2023 Tundra with Retrax XR Pro
Discussion in '3rd Gen Tundras (2022+)' started by benne017, Jan 28, 2023.
  1. Aug 14, 2023 at 10:44 AM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    How was the experience buying from tonneaucovered? They are the least inexpensive for that model now. Quote from the RT forum vendor was higher and includes collecting state tax.
    Unitdosed likes this.
  2. Aug 14, 2023 at 11:30 AM
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Would you mind sharing why you're getting rid of it?
  3. Aug 14, 2023 at 1:52 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I’ve always had soft tonneau covers, I guess that’s what I'm used too..Noting wrong with my Retrax, it’s less than a year old. I’m leaning towards going back to a soft cover.
  4. Aug 14, 2023 at 3:22 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I put the XR PRo on this past week. Took me less than 1 hour by myself. I also installed the same model on my 2020, so I was a little ahead of the curve. Great cover for me though.
    Randy
    Unitdosed and Sixty9Four20 like this.
  5. Aug 26, 2023 at 2:47 PM
    Sixty9Four20
    2023 TuRD Pro
    I did the install on the XR Pro, bought it from tonneaucovered for $200 less than the least expensive I could find. Shipped from ND (I assume straight from the Retrax factory) to my door. I did have a little trouble with the screws on the sides of the canisters, didn't seem to want to get in all the way, and had a hell of a time adjusting using the allen key on the nylon adjusters in the rear...I'm off by maybe 1/4" so it's not super smooth in the rear. I also stripped them and will need to call up retrax.
  6. Aug 26, 2023 at 3:15 PM
    tech1208
    Orlando, FL
    Sorry to hear this. The Allen key in the Nylon is purely to hold in place while you clamp down with the metal fasteners in the rails. They are not to be torqued up. The measurements across the width are the most important when tightening up the rail clamps.
    Randy
  7. Aug 26, 2023 at 3:37 PM
    Sixty9Four20
    2023 TuRD Pro
    No worries, I still love the look and function of the cover and know I just need to adjust it further. I agree with your statement of them not to be torqued but that's not what I meant. The nylon pieces on both sides of the metal fasteners are to be used for widening/narrowing the rails. My nylon (adjustment) pieces were only half way through the rail (not touching the truck at all) and they were super hard to turn already; let alone getting to a point where they would push the rail to narrow it close to the 58 5/8" measurement of the front and second measuring spots. Just a heads-up for anyone having trouble like myself. I still saved $700 from having an authorized dealer install it (they couldn't budge on price due to the supplier...).
    Step #7 page 5:
    https://static.thiecommerce.com/ass...n-guide2/3ce5a01f15fdc72f960e7dd3cdd4a96f.pdf
  8. Sep 5, 2023 at 11:17 AM
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    Do you have any pictures with the UpTop and its fit by the bed and RVM cameras? Do the rack interfere with the video RVM at all or is it tall enough to clear?
  9. Sep 9, 2023 at 3:37 PM
    BJBlixt
    BJBlixt New Member
    Phoenix, AZ
    2022 Tundra SR5 TRD OR 4x4 - Lunar Rock
    Sorry, I just saw this. I don't get on here as often as I should. Purchasing from them was a breeze and shipping was great. They were the least expensive I could find, when I bought. You'll probably have to do some shipping around to find the best deal.
    Sixty9Four20[QUOTED] likes this.
  10. Nov 5, 2023 at 9:02 AM
    christundra845
    christundra845 New Member
    San Diego
    2023 Tundra Limited TRD Offroad
    None
    Has anyone with the XR Pro been able to use the factory adjustable tie downs on the bedrail system or does the cover take up too much space?
  11. Nov 6, 2023 at 10:28 AM
    manapiko
    manapiko New Member
    Patrick
    Soon to own 2023 TRD Pro
    Yes, I kept the tie downs. You do have to install them before the XR, so you are for sure limited in where they can be placed.
  12. Nov 6, 2023 at 11:27 AM
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    I was able to remove them and place them in a different spot after I installed my Retrax… just had to loosen the screw a bit more.
    manapiko[QUOTED] likes this.
  13. Feb 26, 2024 at 9:54 AM
    LunarRockTundra17
    LunarRockTundra17 New Member
    James
    2024 Toyota Tundra SR5 Premium
    Nothing right now… to be continued
    glad to see a fellow Wisconsin tundra owner
