2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. May 7, 2023 at 1:31 PM
    #2971
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    How can I when it bothers you so bad?
  2. May 7, 2023 at 1:34 PM
    #2972
    Breathing Borla
    AZ
    bothers me, lol . That’s a good one
    just having a little fun just like you are
    Bannerman[QUOTED] likes this.
  3. May 7, 2023 at 1:38 PM
    #2973
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    You seen the new Tacoma. Gotta say it’s pretty badass
  4. May 7, 2023 at 1:39 PM
    #2974
    Breathing Borla
    AZ
    I sure hope they fixed the trans programming and the seating position relative to the door entry size
    Tundrastruck91 likes this.
  5. May 7, 2023 at 1:40 PM
    #2975
    Bannerman
    Johnson
    Very surprised to say that I do like it, I was never a fan of the third Gen, looks or drivetrain.
  6. May 7, 2023 at 2:33 PM
    #2976
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I am stuck between being hopeful that Toyota is out for blood with the new Taco (protect that market share!) and thinking that it's going not be nearly as cool as it could be. GM twins are putting out 430 lb ft of torque from a turbo 4cyl that is by all accounts so far a reliable little motor.
    I want to see the Taco return to its Hilux roots. Unkillable, go anywhere, 1 metric ton of available payload. But that would involve more payload than the 3rd gen Tundra gets, so I'm not holding my breath.
    Cpl_Punishment and in_the_mud like this.
  7. May 7, 2023 at 3:49 PM
    #2977
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    If the new Tacoma has better seat positioning with a tad more rear space, I'd honestly be tempted to trade the Tundra and go back.
    Kung likes this.
  8. May 7, 2023 at 3:50 PM
    #2978
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    There’s a solid 90% chance the new Tacoma is going to be super lame. Toyota had 15 years to redesign the Tundra and all we really got mechanically is an optional rear locker that only works in low range, coil springs on the rear axle, 4 more forward gears, and a TTV6 that makes an additional 8 horsepower and an additional 78lb-ft of torque.
    So my prediction is we see the Tacoma get a 10 speed, coil springs out back, and a turbo I4. If the same percentage of power gain from the Tundra is applied to the Tacoma that means we might get 280 horsepower and 318 ft-lbs of torque.
    Probably optimistic considering the bread and butter Lexus RX had the same 2GR-FKS in a higher state of tune making 295 horsepower, and 267ft-lbs of torque and the replacement I4 turbo T24A-FTS (which is the same model the Tacoma will get) makes only 275 horsepower, but torque is up to 317ft-lbs. Tacoma will probably get the Highlander tune for 265hp and 309ft-lbs.
    Pretty freakin’ lame compared to the 2.7L GM I4 turbo.
    Soupbean77 and Bannerman like this.
  9. May 7, 2023 at 3:50 PM
    #2979
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    My coworkers brand new Expedition broke down at 950 miles. Wouldn’t shift past first gear. Power Control Module went bad. Ford dealer fixed of course but didn’t seemed too surprised it happening. Toyota isn’t perfect, but Ford reliability isn’t good.
    Cpl_Punishment likes this.
  10. May 7, 2023 at 5:16 PM
    #2980
    Bannerman
    Johnson
    Still better than the minivan motor.
  11. May 7, 2023 at 5:23 PM
    #2981
    18" TRD Off Road Wheels
    Minivans have better payload than some midsize trucks. Don't go knocking them. :p
  12. May 7, 2023 at 5:41 PM
    #2982
    Coal Dragger
    Kung Fu Dick
    In defense of the I4 turbo T24A-FTS the torque delivery characteristics are superior to a naturally aspirated V6 2GR-FKS, and probably better for use in a truck, SUV, or a minivan.
    I will hold out some hope that Toyota will bring a slightly larger displacement I4 than 2.4L to match the GM for power, but they probably won’t. Toyota’s solution will be a hybrid to match the GM for torque and power. Unfortunately Toyota’s hybrid adds a lot of weight and eats up storage space.
  13. May 7, 2023 at 8:25 PM
    #2983
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Nope. That’s warranty cost per vehicle and defect rate per vehicle.
  14. May 7, 2023 at 9:05 PM
    #2984
    catalac
    catalac New Member
    Hopefully they replaced the anemic power plant.
