2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. Feb 23, 2022 at 1:34 PM
    #841
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Swapping inverter would be easy, but all wiring would have to upsized too though. Not going to be economical. Plus you would probably want to upgrade the alternator too.
    Mattedfred[QUOTED] likes this.
  2. Feb 23, 2022 at 1:44 PM
    #842
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Impossible with stock hybrid setup. Has to be factory.
    OnThaLake likes this.
  3. Feb 23, 2022 at 2:20 PM
    #843
    Acedude
    Acedude New Member
    Colorado Plateau
    I don't know what alternator is in the '22. Toyota likes 130A alternators max in their trucks (150A Sequoia), so max IMO is a 600W aftermarket inverter as the sweet spot. Go beyond that and you'll need a higher output alternator, the Big Three upgrade.
    High wattage should be done at the factory as an optional package. The wiring has to be stouter to handle the amperage, stouter fuses. We'll see if Toyota steps up to the plate.
    JLS in WA and Mattedfred[QUOTED] like this.
  4. Feb 23, 2022 at 2:31 PM
    #844
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    My previous post referred to the non-hybrid and the reason Toyota chose 400watt. There is a reason
    My experience deals with boats like many here.
    In which case you have multiple batteries on board. One to start your boat - the regular 12 volt starting battery - that you can't have run down.
    When you run down your car battery a couple times, lets say someone leaves an interior dome light on.
    its game over on its lifespan. Ask me how I know.
    So you add in a boat ....one or more deep cycle batteries. One/s that can be drained and recharged many times.
    for your needs.
    But that is on a boat. This is on a vehicle that has become more complicated than anything I have ever seen.
    Only a factory solution else you are voiding warranties.
    Its throwing codes now - Imagine someone adding a DIY inverter solution.
  5. Feb 23, 2022 at 2:39 PM
    #845
    Bannerman
    Johnson
    Volume. R&D budget can be bigger and profit margin smaller when you sell 10 times as many trucks
  6. Feb 23, 2022 at 2:43 PM
    #846
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    You gonna run a cord to the boat while you’re driving?
  7. Feb 23, 2022 at 2:45 PM
    #847
    Breathing Borla
    AZ
    why not, there is already trailer wires going to the bumper
  8. Feb 23, 2022 at 2:49 PM
    #848
    Bannerman
    Johnson
    Yeah. Just will secure it. Just like the 7 pin.
    BTBAKER[QUOTED] likes this.
  9. Feb 23, 2022 at 2:50 PM
    #849
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yea. I don’t think it’s a big deal. I’d probably do it myself. If I buy the Tundra maybe I’ll throw my phone in my boat so I can charge it.
  10. Feb 23, 2022 at 9:10 PM
    #850
    Acedude
    Acedude New Member
    Colorado Plateau
    I guess a lot of high voltage cabling and sophisticated control module. And liquid coolant lines for the hybrid battery. https://youtu.be/S1t0Au_z9zA
  11. Feb 25, 2022 at 8:36 AM
    #851
    borla123
    borla123 The Pits
    Ontario
  12. Feb 25, 2022 at 8:41 AM
    #852
    nuclear
    nuclear New Member
  13. Feb 25, 2022 at 8:48 AM
    #853
    Bannerman
    Johnson
  14. Feb 26, 2022 at 8:27 AM
    #854
    Breathing Borla
    AZ
    I’m going to test drive a powerboost f-150 today at 1pm
    I’ll throw a few comments after that .
    I’m wondering why ford can have trucks on the lot and Toyota can’t . I really wanted to test drive a tundra too but you can’t find one anywhere here and I’m in a huge market
    they are under msrp as well
    Bannerman and BTBAKER like this.
  15. Feb 26, 2022 at 8:32 AM
    #855
    borla123
    borla123 The Pits
    Ontario
    unfortunate you cant drive a Tundra.
    interested in your comments. especially on turning circle dynamics.
    your 2.5 gen Tundra handles supposedly from comments sporty in comparison.
    I hear Ford also pipes in engine noise ?
    How does it compare to the Borla ? 8^0
  16. Feb 26, 2022 at 8:38 AM
    #856
    Breathing Borla
    AZ
    Ya blows you can’t even look at a tundra , kinda lame
    each dealer should have one for test drives then order or allocate from there , but no dice
    Canebrake likes this.
  17. Feb 26, 2022 at 8:53 AM
    #857
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Please let us know what you think. A year ago the F150 was nowhere on my radar. With the Tundra rollout I have been looking.
  18. Feb 26, 2022 at 8:54 AM
    #858
    Breathing Borla
    AZ
    exactly me too, I had the AT4 refresh and the tundra only on my radar but the rollout and numerous qc issues has given me pause
    the more I’ve looked into the ford the more I’ve liked it, especially with that black appearance package coming out
    TundraLaw likes this.
