2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. Mar 20, 2024 at 5:43 AM
    #5851
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I think my XLT 4x4 Powerboost is 5600 and change and it is a Long bed hybrid with a moonroof so I would Guess a standard bed Ecoboost might be in the low 5's with stock tires and nothing aftermarket
    Bannerman likes this.
  2. Mar 20, 2024 at 5:50 AM
    #5852
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    What's the summary? Which components? Because the net result is a smaller, heavier truck with less capacity.
  3. Mar 20, 2024 at 5:52 AM
    #5853
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    You guys are "arguing" over a thanksgiving dinner.
    Mattedfred likes this.
  4. Mar 20, 2024 at 6:01 AM
    #5854
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I actually wasn't trying to make fun of you. I love seeing guys work their trucks.
    I don't think there was any part on my grandpa's farm truck that wasn't bent, scratched, dented or torn off.
  5. Mar 20, 2024 at 6:18 AM
    #5855
    Eurodriver
    Eurodriver New Member
    I know you weren't. I just quoted you so you'd see it :)
  6. Mar 20, 2024 at 6:57 AM
    #5856
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Interesting.
    What do you suppose the resale value is of Pappy's farm truck?
    Express the value in pesos, plz.
  7. Mar 20, 2024 at 7:30 AM
    #5857
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Looks like a great motor until 2021. When did that UAW strike happen? I'd wait a few years until those disgruntled GM and Ford workers are gruntled again. You don't get quality from workers that hate the company.
    Cpl_Punishment likes this.
  8. Mar 20, 2024 at 7:33 AM
    #5858
    cmiles97
    cmiles97 New Member
    XP package
    As much as I wouldn't trust Stellantis reliability, that Ram TRX Supercharged V8 would be fun.
  9. Mar 20, 2024 at 7:35 AM
    #5859
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    I think it came down to bad valves. Just like bad wastegates, or bad bearings
  10. Mar 20, 2024 at 7:41 AM
    #5860
    js312
    js312 New Member
    2023 F-150 Lariat PowerBoost
    I can concur that it's pretty easy to avoid using boost with the Ford 3.5. Eco mode helps a lot. However, sometimes it's counter productive. I found that trying to keep it out of boost and lugging it up hills is less efficient than just letting the turbos spool.
    I don't think I could have done that with the 2.7, turbos spool on it too fast.
    My 2020 Lariat was ~5300 lbs. It was a SuperCab, which shaves a bit of weight. It also didn't have the FX4 (skid plates) or large moonroof. Crew cab with those and you probably are right around the 5500 mark.
    My 2023 PowerBoost Lariat is porky at about 5800 lbs. Even still, it doesn't have the moonroof, FX4, or power tailgate which helps. Add those and some other stuff and I could see being around 6000 lbs for a very well optioned hybrid.
    From what I've seen, Tundras are definitely a couple hundred pounds heavier across the board than F-150s.
  11. Mar 20, 2024 at 8:27 AM
    #5861
    Eurodriver
    Will do. I am in a similar boat RE: F150. I bet my dented farm truck Tundra would be worth more than a dented farm truck F150 @hagrid
    pwpblue and Cpl_Punishment like this.
  12. Mar 20, 2024 at 8:31 AM
    #5862
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    ... due to higher quality parts. Thank-You Toyota !
  13. Mar 20, 2024 at 8:52 AM
    #5863
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    3. Take it or leave it.
  14. Mar 20, 2024 at 9:11 AM
    #5864
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    I realize that my truck is from another era, but the fact I need to accept 2024 standards for such a critical part is not confidence inspiring.
    Was watching a detailed video on the comprehensive '24 "TRD Lift" option package.
    As the guy was unboxing the parts - many China labels. 8^(
  15. Mar 20, 2024 at 9:12 AM
    #5865
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    DOHC 32 valves to be exact. It’s a beast.
  16. Mar 20, 2024 at 9:38 AM
    #5866
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @Eurodriver
    My esteemed colleague hath delivered an accurate appraisal of your SR "hog-hauler" replete with bent up door.
  17. Mar 20, 2024 at 12:25 PM
    #5867
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Sometimes I like to stir the pot. 2024 raptor w/ 65 miles
  18. Mar 20, 2024 at 12:53 PM
    #5868
    Breathing Borla
    AZ
    O no, is that yours Dr z?
  19. Mar 20, 2024 at 1:06 PM
    #5869
    kilocharlie106
    TRD Pro in LR
  20. Mar 20, 2024 at 1:26 PM
    #5870
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Not mine. Mine is still just a swimmer in the ford plant nutsack
  21. Mar 20, 2024 at 2:00 PM
    #5871
    Eurodriver
    It’s actually bent out, not up.
  22. Mar 20, 2024 at 2:09 PM
    #5872
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    It doesn't matter if it is bent out or up, so long as it works, right? At least that's what I tell her.
  23. Mar 20, 2024 at 2:42 PM
    #5873
    mass-hole
    mass-hole New Member
    IDK. I've seen 2015+ Lariats with ~1560 lbs of payload on a truck with a 7050 lbs GVWR. And I know that my trucks payload sticker was within 20 lbs of the cat scale when I weighed it completely empty. I also know that my 17" wheels with 315/70R17's KO2's were the same weight as my OEM 20" wheels/tires at around 92 lbs a piece. My truck was actually lighter than stock when I went to the 315/70R17 Goodyear Territory MT's. The OEM 20's are heinously heavy.
    5500 lbs is the upper limit for a non-Powerboost though. Thats a fully pimped out truck on 20" wheels with a moon roof and tailgate step, spray in bed liner etc.
  24. Mar 21, 2024 at 4:56 AM
    #5874
    borla123
    borla123 The Pits
    Ontario
    I am willing to bet one Canadian Loonie, that this vehicle was parked for quite a while, and the electronic drain brought the battery to a level that affected the proper operation of the electronic sensors in the brakes, the gear shift and I am sure a few more places too. Attached pic is a sample only for illustration.
    Cpl_Punishment and cmiles97 like this.
  25. Mar 21, 2024 at 8:30 AM
    #5875
    Breathing Borla
    AZ
    they had to park it for a while to make sure it comes with one of those rusty under parts ford gives on new trucks
  26. Mar 21, 2024 at 10:58 AM
    #5876
    SnrDisregardo
    Wade
    IL
    I want to know what the PP test is.
    borla123[QUOTED] likes this.
  27. Mar 21, 2024 at 11:39 AM
    #5877
    borla123
    borla123 The Pits
    Ontario
    Well I have heard "on the internet" that a lot of guys are buying these trucks these days to make up for problems in that dept.
    this is what FB sends me after I clicked on your pictures.
    doublethebass and Cpl_Punishment like this.
  28. Mar 21, 2024 at 11:49 AM
    #5878
    cmiles97
    cmiles97 New Member
    XP package
    I really don't want to know my tasty bacon and ham can be a friendly pet. :eek2:
  29. Mar 21, 2024 at 1:45 PM
    #5879
    SnrDisregardo
    Wade
    IL
    So that's a F150 problem then?
  30. Mar 21, 2024 at 2:03 PM
    #5880
    borla123
    borla123 The Pits
    Ontario
    LOL
    I said it was a Sample Repair Report
    You wanna know the source of who does these PP tests ?
    you should ask @Eurodriver what happened to his Pet Goose when it got into doing some bad stuff. or was it a duck?