  15. May 7, 2023 at 11:18 PM
    #2985
    mass-hole
    mass-hole New Member
    The mopar exhaust on the Rebel GT was annoying. Every cold start was very loud and borderline embarrassing. Engine braking down hills(I was in Banff so I was doing this fairly frequently) was obnoxious. I dont feel like my truck needs to sound like im drag racing just trying to head to Tim Hortons in the morning.
  16. May 8, 2023 at 1:50 AM
    #2986
    Coal Dragger
    Kung Fu Dick
    The tires are an easy enough fix, and having suffered through a set of Goodyear Wrangler Duratrac tires I agree 100% on the excessive noise. Plus no matter how many times those tires were rotated and balanced they cupped, and vibrated like crazy at highway speeds.
    The small fuel tank is a tougher issue to remedy though if you buy an AT4 with the 6.2L, I don’t think anyone makes a replacement tank with greater capacity for the gasoline engines. There is an aftermarket tank for 1500’s with the 3.0L Duramax though.
  17. May 8, 2023 at 4:01 AM
    #2987
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Personally, I don't want to hear the too much rumble at idle after the truck is warmed up. When I enter the trail section up north going through the forest I want to slip through unnoticed. My Borla can only be heard when on it. I live in the country on a large lake. Sound resonates and bounces. Yeah, everyone knows the sound of the RAM, they are loud even at idle. There are a bunch of new RAMS here and you can hear them from a distance. I thought the guy that buys a Limited trim RAM would want it quieter. Now if Toyota would allow me to upload the exhaust sound of my 993 into the algorithm, that would be a selling feature.
    Cpl_Punishment and Mattedfred like this.
  18. May 8, 2023 at 7:28 AM
    #2988
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    This is why I got a canopy for my truck.
    I looked at a 5.5 ft bed with a tonneau cover and ascertained that all my wife's crap wouldn't fit in there on trips.
  19. May 8, 2023 at 7:29 AM
    #2989
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Maybe don't get the off road trim, then?
    Breathing Borla likes this.
  20. May 8, 2023 at 7:56 AM
    #2990
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Trade the CRV for one?
  21. May 8, 2023 at 8:01 AM
    #2991
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Crv long gone lol
    I just sold my 2023 pilot and my raptor gets picked up Wednesday for transport :anonymous:
    BUT I am #1 on the list for a grand highlander, might move that to the Tacoma list
  22. May 8, 2023 at 8:06 AM
    #2992
    Bannerman
    Johnson
    R?
  23. May 8, 2023 at 8:09 AM
    #2993
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Hell no lol. If I could find one at msrp sure. It’s a showroom demo I found in Michigan. 2022 black with recaro interior for 79k . Still has front locker, heated steering wheel, and advanced security pack.
  24. May 8, 2023 at 8:11 AM
    #2994
    Bannerman
    Johnson
    Nice. I'm a big fan of the Torsen.
    I saw a R for sale the other day for $199,900.
  25. May 8, 2023 at 11:00 AM
    #2995
    nodak67
    nodak67 New Member
    JR
    yeah really looking hard at the GH as a maybe replacement for the 4runner in my old age. have to really see how the 6th gen 4runner stacks up interior wise to a GH.
    i will need a heated steering wheel and more tech and bigger screen in my 6th gen to make up for holding out on my 2014 for so long. gotten spoiled on the wife's 23 tundra.
    akmerle likes this.
  26. May 8, 2023 at 12:10 PM
    #2996
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Talk about circle jerking…
    Melikeymy beer and Bannerman like this.
  27. May 9, 2023 at 2:40 PM
    #2997
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I am in a loaner escape because the dealer needs tomorrow morning to finish completely rewiring my tailgate button as per the recall.
    I'll say again, In my opinion hands down dumbest and most useless feature on higher end new pickups. I almost told them take one off an XL that has a regular latch and manual lock and paint it rapid red for me.
  28. May 9, 2023 at 3:47 PM
    #2998
    mass-hole
    But how are you supposed to open the tailgate without spilling your latte on your flannel shirt. Imagine if you had to yank on a handle and the tailgate came flying down at you. Yuck.
  29. May 9, 2023 at 3:51 PM
    #2999
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My Tundra has a soft open tailgate. My FIL's F150 does not. Checkmate, Ford fans. :cool:
    Mattedfred and Outbound like this.
  30. May 9, 2023 at 3:57 PM
    #3000
    mass-hole
    You just have to spend more money on skid plates, rock sliders and ceramic coatings to keep it pristine.
    PomDad and 22whatwedo like this.
