2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. Jan 4, 2024 at 8:25 AM
    #5191
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    I would always use a certified scale to confirm steer, drive, and tow axle weights for a 1/2 ton. It's NOT like a 1 ton SRW HD where you can place a ton of weight on the tongue, laugh, and just roll out.
    8,000lbs on a flat bed trailer with WDH is not unreasonable for a 1/2 ton. It doesn't have the side profile to be impacted by wind nearly as much as an enclosed trailer. Also, for a flat bed car trailer, you can easily adjust the weight balance / tongue weight by moving the vehicle slightly forwards /backwards on the trailer. It's not like a travel trailer where it takes far more work to shift weight around on the trailer.
    I would think where you would potential run into the weakness with that configuration is downhill braking.
    For me, I generally divide the advertised tow rating in half and that's probably the real world tow rating for that vehicle which is most likely limited by its rear axle weight rating / capacity.
    Between 8,000lbs and 12,000lbs, I would opt for a 1 ton SRW HD gas pickup. Beyond 12,000lbs, I'd opt for a diesel power train for its exhaust braking capabilities.
  2. Jan 4, 2024 at 8:25 AM
    #5192
    Breathing Borla
    AZ
    they also made the frame 8" wider in the rear and it tows significantly better then the outgoing model , which is stated by pretty much 100% of the gen 3 owners after towing who have owned both. So it's not just focus on the center of the frame deal. and yes, its way stiffer, no more bed flopping all over, I don't miss that either or the shitty ride unloaded or light loaded.
    but I do agree with you as I stated in the other thread you were badgering me about, all new 1/2 tons are extended warranty purchases, way too much to go wrong with all the fancy shit everyone is bragging about.
  3. Jan 4, 2024 at 8:27 AM
    #5193
    Breathing Borla
    AZ
    ya, you can do it if your careful, no doubt. Sweers stated directly when they rated the tundra that he wanted it to not only tow that much, but tow it well. so there's that.
    just hope the magic ford pixie dust and undersized cooling system doest get you, HAHA, JK
  4. Jan 4, 2024 at 8:30 AM
    #5194
    Polo08816
    2014 BMW 335i
    My understanding is that those problems manifested in PowerBoost vehicles, not the non-hyrid vehicles. I wouldn't want the PowerBoost F150 because it downgrades you to a 30 gallon fuel tank compared to the non PowerBoost models that can have the 36 gallon fuel tank.
  5. Jan 4, 2024 at 8:31 AM
    #5195
    DFS
    DFS New Member
    2022 Capstone Tundra
    Yeah well for the safety of other drivers on the road, makes a lot more sense for you to use a 3/4 or 1 ton when towing in excess of 10,000. Yet, many Tundra and F-150 users admit to towing well over that "because they can". I know some people are exceptionally experienced with towing and it's a non-issue, not everyone falls into that category though. Driving I-80 for long stretches I see many instances of people overloaded, being pulled all over the road by an excessively heavy trailer and no WDH. A 3/4 or 1 ton wouldn't fix all the problems, but wheelbase alone with mitigate some risk.
    Another issue, EVERYONE overestimates their abilities time and time again just because they've "never had an issue".
    Breathing Borla likes this.
  6. Jan 4, 2024 at 8:34 AM
    #5196
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    At that weight you certainly better have trailer brakes though. My boat trailer has surge brakes and even at only 6500# I'm not really a fan. I'm looking into converting it to electric over hydraulic
  7. Jan 4, 2024 at 8:34 AM
    #5197
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Do you have any pics of the inside of your truck ?
  8. Jan 4, 2024 at 8:34 AM
    #5198
    Breathing Borla
    AZ
    I guess I differ, if your towing that much weight, the powerboost would be good at that, also the range is probably better even with the smaller tank. You could also then get the 7.2Kw generator for your outings.
    I think you should consider the other way around to your thinking.
    just my trying to understand Ford guys logic and provide tundra guys level headed thinking, which is why all of you are here right? HA :rofl::bowdown:
  9. Jan 4, 2024 at 8:36 AM
    #5199
    Breathing Borla
    AZ
    what do you want to see?
  10. Jan 4, 2024 at 8:38 AM
    #5200
    Polo08816
    2014 BMW 335i
    It's been tested - that's not the case. I believe there may be Youtube videos that indicate the results are contrary to this assumption.
    The hybrid powertrain really only improves in city fuel economy (and thereby distances). I also don't want the complexity of a hybrid powertrain. For highway towing, the hybrid powertrain is just extra weight you have to carry and a smaller fuel tank so you get a double whammy from it. I don't think Toyota's version would fare any better in the real world. The behavior would be similar.
  11. Jan 4, 2024 at 8:39 AM
    #5201
    Breathing Borla
    AZ
    ya, I can't fault you there, it didn't go well for me either looking at those fords
  12. Jan 4, 2024 at 8:40 AM
    #5202
    Bannerman
    Johnson
    Video?
  13. Jan 4, 2024 at 8:40 AM
    #5203
    Polo08816
    2014 BMW 335i
    I wouldn't want it in the Tundra either for the same reasons.
  14. Jan 4, 2024 at 8:44 AM
    #5204
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Everything ! Front seats , dash and rear seat area ?
  15. Jan 4, 2024 at 8:48 AM
    #5205
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Haha, You Boys could bench race, real race, handicap race my GTR and STI anytime you all want too.