  19. Feb 26, 2022 at 9:00 AM
    #859
    Breathing Borla
    AZ
    Toyota is really starting to piss me off. They just called and said I have to drive in and talk to a specialist just to be put on a waitlist to test drive , lol
    I said I understand but can’t you just take my name over the phone? I have to drive over there to be put on a test drive list? I said no thanks , you take care
  20. Feb 26, 2022 at 9:13 AM
    #860
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
  21. Feb 26, 2022 at 9:16 AM
    #861
    Breathing Borla
    AZ
    Gee that’s helpful
  22. Feb 26, 2022 at 9:34 AM
    #862
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    If you get the Ford you'll get present day technology, and not piano black inserts (hot in 2014), rear set hump with nearly no usable rear floor space due to that dumb partition, no tow hooks, not as perfected twin turbo set up compared to ecoboost, large grilles that aren't in style anymore, and the list goes on.
    new tundra imo is just an overgrown tacoma with no originality, or positive notes.
    Bannerman likes this.
  23. Feb 26, 2022 at 9:40 AM
    #863
    maddog 72
    maddog 72 New Member
    2018 Db Cab TRD - Cement
    Sounds like the dealer is pissing you off, not Toyota.
    Cpl_Punishment and damnfingers like this.
  24. Feb 26, 2022 at 9:51 AM
    #864
    maddog 72
    Not trying to be snarky, but why did you buy one or have one one the way if you dislike that much of it?
    OnThaLake and Cpl_Punishment like this.
  25. Feb 26, 2022 at 9:55 AM
    #865
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    I drove one of my employees new PowerBoost Lariat FX4 yesterday. My personal truck is a 2018 Platinum Tundra w/ Pro shocks, and work truck is a 2021 Ram Etorque for reference. Couple thoughts….
    - Motor is VERY powerful, and effortlessly gets you moving much faster than you think you are going. The 10 speed shifts extremely smooth, and works seamlessly with the motor. Very impressive. He had roughly 700 miles on it, and the dash was reading 17.9mpg. He drives it solely in Sport Mode.
    Makes the power train of the Ram feel a tad bit dated, and a very noticeable gap in torque. Compared to the Tundra, it feels from the Stone Age, and an even bigger gap in torque and felt power.
    - Ride quality was somewhat disappointing. Felt very springy / pogo stick’ish at slow speeds on any kind of uneven terrain. Not exactly confident feeling. A bit better at highway speed (but all rigs are). Turning radius felt very tight.
    The ride is MUCH better in the Ram in all conditions. Continually impressed with how well the RAM drives. I prefer the ride of my Tundra with Pro suspension much more as well.
    - Interior is massive feeling and the new interior is light years better than the previous generation. Buttons EVERYWHERE. The fully digital instrument cluster is very nice, and the large center screen is well laid out. Finishes are good looking, and felt solid. Panoramic sunroof was very nice with how much bigger it makes the interior feel. However it’s exposed tracks look a bit unfinished. Fold flat rear floor and locking cargo is very handy. Interior was extremely quiet while driving as well. Still has an old school antenna on the hood, which looks silly to me.
    My Ram is just a BigHorn, so can’t really compare it to a Lariat. F150 interior does feel larger. Lol, won’t even try to compare my second Gen Tundra interior.
    All in all I was impressed with the truck, and especially with how much better it feels than the previous Gen. Still don’t think I’d get one over a new Ram however. Which basically feels like if you took a 2nd Gen Tundra, gave it a super nice 8zf transmission, coil rear, updated interior, and slightly more powerful motor.
    OnThaLake and Lovetrucks like this.
  26. Feb 26, 2022 at 10:03 AM
    #866
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Demand and interest in relation to supply is higher for Tundras than F150s. :notsure:
    The dealer making you physically show up to book a test drive supports this. I would’ve responded in the same way as you, but this just goes to show that the apparent issues aren’t slowing down demand much if at all.
  27. Feb 26, 2022 at 10:05 AM
    #867
    Breathing Borla
    AZ
    one in the same imo , but I get it
    I called another one and they have a crewmax that’s only for test drives but they won’t let me take it today since I want to see if it fits in the garage. They also said we can’t order one either .
    so I guess I have to see if I can take it home during the week the guy said
  28. Feb 26, 2022 at 10:07 AM
    #868
    Breathing Borla
    AZ
    I’m at ford right now and taking it home for garage test fit
  29. Feb 26, 2022 at 10:09 AM
    #869
    maddog 72
    Even better! Being able take it home and get a little more seat time would be nice.
  30. Feb 26, 2022 at 10:35 AM
    #870
    Breathing Borla
    AZ
    Most important box checked , it fits , lol
    tight like my tundra but fine
    Nice tow hooks lol
    Sitting in my heated garge going to play around with all the settings then take it out on the road and inter state for a bit
    Super first impression, holy torque Batman
    Canebrake, Acedude, akmerle and 3 others like this.
