2022 Tundra development
Discussion in 'Valhalla’s Shield' started by Classy63, Dec 24, 2021.
  1. Feb 15, 2022 at 4:00 PM
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Amendment to my plan for the 4x4 trucks, I am going to use a low profile lock nut and a 1/4” shorter bolt at that corner to give it more clearance
  2. Feb 23, 2022 at 12:26 PM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Will the cat plate fit with a TRD skid plate? Same question for the tow hook plate?
    Also, new to owning a truck and cat theft issue. is weight and strength the main difference between the aluminium and steel plates?
    Thanks!
  3. Feb 23, 2022 at 2:14 PM
    Classy63
    Tyler
    Cypress Texas
    This will fit with the TRD plate, I am going to be installing one on the truck that got the prototype to be sure soon
    the tow hooks solution will not get in the way the of the pro plate, this is on hold looking for someone local willing to have me take apart the front of their truck
    AggiePhil and DesmoDoe like this.
  4. Mar 29, 2022 at 9:05 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    Hi. Have you confirmed your 2022 Tundra cat plate will fit with the TRD plate?
    Also, will the same plate be used for the 2022 Tundra Double Cab gas, CrewMax gas and CrewMax hybrid 4X4 models?
  5. Mar 31, 2022 at 9:32 PM
    Fairlane
    Fairlane New Member
    Dave
    2022 Tundra Platinum hybrid
    Hi. I've got a 2022 Tundra Platinum on order in Canada. Well actually I have two on order. One Platinum gas engine no AVS or air bags and one Platinum ordered a month later when I could get the hybrid and the AVS and load leveling air bags. I plan to keep the hybrid version.
    I don't imagine the AVS or rear air bags will have any impact but for the cat plate do you know if there is any difference for fit on a hybrid vs regular gas engine?
  6. Apr 2, 2022 at 8:53 PM
    Fairlane
    Fairlane New Member
    Dave
    Looking at more pictures and videos online clearly the hybrid transmission is pushed farther back and the transmission mount has to have moved back with it. Therefore hybrids will need a longer cat plate in order for the plate to mount to the transmission support cross member.
  7. May 27, 2022 at 7:41 PM
    Classy63
    Tyler
    Cypress Texas
    So, the 2022 plate changes have me considering an option since I hate standard security bolts. I need clearance for the PRO plate people. I am considering using one of these on the passenger side along with bolts in the threaded holes that are there from the pro plate from the factory. So the intent here is to make this plate FULLY functional with the PRO plate, while being an oil change tech/DIY best friend. All the other plates I have seen for the 22 have the 2 threaded holes holding up the front of the plate. That works, but there is a problem that comes up whenever you go to actually change the oil. You remove the PRO plate and the cat plate droops down. This fatigues the metal and causes a PITA for whomever is doing the work. My solution is to add an elevator bolt to hold the front of the plate up and at the same time making access to the cats harder. This will make install of the plate a bit of a PITA, but I would personally rather spend another few minutes installing this bolt than giving a thief and easier target.
    So, there would be 3 bolts in front and 2 in the rear. I have issues going with the easy bolt hole on the driver side because how damn close that nut and bolt is to the half shaft for 4x4.
  8. Jul 17, 2022 at 3:49 PM
    Firemedic1428
    Firemedic1428 New Member
    2022 Blueprint Platinum CM
    Just ordered an Aluminum 1/4” cat plate! I imagine this is a straightforward install with the pentagon bolts?
    Classy63[OP] likes this.
  9. Jul 17, 2022 at 4:32 PM
    Classy63
    Tyler
    Cypress Texas
    Yes. To make sure, you don’t have a Hybrid correct?
  10. Jul 17, 2022 at 4:38 PM
    Firemedic1428
    I do not.
  11. Jul 18, 2022 at 9:23 AM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Any more information on fitment with Hybrids and clearance with TRD Skid Plates?
  12. Jul 18, 2022 at 9:53 AM
    Classy63
    Tyler
    Cypress Texas
    I have the first hybrid plate being made now. The PRO plate will fit just fine
    DesmoDoe likes this.
  13. Jul 18, 2022 at 9:55 AM
    18" TRD Off Road Wheels
    Pure casual interest here, as I do not have a 3rd gen, but are these cut on a machine in house? Just for the sake of neat stuff to see, do you have a clip/video of it being done? CNC and laser cutters are fun to watch. :D
    Classy63[QUOTED][OP] likes this.
  14. Jul 18, 2022 at 10:37 AM
    Classy63
    Tyler
    Cypress Texas
    I contract it out locally.
