2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. Jul 29, 2024 at 6:45 AM
    #7111
    MrFord
    MrFord New Member
    Any particular reason you did not go with V8 5.0 and 3.7 rear axle since you are towing the trailer?
    I am surprised you are feeling Tundra trainy drives better.
    I tested my friends 2024 XLT 3.5EB and it was way smoother than my 2022 Tundra. Specially in low gears.
    My 2022 tends to downshift all the time and makes noises in low speeds every time I want to give a little gas..
  2. Jul 29, 2024 at 7:03 AM
    #7112
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    I'd take the 3.5/3.31 or 3.55 combo for towing over the 5.0/3.73. @nmmike did you look at the Tremor at all? 3.5 and 3.73 combo is amazing for towing and if you like the BAP, it's based on the looks of the Tremor.
    DFS likes this.
  3. Jul 29, 2024 at 7:23 AM
    #7113
    nmmike
    nmmike New Member
    2022 Tundra CrewMax SR5 TRD
    First of all, I was in a hurry to trade my 2022 Tundra before its value crashed further. So, I checked the local dealers inventory to make my deal ASAP.
    My TT weighs only 5500 lbs wet so I wanted to stay with a half ton because I also drive my truck around town quite a bit. My 2024 F150 has towing capacity of 10,400 lbs and Payload of 1800 lbs. Plenty of tow capacity for me and 600 lbs more payload than my Tundra, and I need the extra PL. The F150s I saw with the 5.0 were 2023s and the 2024 has a lot of nice upgrades over the 2023. I like the BAP a lot and think that the truck looks very good with that package. I shopped at 3 dealers and went with the dealer that gave me $44k for the Tundra and $10k off the F150s $66k sticker. The other dealers were $6k more, which is amazing. If I had time, I would have shopped around the SW and not limited my search to Albuquerque. If I get a larger TT, I would seriously consider a 3/4 ton but I don’t see that happening.
    Bannerman likes this.
  4. Jul 29, 2024 at 8:11 AM
    #7114
    mass-hole
    mass-hole New Member
    Because the 3.5L Ecoboost tows like a locomotive compared to the 5.0. Hell I went from a 2014 Ecoboost that only made a measly 420 ft-lbs to this 5.7L/8 speed LX570 and the LX feels like a turd in comparison with the trailer behind it. The new 3.5's are making 500 ft-lbs.
  5. Jul 29, 2024 at 8:13 AM
    #7115
    Breathing Borla
    Northern Illinois
    this ^
    ya, you really cant compare these new boosted motors to the V8 NA anymore when it comes to low RPM high torque
  6. Jul 29, 2024 at 8:18 AM
    #7116
    nmmike
    nmmike New Member
    I agree that the 3.5 EB tows good, U just have to be sure to lock out the overdrives 9,10 and sometimes 8 when going uphill. And be sure to watch the engine and tranny temps. Plus the 3.5 EB is fun to drive around town in Sport mode. The 5.0 is a good old tech engine, and its main advantage now is that it does not require as much maintenance.
  7. Jul 29, 2024 at 8:20 AM
    #7117
    nmmike
    nmmike New Member
    I have read that the F150 10 speed goes through a “learning” period and it does seem to be shifting better. It sounds like Ur Tundra tranny is not as good as the one I had. I would consider the F150s Max Tow rear diff once they get the recall for “sheared bolts” fixed.
  8. Jul 29, 2024 at 8:24 AM
    #7118
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Wouldn't you also have to lock out the overdrive gears when towing with the V8?
  9. Jul 29, 2024 at 9:07 AM
    #7119
    Bannerman
    Johnson
    I just use Tow/Haul and let it do it's thing. I regularly tow 7000 pounds while also at max payload, 200 miles at a time to the beach. It was 100 degrees on the way back in June and trans and engine temps stayed dead center on the gauges. Someone here said Ford massively upsized the intercooler in the EB. With the autostart/stop and cylinder deactivation on the current 5.0, it's getting harder to use that "ol' reliable" argument. But, what added maintenance does the 3.5 require over the 5.0?
  10. Jul 29, 2024 at 9:09 AM
    #7120
    Bannerman
    Johnson
  11. Jul 29, 2024 at 9:22 AM
    #7121
    MrFord
    MrFord New Member
    Cpl_Punishment likes this.
  12. Jul 29, 2024 at 9:27 AM
    #7122
    Bannerman
    Johnson
    For sure. He could be just some cranky old man too. But the long row of Tundras in the background made for a funny image.
    MrFord[QUOTED] likes this.
  13. Jul 29, 2024 at 10:37 AM
    #7123
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    The only thing I can think of is the turbo(s). When I was in the medium duty truck field, the narrative changed to the turbo being a wear item with a maintenance interval, which meant replacement, unless it failed due to another failure.
  14. Jul 29, 2024 at 1:28 PM
    #7124
    mass-hole
    The Ecoboost turbos really dont seem to be a failure point. And even if they did fail, they are cheap. I was actually just talking about this the other day and Tasca Ford has the 2023 3.5L turbos for $370 a piece with core.
    The Tundra on the other hand, those turbos are $3000 a piece. Its a much bigger deal to have a turbo fail in a Tundra out of warranty.
  15. Jul 29, 2024 at 1:37 PM
    #7125
    SnrDisregardo
    Wade
    IL
    Wow. That is way less than I would have thought. Good if you're a DIY'r but the labor is another story. At least that cost will offset it a bit.