    Free of charge.
  16. Jan 4, 2024 at 8:48 AM
    #5206
    DougNuts
    DougNuts New Member
    Call it the same, but the non-hybrid should have about 30 more miles of range, based on comparison of Fuelly data.
  17. Jan 4, 2024 at 8:49 AM
    #5207
    Breathing Borla
    AZ
    lol, I won't
  18. Jan 4, 2024 at 8:50 AM
    #5208
    Breathing Borla
    AZ
    I pick the time and spot? if so, titles for that GTR?
  19. Jan 4, 2024 at 8:51 AM
    #5209
    Bannerman
    Johnson
    What a silly thing to say. If we are "racing" vehicles across classes, bring the GTR and race me from one side of the lake to the other. Bring a snorkel.
  20. Jan 4, 2024 at 8:52 AM
    #5210
    Breathing Borla
    AZ
    you havent seen a platinum tundra interior before? or just want real pics and not the computer thingys?
    its all black with blue accent stitching and blue ambient lighting, black headliner, super sharp
  21. Jan 4, 2024 at 8:59 AM
    #5211
    TRDoffroadPRO
    It was a joke, but yes I have the titles to them.
    The Hyrbid Tundras are quick though, and I don't understand all this back and forth anyway especially dealing with a Ford. Some guy traded his Tundra off on a RAM so what does that tell you. I think the really value in a Toyota is resale at 80-100 thousand miles. They have historically held their values well.
  22. Jan 4, 2024 at 9:00 AM
    #5212
    js312
    js312 New Member
    2023 F-150 Lariat PowerBoost
    I'm not responding to everything, but:
    Regarding 4 Auto:
    The beauty of 4 Auto is situations where side roads are icy and the main road is clear. With a conventional transfer case, you might need 4H to get moving to leave the side road, then have to quickly switch back to avoid binding when turning 90° onto the bare dry pavement of the main road. 4 Auto just takes care of it - no switching back and forth, no binding.
    It's also helpful in situations like backing a trailer on a wet lawn or up a steep gravel driveway. 2H might slip, 4H will damage grass and leave marks on the driveway as you turn because it is locked 50/50 and has to slip to avoid binding. 4A doesn't bind and doesn't slip.
    I had conventional non-4A transfer cases on two trucks. It's really tough to consider going back to one once you've had 4 Auto.
    Flat load floor:
    I use my truck for stuff more than people. I liked the SuperCab F-150s because while they weren't great for people, I had loads of interior space for transporting large items that I'd prefer not to have exposed to the elements in the bed. One classic case is a large TV - I've moved a bunch outside of their boxes. You're supposed to keep them upright to transport them. The flat floor is perfect for that because I was able to have them flat on the floor propped up against the folded up back seat. No rocking back and forth on a hump that's putting pressure on the sides or anything like that.
    Range on 30.6 gal hybrid tank vs 36 gal non-hybrid tank:
    I see about 50 miles less range with 2 MPG better economy. So far I've gotten it to read 704 - currently on winter fuel and snow tires so maybe I'll see 750-760 in the summer. My plain EcoBoost 3.5 regularly showed in the low 800 range in the summer.
  23. Jan 4, 2024 at 9:02 AM
    #5213
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Just real pics . None of the dealers near me have any Tundras to see .
  24. Jan 4, 2024 at 9:15 AM
    #5214
    Bannerman
    Johnson
    What part of the country? My closest dealer has 75 new tundras in stock, and we have multiple dealers in town.
  25. Jan 4, 2024 at 9:32 AM
    #5215
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Hamilton Ontario Canada
  26. Jan 4, 2024 at 9:42 AM
    #5216
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In that case, I suspect it's actually less stiff.
  27. Jan 4, 2024 at 9:48 AM
    #5217
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My buddy tows fairly heavy with his Powerboost and has been getting worse fuel economy than his previous 5.0L. He really should be in a SD Powerstroke; I can't remember why he went with the F150 this time but it might have been availability when he was buying.
  28. Jan 4, 2024 at 9:50 AM
    #5218
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    If the frame is bigger in the rear then why the hell is the Bed smaller in dimensions? I haul stuff, large items, I tow rarely and never more than probably 6-8k lbs. How much do you need to tow? My rear axle is rated for more weight and if you are carrying weight in the bed, it works really well as Speers designed it to work and its a Lizard off road because of the Open C frame. Ride is good for a full size when loaded. I would never drive my truck around with an empty bed. It was a purpose made vehicle. And the few people I know that owned one never commuted in one. Thats where the 3rd Gen is focused.
  29. Jan 4, 2024 at 9:57 AM
    #5219
    Bannerman
    Johnson
    Yeah if you want good economy while towing heavy you need a diesel, period.
  30. Jan 4, 2024 at 10:14 AM
    #5220
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Guys I have an idea that will help us all out and no one leaves empty handed...... Lets all get together and meet up in person. We'll line all of our F150's and Tundras in a row behind us and set up cameras at all angles. Then lets all get into a massive fist fight! Just kick the shit out of each other! Then we upload it to Youtube as the Official F150 and Tundra Fist fight. I would imagine it will amass a ton of views and we all can split the money we get from it. Its a win win and people in the comments can cheer on their choice of truck owner in the fight!
    What do you all say!?!?
    Polo08816 and Bannerman like this.