    I actually just deleted all the old manufacturing pictures and videos
    GODZILLA[QUOTED] likes this.
  15. Jul 18, 2022 at 10:38 AM
    No worries. Was just idle curiosity anyway. :thumbsup:
  16. Aug 18, 2022 at 1:54 PM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    How's the progress on the hybrid plate? I don't see any options for it on your site yet so thinking it's still being worked on.
  17. Aug 18, 2022 at 5:40 PM
    Classy63
    Tyler
    Cypress Texas
    Annoyingly slow… I was supposed to have a prototype made again this week
    DesmoDoe[QUOTED] likes this.
  18. Aug 30, 2022 at 12:23 PM
    Classy63
    Tyler
    Cypress Texas
    The 22+ hybrid plates are live on my website!
    Ray D and DesmoDoe like this.
  19. Aug 30, 2022 at 2:35 PM
    #49
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    @Classy63 this is great news. To confirm, is it four bolts to secure the hybrid plate to the truck? Also, I was looking to buy the Toyota TRD front skid plate. Is the front skid plate even needed with your hybrid plate? Thanks.
    Edit: Also, would there be any issue using the Rock Hard Rock Dome bolt head protectors with the plate?
  20. Aug 30, 2022 at 2:48 PM
    #50
    Classy63
    Tyler
    Cypress Texas
    There is an option when ordering the plate to add pentagon bolts
    The plate has holes for the TRD plate. The TRD plate and the cat plate do different jobs, I wouldn’t say one would replace one with the other as they cover different spots
    The rock domes of course would work, but you would only need 2 for the rear of the plate as the TRD plate will cover the front
  21. Aug 30, 2022 at 3:18 PM
    #51
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    @Classy63 If I order two additional pentagon bolts, do you know if they are the same size as the two front bolts used for the front of the Toyota TRD skid plate? I'd prefer to have all pentagon bolts on your hybrid plate and the Toyota TRD skid plate. Thanks.
  22. Aug 30, 2022 at 6:11 PM
    #52
    Classy63
    Tyler
    Cypress Texas
    The TRD skid plate uses much smaller bolts. I think they are M12
  23. Sep 1, 2022 at 6:07 PM
    #53
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    @Classy63 I ordered your 2022+ Tundra hybrid aluminum cat plate yesterday (Sep.01) via your website. Will I need washers, bushings, or your nut plate to install the cat plate? If so, I'd like to add them to my order. Thanks.
  24. Sep 2, 2022 at 10:57 AM
    #54
    Classy63
    Tyler
    Cypress Texas
    Nope!
    Ray D[QUOTED] likes this.
  25. Dec 30, 2022 at 11:45 AM
    #55
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    For those of you who ordered the 2022+ Tundra hybrid aluminum cat plate, this may give you some idea as to timing regarding a similar order.
    I ordered my 2022+ Tundra hybrid aluminum cat plate on 01 Sep 2022 from Valhalla's Shield and it was delivered to my doorstep in Canada on 22 Dec 2022. I have no issue with the delivery time as I was well aware of the delays in production/shipping when I ordered the plate.
    The plate was well packaged and received without issue. As per the attached photos, the cat plate looks great and the powder coating is 100% uniform on the plate. The welds on the seams are clean and the pentagon bolts/socket were also well packaged.
    The cat plate will sit in my garage until I take delivery of my 2023 Tundra hybrid Limited TRD Off Road, which is anticipated to be in early spring 2023. I will provide an update with additional photos once I get my truck and install the cat plate.
    Thanks to @Classy63 for delivery of a quality product.
    Classy63[OP] and DesmoDoe like this.
  26. Dec 30, 2022 at 12:00 PM
    #56
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    I concur. I order mine Aug 30, 2022; received the same week (Canada as well) but was also prepared for the wait/delay. Plate was installed on my truck and the fit is good and I'm satisfied with the plate and quality of the product. Thanks!
  27. Jan 22, 2023 at 10:33 AM
    #57
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    @Classy63 or anyone else: Are you able to confirm the 2022+ Tundra Hybrid Cat Plate is the same for both the 5.5' bed and 6.5' bed trucks? I purchased this plate for a 5.5' bed Tundra Hybrid I have on order but I now have an opportunity to lock in an allocation for 6.5' bed Tundra Hybrid and I'd like to confirm the same plate fits both trucks. Thanks.
  28. Jan 22, 2023 at 11:37 AM
    #58
    Classy63
    Tyler
    Cypress Texas
    Bed size does not change anything for the plate, only hybrid or non hybrid