  16. Jul 29, 2024 at 5:07 PM
    #7126
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    It took a long time but through the generations the Ecoboost has gotten pretty buttoned up. Still transmission and electronics questions but the motor has gone through lots of field testing and revision on 13-14 years. I read there used to be oil leak issues with bad fittings that were revised over the generations. Other than that the turbos themselves generally don't just crap the bed.
    Polo08816 and MrFord like this.
  17. Jul 30, 2024 at 6:00 AM
    #7127
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Spark plugs is the only thing that comes to mind, meticulous oil changes to conserve the turbos. Maybe an oil catch can, coz turbos.
    Bannerman[QUOTED] likes this.
  18. Jul 30, 2024 at 6:09 AM
    #7128
    Bannerman
    Johnson
    Interval is 60-100k, inspection at 30k for all engines I think. I'll change mine at 30k, and I do oil at 5k with tire rotation. That stuff is cheap and easy, I never understand why people try to push their oil change intervals. I'm not as sold on the need for a catch can now that they are duel injected, that stuff burns off I think.
  19. Jul 30, 2024 at 6:33 AM
    #7129
    nmmike
    nmmike New Member
    Not really maintenance but, when towing I lock out overdrives 9 and 10 and watch the engine and tranny temps when going up hill in NM and CO. Temps will go up when going up hill and then drop down when U top out or go down hill. I drive light footed around town and generally the turbos don't get used much then. Debating whether to use full synthetic or blend when I change oil. I might use the blend for a while, then switch to full syn.
    2024 F150 XLT 3.5 EB
    2024 4Runner ORP
  20. Jul 30, 2024 at 6:35 AM
    #7130
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    No need for it. Ford in 2017, did change it to dual fuel injected to get rid of the carbon build up possibility. Still many 3.5L ecoboost with over 200 and 300 thousand miles on the direct injection only original motors without excessive carbon build up when properly maintained.
  21. Jul 30, 2024 at 6:40 AM
    #7131
    Jaxyaks
    Jaxyaks New Member
    Which models in their lineup would you consider lemons? Not being sarcastic, I am interested because I will be doing some vigorous car (not truck) shopping very soon to replace one in the household. Hopefully you don't say Corolla Hybrid because I just bought the kid one them a couple of weeks ago....lol
  22. Jul 30, 2024 at 6:41 AM
    #7132
    Bannerman
    Johnson
    That's what I did. Used the Motorcraft Blend for the 1,000 and 5,000 mile changes then swapped to full synth.
    DFS likes this.
  23. Jul 30, 2024 at 8:20 AM
    #7133
    Black widow TRD
    Manuel
    I like to change the spark plugs preemptively. You can stretch it out to 60 or 100k. But for best engine efficiency and performance I do 30k. Oil I may change at 3k, 5k is cool. But same I like to be kind to my Turbos. Also Fords VVT system relies on clean oil.
    Overall you got it down.
  24. Jul 30, 2024 at 8:26 AM
    #7134
    Bannerman
    Johnson
    I have a client who makes fun of me for doing all my own maintenance on my boats and vehicles. But it takes less time to DIY and I know it's done right.
  25. Jul 30, 2024 at 12:37 PM
    #7135
    js312
    js312 New Member
    2023 F-150 Lariat PowerBoost
    Normal summer driving I do 7k on Pennzoil Ultra Platinum. My commute is pretty ideal 25 miles each way of slow highway, so it should be pretty kind to oil. In the winter or if I'm towing more than usual, I do 5k.
    I have a friend that does 3k full synthetic with mostly highway driving on a 2016 Coyote V8, which seems excessive. But I think the 10k intervals Ford suggests are pushing it on a twin turbo engine. I figure the 5-7k is a decent balance between the two.
    I do engine and cabin air filters every 20k. I'm at 14k so haven't done them yet on this one, but I'm pleased that the cabin one is easier. In the 15-20s you have to pull trim off above the glove box and remove a bunch of screws for another compartment. In the 21+, you just swing the glove box door down and it's totally accessible.
    I did spark plugs at 60k on my 2020 3.5, and the gap on the old ones were still within spec. Differential oils also looked good. Transfer case fluid looked awful - dark black and very thin. I had the dealer do the transmission fluid change because that looked like a bear.
  26. Jul 30, 2024 at 12:38 PM
    #7136
    mass-hole
    Oil leaks have not been an issue. The JittyTite fittings they used for the turbo coolant lines could leak.
    eharri3[QUOTED] likes this.
  27. Jul 30, 2024 at 12:40 PM
    #7137
    mass-hole
    If you did a catch can I would only do the passenger side PCV. The intercooler works as a pretty excellent catch can for the drivers side PCV
  28. Aug 3, 2024 at 9:26 AM
    #7138
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    August already !! 10 months of ownership now ... nothing but smiles. Thanks TOYOTA :) hands down the best new 1/2 ton on the market.
  29. Aug 3, 2024 at 4:45 PM
    #7139
    Gman6112
    Gman6112 New Member
    Gerald
    Glad you’re enjoying your Trd pro but let’s not get carried away. Lol
    Black widow TRD likes this.
  30. Aug 3, 2024 at 5:20 PM
    #7140
    nmmike
    nmmike New Member
    I wish I had a 24 instead of a 22. 22 Tundra that will have to wait 12-18 ? Months for a new engine. No towing the TT across the country because it could stop running at any time :)
