the amp sub now…
    Edited because I’m an idiot…​
  25. May 3, 2023 at 6:36 PM
    #115
    Bergy24
    Bergy24 New Member
    I’m still debating it. I’ll probably pull the trigger here soon.
  26. May 3, 2023 at 6:38 PM
    #116
    Bergy24
    Bergy24 New Member
    Any chance one of you guys live in Pa?
  27. May 3, 2023 at 6:52 PM
    #117
    Tripleconpanna
    Do it...
  28. May 3, 2023 at 7:47 PM
    #118
    RusPro21
    Don
    Pa.
    Hey Bergy24 what do you need to know? I’m in Pa. Not sure where you are located. Are you looking to upgrade your whole system?
  29. May 3, 2023 at 8:20 PM
    #119
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    I was getting a popping, crackling sound.narrowed it down to lead off of amp.let James know and he sent me a replacement amp.
    bulldog93 and Tripleconpanna like this.
  30. May 4, 2023 at 3:46 AM
    #120
    Bergy24
    Bergy24 New Member
    Just wanted to see if anyone Pa. Has the amp and sub installed so I could listen to it to compare. I’m located in the York area.
